Interesting Info about 00-02 Ball Joints - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 02-25-2012, 06:38 PM Thread Starter
DSLDVL's Avatar
Check this out:
Dan The Gear ManŽ Tech Note: Ball Joint failures on 2000-2002 Ram Trucks is a reoccurring problem that will probably plague these trucks for their entire life due to the size of the Ball Joints and the steering geometry of the 2000-2002 Dana 60 Front axle.
The Upper and Lower Ball Joints on these axles are at different angles, in other words the vertical axis of the Upper and Lower Ball Joints are neither in-line or parallel to each other. To compensate for the different arcs of each Ball Joint during turns, the modest sized, straight shank, .855" diameter stud of the greaseable Upper Ball Joint is vertically floating in a plastic sleeve. Consequently, the Upper Ball Joint does not support any weight, it merely keeps the knuckle in place. On these axles, the Upper Ball Joint is not really a Ball Joint at all, instead it is a floating King Pin that is smaller in diameter then King Pins found on 1966-1981 Ford F100 4x2 1/2 ton trucks and light 3/4 ton trucks with GVW's of 4,700 lbs-6,900 lbs.
The non-greaseable Lower Ball Joint is load bearing, in fact, the two Lower Ball Joints carry 100% of the front axle weight on your 2000-2002 Dodge Ram 2500 or 3500 truck. Dimensionally, the outside diameter of the Lower Ball Joint is only 3.5% larger than the Ball Joints used on 1972-1986 Jeep CJ's (and other light-duty models of that era) which has somewhere between 1/4 and 1/3 of the front axle weight of the Dodge Ram, plus both the Upper and Lower Ball Joints on the CJ are load bearing. In addition, the Ball Joints used on older models like the Jeep CJ and 1994-1999 Dodge Ram 2500 and 3500* shared the same vertical center line axis and were pre-loaded to compensate for wear. With the 2000-2002 front axle steering geometry using differing Ball Joint angles, no preload is possible, therefore, any wear means loose Ball Joints.
Yes, lack of lubrication with the non-greaseable factory lower Ball Joints can be a factor; however, very few of the failed lower Ball Joints we cut apart are suffering from a lack of lubrication. Replacement Ball Joints in both greaseable and non-greaseable versions are available from us, plus there are even offset upper Ball Joints out there (which in my experience is both short-lived and of limited use). Installing Greaseable Ball Joints and regularly greasing them may provide longer service life, but with the 2000-2002 axle, chances are you will still need to replace the Ball Joints every three to five years. One would not mind the relatively short Ball Joint life so much if these trucks steered better than previous models, were not subject to "Death Wobble", or had longer tire life.
I do not find any allowable Ball Joint tolerances in my Factory Dodge Ram Truck Service Manuals. Generally, with a solid axle, any side to side play is grounds for replacement. Some slight vertical play is probably acceptable for these years.
*1994-1999 Dodge Ram trucks with the Dana 60 Front Axle have Lower Ball Joints that are nearly 10% larger than the 2000-2002 axle. Average Ball Joint life for 1994-1999 trucks is close to 150,000 miles or 7 to 10 years. All 4 Ball Joints for those years carry weight and are pre-loaded to compensate for wear and dampen steering shocks.
Credit to: Quad4x4.com and "Dan the gear man"
I crawled under mine and it is in fact like this. Apperently the 00-02 are the only axles with this set-up.
01.5 2500 QCSB 4x4 5.9 SLT, 47RE Rebuilt @ 140k, 3.55 gears, 285/70/17's, 4" Straight pipe/exhaust brake. Purchaced 5-13-11, 190k on the clock now. Added: fuel press/trans temp/EGT gauges, TC L/S/UL switch, Edge comp, dual fuel pumps
DSLDVL is offline
post #2 of 19 (permalink) Old 02-25-2012, 07:31 PM
Only 110,000 mile and one bad ball joint on my truck.
Horrible design.
His-2001 4x4 QC CTD HO
Hers- 2003 4x4 QC CTD HO
Project- 1965 Dodge Town Wagon
bigdav160 is offline
post #3 of 19 (permalink) Old 02-25-2012, 08:08 PM
Old_Sparky's Avatar
158k and still running the original ball joints on mine.
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude, Airdog 100, K&N air filter, 17" rims, big brake upgrade (2004 version), 08.5 steering upgrade, CPP 125 hp injectors.
