speaker recommendations - Dodge Cummins Diesel Forum
Old 05-02-2012, 01:25 AM   #1 (permalink)
Can anyone give me any insight as far as what brand speakers that you replaced your stock ones with, fronts, rears, and tweeters.Wanting to get some that sound good. I know that the fronts are really shallow so i want some that fit without much modification to the mounting holes. Also does anyone know the speaker depth of the fronts and rears?
'02 2500 QC 4X4 Auto, AirAid MXP, MBRP 4" Staight Pipe, HX35, MM 12K Winch, Raptor FRRP/DAP Bigline, Isspro EV2's, Quad XZT, Cooper ST Maxx 285's, Bilstein HD's, Custom Diesel Stabilizer, Recon, 46K
tlpatter is offline   Reply With Quote
Old 05-02-2012, 08:40 AM   #2 (permalink)
fwiw, i was able to fit infinity kappas in the front doors without any modifications, and they have a pretty big magnet. my personal recommendation would be infinity or alpine.
DannyMK2 is offline   Reply With Quote
Old 05-02-2012, 09:55 AM   #3 (permalink)
jesnic's Avatar
I replaced all my factory speakers with polk audio. Fit great with no modifications.
02 QC LB, 4x4, ISSPRO gauges, garmonized trans, triple disk, hot rod vp44, dragon flow sticks, Garrett GT3782R, aem workhorse intake, 4:10, 4" silverline, BD RAD, comp as ez, smarty, raptor 150, 285/75/17 nittos, nav, dvd, twin 15" subs, 7.1 surround sound.
jesnic is offline   Reply With Quote
Old 05-02-2012, 11:10 AM   #4 (permalink)
Gnelsonjr's Avatar
I recommend Diamond Audio. Using MDF i made a spacer to help bring the speaker forward allowing me to fit a deeper speaker without hitting against the window glass.
01 2500 Laramie 24V Cummins, 4X4, S&B CAI, MBRP 4"-6" Turbo back Stack Kit, FASS Lift Pump, Juice W/Attitude, Smarty, 85HP Industrial Injectors, Phatshaft 62/80, Full Billet Auto Trans W/Goerend VB, Borgeson box/shaft, 4th Gen Steering, 3rd Gen Brakes.
Gnelsonjr is offline   Reply With Quote
Old 05-02-2012, 11:23 AM   #5 (permalink)
Western WA President
jigabop's Avatar
I'm eventually going with polk audio
'00 2500 Sport 4x4 SOVP, 6spd, 4.10's 2" lvl, 315/75R16 BFG M/Ts, posi-lok, SB3600-6DD, DDP150's, S357/S475 twins, Adrenaline w/Pulse v1, Smarty, ARP 425's, AirDog150 + DS-V liberty mod, DiPricol fp gauge, 2x isspro boost gauges, 08.5+ steering, carli low-mount, DT ProFab track bar, 5"str8 pipe 538hp 1078tq 10/1/2010
"Tow mirrors extended with no trailer is like wearing a condom with no woman." - UnregisteredUser
jigabop is offline   Reply With Quote
Old 05-02-2012, 09:24 PM   #6 (permalink)
KATOOM's Avatar
I understood that it wasn't that simple if you have the Infinity OEM system since every speaker has its own amplifier. And if you have the pillar tweeters then you have the Infinity system no matter if it says it anywhere or not. I too would like to add some bass to my stereo system but given all the talk about whats involved with the Infinity system, I haven't done anything yet. Stereo systems aren't my forte.
'01 2500 Sport 4x4 5spd, EZ, straight piped, no sillencer ring, aFe intake, 2 lo kit, Isspro Boost, fuel pressure, and EGT all on pillar, Westach Transmission/Differential temp gauge in dash pod, Raptor 100 with big line kit, Pac Brake, 285's
KATOOM is offline   Reply With Quote
Old 05-02-2012, 09:59 PM   #7 (permalink)
BigBad12V's Avatar
I have Boston acoustics speakers and 10" subs under the backseat. JVC touchscreen head unit, and JL Audio amplifier to finish it off. Sounds great!!!
Sent from my Autoguide iPhone app
98 Ram 2500 12V 4x4. ED 64/74/14. 5x.014 Injectors. Custom DV's. Tuned 180 P7100. RBHAF. 4K GSK. 60lb Valve Springs. Triple Disc TC, Valve Body and Shift Kit w/ Billet Shafts. TC Lockup Switch. Dual Electric Fans. 290,000 miles and still purrs like a kitten! =)
BigBad12V is online now   Reply With Quote
Old 05-03-2012, 09:40 AM   #8 (permalink)
my last truck had the infinity system and it wasnt an issue at all. granted it was a third gen but still. if the infinity system scares you, just bypass it. run new speaker wires and put in an aftermarket amp. it will sound a million times better.
Old 05-03-2012, 09:47 AM   #9 (permalink)
jesnic's Avatar
That's exactly what I did. Bypass the entire infinity system and installed 2 front doors, two front tweets, two rear doors and two subs. One amp for subs and one for everything else. Pretty simple.
Old 05-03-2012, 09:47 AM   #10 (permalink)
Smourj21's Avatar
iTrader Score: 4 reviews
i just put infiniti 6x9's in the front door they sound good! just cant figure out how to get the back door skins off
i did hear the infiniti kappa speakers sound awesome
02 QCSB 6 Speed|215 P-Pump 600cc 24*|SAC 7x12|131 DVs|.084 Lines/Tubes|64/71/14/S475|Tunnel Ram|CFM+| Water/Meth |6" Miter|Valair DD 3600|Colt 181|HD Push Rods/Springs| O-Ringed Head|ARP Studs|AD150|Dana60/80|3:55|True Trac|35" Toyo MT's|Quest for 700+ |
Smourj21 is offline   Reply With Quote
Old 05-03-2012, 09:50 AM   #11 (permalink)
Jdufff25's Avatar
Agree with Danny above me I deleted the infinity in my truck and went all JL Audio with an aftermarket cd/mp3 player. Sounds 10 times better than stock especially with the 12" sub I installed under my backseat. Just the rich balance between treble, mids, and bass. Only mods that had to be done to install JL speakers was I had to cut out the tweeter grills in the a pillars and find the audio inputs from the infinity amps and hook up my speakers. Walla no more infinity system
2001 Ram 2500 4x4 24v Cummins 6spd
4in. Turbo back exhaust, 95gph fass platinum, RV275 injectors, S&B Cold air intake, 550hrs. South Bend Single Plate Clutch, Much More to come
Jdufff25 is offline   Reply With Quote
Old 05-06-2012, 03:24 AM   #12 (permalink)
JacksonDog's Avatar
Just replaced mine with Polk Audio and bypassed the infinity amps. Run my two ten inch subs through a 1000 watt amp and the door speakers through a 250 watt amp. Sound is great! Especially the Polk Audios.
I am here: http://tapatalk.com/map.php?t1xhdq
99 2500 4x4 Laramie, Ranch Hand front,62/65/12, ADR/Pulse, MBRP 4" , BHAF, AD100, Isspro fp gauge, lvld, boost elbow, Relentless billet w/ triple. CPP 200s, Tunnel Ram. Steering brace, dual stabilizer, heims, adj. tracbar. 1000 watts. Rhino'd rockers. Air Ride
JacksonDog is offline   Reply With Quote
