Truck won't warm up.Is it my thermostat or do I need to replace my coolant? - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 12-01-2011, 03:26 PM Thread Starter
ROCKYTOPCUMMINS's Avatar
The truck is not overheating, it's just the opposite. I drive about an hour to work and some mornings when it's 35 or lower outside my truck will not come up off of 140 during the whole drive. On warmer days it will come up but never even makes it to 190, anybody have a clue what's going on? I just don't want to start throwing parts and money at it until I figure out what's actually going on.
2001 Dodge 2500/ 4x4/ 6spd ECLB
P-pumped South Bend DD#3850 hydros
AFE Brute Force intake/ Air Dog 150-150
ROCKYTOPCUMMINS is offline
post #2 of 26 (permalink) Old 12-01-2011, 03:33 PM
Would almost certainly be the thermostat. Mine did exactly the same thing a couple years ago. New thermostat-problem solved.
RR
'01 QC 2500 long bed, 3:54 auto w/Dunrite VB & LU switch, untapped Comp, Scan gauge II, Raptor lift pump, fuel pressure gauge and trans temp gauge.
Russ Roth is offline
post #3 of 26 (permalink) Old 12-01-2011, 05:27 PM
Powerwagon64's Avatar
iTrader Score: 4 reviews
Talking Thermostat
Likely the thermostat,
Mine did same thing, wouldnt warm up.
The rubber gasket around my thermostat was torn.
2001 ECLB, 4x4 Full On Suncoast, SXVP44, Blue FMS, Silencer Ring MIA, Banks 4" Power Elbow, 4" downpipe and 4" MBRP Duals 5" tips, FASS ip, BD low fuel indicator. In process of gathering upgrades to install tttriples!:
Powerwagon64 is offline
The Following User Says Thank You to Powerwagon64 For This Useful Post:
ROCKYTOPCUMMINS (12-02-2011)
post #4 of 26 (permalink) Old 12-01-2011, 05:49 PM
rhagfo's Avatar
Don't Cheap out either Cummins or NAPA Gold, I would also flush your system and change the coolant if not done recently.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 298K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #5 of 26 (permalink) Old 12-01-2011, 08:36 PM
ben
ben's Avatar
Thermostat stuck open?
99 2wd 2500 RCSB
ben is offline
post #6 of 26 (permalink) Old 12-01-2011, 10:45 PM
yep had the gasket in the thermostat too. It has to be the easiest thermostat I have ever put in. A 5/16 socket and 3 bolts it would be a great time to change coolant as you will lose some to replace the thermostat.
Brett
01 Dodge CTD 3/4 ton 4x4, auto, QCLB straight pipe, BHAF, Van Eekan V5 30 hp/60 hp, 200K miles,
yakdaddy42 is offline
post #7 of 26 (permalink) Old 12-01-2011, 11:18 PM
VP Moderator
dozer12216's Avatar
Take advice and use the NAPA part. It much cheaper and does not allow for as much temp flucation.
To completelly flush the system it is practical to remove water pump. That way you gea ALL the coolant out and can actually wash the water jacket out. Also the ONLY way to get the correct 6 gallon fill. Take heater hose off at head and flush with garden hose. When filling let coolant come up to open fitting and install hose. Now you got no traped air in system.
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
post #8 of 26 (permalink) Old 12-01-2011, 11:36 PM
TripleT's Avatar
get your stat from Napa because Cummins is on national backorder for them right now unless your local shop has one instock.
2000 Dodge Ram 2500 4x4 White Extended Cab, Garmonized 47RE Triple Disc TC, Smarty/ADR w/iQuad, 5" straight pipe to 6" tip, AFE stage 2 CAI, Amsoil Dual oil filtering kit, Boost Elbow, Raptor 150 fuel pump,On-board Air and Train Horn, 2" Leveling kit
TripleT is offline
The Following User Says Thank You to TripleT For This Useful Post:
post #9 of 26 (permalink) Old 12-02-2011, 08:28 PM Thread Starter
Thanks everybody. I'll search for it but in case I don't find it...anybody got a pic of where it's located in the engine bay?
post #10 of 26 (permalink) Old 12-02-2011, 11:13 PM Thread Starter
NAPA has a 180 and a 190 degree both for our engines. Anyone know which one it is?
NAPA AUTO PARTS
post #11 of 26 (permalink) Old 12-03-2011, 12:33 AM
rhagfo's Avatar
NAPA AUTO PARTS
Your Cummins wants to run at 190 part # 375190
rhagfo is offline
The Following User Says Thank You to rhagfo For This Useful Post:
ROCKYTOPCUMMINS (12-03-2011)
post #12 of 26 (permalink) Old 12-03-2011, 03:00 AM
That's the one, IMHO.
RR