Old_Sparky is offline
post #4 of 19 (permalink) Old 02-25-2012, 08:34 PM
mfulton2389's Avatar
216,xxx on mine and I just replaced the originals with xrf's only 1 was bad but if you're gonna do it ya might as well do it all and do it right
01 3500 drw qc 5spd 4x4, 5" straight, Raptor 150, afe stage 1, Isspro fuel, pyro, boost. TST Comp/Smarty w/Revo, DAP 7X10'S, Super B, Valair DD. "Don't call what you're wearing an outfit, don't ever say your car is broke" DBT
mfulton2389 is offline
post #5 of 19 (permalink) Old 02-25-2012, 09:40 PM
Hello Kitty admirer
MadMikeX3's Avatar
Would doing a 3rd gen steering upgrade correct the angles?Steering upgrade thread I really am thinking of doing one because I have so much play in my steering. Im constantly moving the wheel left to right to keep straight. Im sure a new updated steering box from PSC would help me there. PSC box
00' 2500 Sport QCSB, 4X4 Auto, Open down-pipe exhaust, Smarty S-03, Air Dog I, Eagle Alloy Series 185 16X10 Maxxis Buckshot's 315/75/16. ""There is no replacement for Displacement except for volumetric forced induction."
MadMikeX3 is offline
post #6 of 19 (permalink) Old 02-25-2012, 10:11 PM
Add some Glo for that Soul!
sebastian f7's Avatar
Not in my experience I had brand new Moog joints put on last year 1 lower is already trash. I bought a ball joint press and will do the replacements myself from now on. Moog wont be making any money from me on Ball joints since they have a lifetime warranty.
sebastian f7 is offline
post #7 of 19 (permalink) Old 02-26-2012, 12:01 PM
Waldershrek's Avatar
my original ones made it to 268k lol. Just replaced them with Napa lifetime warranty ones this past summer. What a that was too let me tell you.
01 Dodge Ram 2500//262,000 miles and counting//AFE Stage 2 air box AFE dry flow filter and pre-filter//Raptor 150//Diamond Eye 4" stainless dual exhaust//Isspro Ev2 fuel pressure gauge
Waldershrek is offline
post #8 of 19 (permalink) Old 02-26-2012, 02:29 PM Thread Starter
DSLDVL's Avatar
Yeah mine made it to 187k. Not bad for inferior design. looking at replacements now. Either spicer or XRF.
DSLDVL is offline
post #9 of 19 (permalink) Old 02-26-2012, 04:35 PM
kickers99's Avatar
323k on mine. Checked them yesterday, no play at all
Sent from my Crapper
99 qcsb sport- sold
08 3500 srw g56,
Deleted,5" flopro,s&b,efi-anarchy, valair dual disc
kickers99 is offline
post #10 of 19 (permalink) Old 08-22-2012, 11:42 PM
peddlebike's Avatar
An older thread ......
My '02 has a small 'plug' on the top of the lower ball joints. It looks to be the type of plug (grease-able with a pin type fitting) that are on the U-joints. How anyone would be able to get the pin type applicator past the axle u-joint is a mystery......any ideas?
'91.5 LE-W250 RC, 5sp, 3.54 lim. slip, guages, ..... inter-cooled, tweaked.
'02 Regular cab 4x4 .... 5sp, 3.54 lim. slip, Juice/Attitude, 4" turbo back.
peddlebike is offline
post #11 of 19 (permalink) Old 08-23-2012, 12:44 AM
Ahhhh, I didnt know this about the 2000-02's .
Another good thing about my '99 with heavy duty 88000 gvw.
I wondered why lots of people have ball joints worn out. My truck is still tight
Ill have to compare mine to a 00-02 front axle
'99 quad,long bed,4x4,auto, tow pac,reese 5th ,isspro guages,SMR shift kit, New VP44, JIC fuel line fittings, Red Head Steering/Big D steering brace, some other crap too
GSP7 is offline
post #12 of 19 (permalink) Old 08-23-2012, 02:32 AM
uhm all the 3/4 tons were rated 8800gvw.
HAH, 100k on my truck, and my uppers were loose...lowers are solid as can be, and show literally no wear.
2001 RCLB, Quad 4k, 6x.018s, dragonflow extreme vp44, 66 over s480, 5" turbo back exhaust (straight pipe), airdog2 200gph, snow performance dual nozzle meth injection, fully built billet 47re, and a little bit of Nitrous
01dirtydzl is offline
The Following User Says Thank You to 01dirtydzl For This Useful Post:
thebullet83 (08-23-2012)
