Ball joints - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 02-16-2012, 04:01 AM Thread Starter
bigblue88's Avatar
Ball joints
So i was doing a check uup of the truck the other day and jacked up the front end on one side . When i placed a bar under the tire a lifted the tire did move up and down. I have been looking around and people are saying up and down movement is normal on the top ball joint, but how much is too much? Anything helps thanks.
01 4x4 6 speed manual with H.O motor
stock except for straight pipe
bigblue88 is offline
post #2 of 6 (permalink) Old 02-16-2012, 07:33 AM
Without looking in the service manual I think the spec is close to 1/8 inch.
Although some will tell you "any play is unacceptable". Unless the ball joints are new, I think that expectation is unrealistic.
His-2001 4x4 QC CTD HO
Hers- 2003 4x4 QC CTD HO
Project- 1965 Dodge Town Wagon
bigdav160 is offline
post #3 of 6 (permalink) Old 02-16-2012, 10:34 AM
Company Name
I've always gone by any play is unacceptable, my ball joints have about 30k on them and still have no play whatsoever. Plus when you work on customer vehicles for a living it's your a$$ getting fried when a component fails after it leaves your shop weeks prior.
nkfry is offline
post #4 of 6 (permalink) Old 02-16-2012, 11:41 AM
But if work at a dealer and replace ball joints under warranty, Dodge can audit you and charge the dealer back for replacing parts that are within tolerance.
I've seen techs fired for that.
post #5 of 6 (permalink) Old 02-18-2012, 07:47 PM
shotgunnar's Avatar
I think the tollerance is in the eye of the beholder.....My mechanic couldn't find any vertical play tollerance for the PA inspection. But the PA inspection only allows for minimal horizontal wear. Maybe 3/16
2001 2500 long box, silencer ring gone, BHAF. 227,000 on the ticker. Glock 21 security system
shotgunnar is offline
post #6 of 6 (permalink) Old 02-18-2012, 11:45 PM
DJK
Make sure its not your hubs either(if it is you will know pretty darn soon) After i did my ball joints and hubs i had no play at all.
02 1 Ton 4x4 5 spd 4" straight pipe,leveling kit,air dog 150, edge juice w/att.,175hp inj.HX35/S475 Compounds, valair DD clutch, ats manifold,ram air, gear vendors overdrive, D-lux fab free spin hub conversion,08 Honda CBR1000RR
DJK is offline
