ATF or power steeringfluid? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 04-11-2012, 06:12 PM Thread Starter
cummins5445's Avatar
I just got my power steering pump replaced on my 2001 ram 2500, 5.9 cummins. Does it use power steering fluid or ATF??? My mechanic put ATF in but i for some reason dont trust it... what do you guys think?
Sent from my LG-P500h using AutoGuide.Com Free App
cummins5445 is offline
post #2 of 18 (permalink) Old 04-11-2012, 07:09 PM
gearhead759's Avatar
Direct quote from the FSM "CAUTION: Use MOPAR Power Steering Fluid or
equivalent. Do not use automatic transmission fluid
and do not overfill"
I would take it back to the shop to get that atf out of there quickly, do a full thorough flush and refill with the proper fluid. If there is any damage to the pump or powerboost system they need to pony up and repair/replace any damaged components.
01.5 HO 6sp. Airdog, RV275s... muffler MIA.
gearhead759 is offline
post #3 of 18 (permalink) Old 04-11-2012, 07:41 PM Thread Starter
Thanks man, I'll do that asap.
post #4 of 18 (permalink) Old 04-11-2012, 07:50 PM
I've run atf for 150000 miles now without a problem yet!!
Are you going to listen to me in English or do i need to speak to you in 12 gauge?
littleboy is offline
post #5 of 18 (permalink) Old 04-11-2012, 07:52 PM
irish power mad's Avatar
Never used atf in a power steering myself but I know guys who do and they have no problems.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator,
half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open
)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #6 of 18 (permalink) Old 04-11-2012, 08:00 PM
Add some Glo for that Soul!
sebastian f7's Avatar
Lots of guys run it.
sebastian f7 is offline
post #7 of 18 (permalink) Old 04-11-2012, 10:59 PM
lilbrownCTD's Avatar
I have never used the Mopar Power Steering Fluid in any of the rigs I've worked on, I've got 178k miles and always used atf +4. works great and have never had a problem with leaks.
2001 Dodge Ram 2500 QCSB 4" TBE, PDI 3 piece manifold, AFE intake, Edge Juice CS, 100hp DDP injectors, FASS 95 Titanium, Built Suncoast Transmission with Triple Disc Converter, HE351CW swap
lilbrownCTD is offline
post #8 of 18 (permalink) Old 04-12-2012, 10:05 AM
my last dodge called for atf+4 not power steering fluid. not really sure what this one take, havent checked.
DannyMK2 is offline
post #9 of 18 (permalink) Old 04-12-2012, 10:59 AM
Freakin' Honey Badger
99StoneColdCountry's Avatar
I've used ATF for years also, never any problems. Its just hydraulics, building pressure. My older mud trucks I run straight 30w oil in the PS since they're so old and worn, but it keeps them working until I decide to finally replace them
1999 QCSB 4x4 built 5 speed: Valair 13" clutch & hydraulics, BD short throw, EGT/boost/fuel gauges
HRVP, FASS 95, CPP 125's, Super B, BHAF, 4" TBE, Tunnel Ram, Pusher Intake, Edge Comp Drag
Carli Suspended with Carli control arms & 325/70s on 3rd gen rims
SOLD Lookin for a 4x4 First Gen
99StoneColdCountry is offline
post #10 of 18 (permalink) Old 04-12-2012, 11:10 AM
I believe the reason that dodge does not recomend ATF is that it is a detergent. And if you read through your service manual that dodge actually recommends that you change the PS oil every so many 10000 miles.
Therealchucknorris is offline
post #11 of 18 (permalink) Old 04-12-2012, 11:12 AM
FROM FREAKIN CHUCK NORRIS!!
Even though I believe your picture is off, because I have Walker Texas Ranger's truck
post #12 of 18 (permalink) Old 04-12-2012, 11:17 AM
argo i win
