A/C stuck on defrost, any ideas? - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 09-06-2011, 07:23 PM Thread Starter
ROCKYTOPCUMMINS's Avatar
Just as the subject title says, my A/C is stuck on defrost. The fan speeds work fine and it blows fairly cold but it won't switch back and forth. Ya'll think it's the selector part or something in the dash? Any help anybody could give would be great. Thanks.
2001 Dodge 2500/ 4x4/ 6spd ECLB
P-pumped South Bend DD#3850 hydros
AFE Brute Force intake/ Air Dog 150-150
ROCKYTOPCUMMINS is offline
post #2 of 14 (permalink) Old 09-06-2011, 07:24 PM
Yes. It is a vacuum issue. Try the search and you will come up with more than enough info to fix the issue.
Scott91370 is offline
The Following User Says Thank You to Scott91370 For This Useful Post:
ROCKYTOPCUMMINS (09-07-2011)
post #3 of 14 (permalink) Old 09-06-2011, 10:48 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Yeap... Vacuum problem...
Mopar1973Man is offline
post #4 of 14 (permalink) Old 09-06-2011, 11:20 PM
There's a hard vacuum line that runs under the hood from the center of the cowl, fire wall next to the engine to the back of the vacuum pump. It can be knocked loose when working on the truck and cause this issue. ask me how I know.......
check to see if your cruise control works, if this line comes loose that will stop working as well.
2000, 2500 4X4 LB, smarty, Adrenalin 7X.095 injectors, 62-68/12 FMW, 4" exhaust, T steering, Allison 5 speed transmission, w/271 Transfer case, 19.5 wheels and tires, 3rd gen brakes, DT Radius Arms, Hamilton 188/208 cam, studs, 19.5-1 pistons, 53 block, Gone.
bwdt is offline
The Following User Says Thank You to bwdt For This Useful Post:
post #5 of 14 (permalink) Old 09-07-2011, 01:06 PM Thread Starter
Well now that you mention it...It still "works" but now when I set it, the speed will drop a little over 5MPH before it starts to work. I'll have to look into this.
For anyone else intersted.....Air only comes out of defrost vents
post #6 of 14 (permalink) Old 09-07-2011, 05:46 PM
The Nut Puncher's Avatar
Most likely a vacuum line either broken or loose. As stated check to see if your cruise control and 4wd engages. Both of these are run off vacuum as well. Mine was only working on defrost due to a broken hinge on the air box. It is located near the floor in the center of the dash. This is much less likely but a possibility.
The Nut Puncher is offline
post #7 of 14 (permalink) Old 09-07-2011, 07:43 PM
FRIENDS OF COAL
DieselDon16's Avatar
Also check the Switch, If you mean the AC/Heat wont work on anything but Defrost, it could possibly be the switch, that would be a "Gang Switch" If your looking at Schematics of the wiring for the switch it will be a Power Side Control circuit.
Hebrews 11:1
Now faith is confidence in what we hope for and assurance about what we do not see.
DieselDon16 is online now
post #8 of 14 (permalink) Old 09-08-2011, 08:15 AM
CGCampbell07's Avatar
i had this issue like 4 months ago its a vacuum line problem mine broke at a 90 right near the power assist
2015 Ram 2500 Auto 4x4 CCLB
2000 Dodge ram 2500 5spd, Airdog 150, 2wd with 353300 miles, 90hp injectors, and triple gauge pillar pod
CGCampbell07 is offline
post #9 of 14 (permalink) Old 09-08-2011, 02:48 PM Thread Starter
Well I don't know how it happened, but at the end of the line where it T's there's a little rubber nipple that caps the end of that plastic line, and that little nipple had rubbed on something and had a hole in it and that's what was causing the issue.
post #10 of 14 (permalink) Old 12-06-2011, 12:16 AM
Ttt
I have the same problem. I only get heat out of the defrost.
My 4wd works fine, my cruise works fine.
Any more ideas ? I took it to the shop, and they told me that the job cost's $750.00..... Because they have to remove the dash.
I don't have that kind of money.
Thanks
2001, 2500 4wd. 47RE/ Fass hpfp 95, Edge EZ. and the rest is bone stock.
jyenney is offline
post #11 of 14 (permalink) Old 12-06-2011, 05:45 PM
Dude_57's Avatar
yup most everytime that happens its a vaccuum issue very easy fix
Dude's Diesel Performance-Facebook
Dude_57 is offline
post #12 of 14 (permalink) Old 12-07-2011, 10:30 AM
Ok thanks,
I will keep looking
jyenney is offline
