Major Hydroboost problems - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 08-16-2011, 11:07 PM Thread Starter
New Mexico Chapter Vice President
mikeluna_17's Avatar
Ok so my hydroboost started leaking powersteering fluid. I ordered a kit from pirate jack with new seals. I pulled the hydroboost apart and put the two new seals on. I reinstalled the hydroboost. And now when i turn the steering wheel, the brake pedal pushes down all the way on its own! I cant drive the truck because as soon as i turn the wheel. the truck brakes on its own. i took it apart again to see what is wrong, i dont see anything wrong. please help
98.5 24 valve cummins QCLB.5spd Straight Pipe..HBS 2.5" leveling kit. 35"s No silencer ring.homemade CAI
mikeluna_17 is offline
post #2 of 11 (permalink) Old 08-17-2011, 12:03 AM
rhagfo's Avatar
Did you reconnect all the hoses to the correct ports to the Hydroboost unit? Connecting in the wrong ports may cause reverse action.
It is assumed that you bled the power steering and Hydroboost unit.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 298K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #3 of 11 (permalink) Old 08-17-2011, 08:52 AM Thread Starter
yeah i reconnected all the hoses the way they came off. and i bled the p/s and hydroboost twice. still happening
post #4 of 11 (permalink) Old 08-17-2011, 09:01 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
Did you get the linkage on the balance piston back into the slot? Its really hard to explain, but there is a little fork like piece that needs to get lined back up with the actuator rod and everything and that fork can come out REALLY easy. I think it'll cause that when you turn the wheel.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #5 of 11 (permalink) Old 08-17-2011, 09:13 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
I spoke with him as well... There is a hitch... He never removed the unit from the truck just split while hanging on the firewall. I've never open a hydroboost... So I'm not sure if there is something out of line or fell out of place since it was hanging on the firewall.
Mopar1973Man is offline
post #6 of 11 (permalink) Old 08-17-2011, 09:18 AM
Mike, were you the guy that was having problems with pumps blowing up about a month or two ago?
post #7 of 11 (permalink) Old 08-17-2011, 09:20 AM
Mopar1973Man.Com
Not me...
post #8 of 11 (permalink) Old 08-17-2011, 09:24 AM
whoops, wrong mike (to the OP)
post #9 of 11 (permalink) Old 08-17-2011, 11:35 AM Thread Starter
yeah i was the one having pump problems. and i decided to take the whole hydrobooster off. i made sure the fork was holding that rod when putting back together. everything went together smooth. i put it all back just about 30 minutes ago and its still doing the same exact thing. i dont get what the problem can be. i dont have any kinked or clogged lines. my power steering pump is working great. its just when i turn the wheel the brakes push in all the way. everything in the hydroboost went in smooth. nothing out of place. i triple checked everything
post #10 of 11 (permalink) Old 08-17-2011, 01:00 PM
Are the seals in it directional like if you put one in backwards it would let fluid in places it shouldn't be? I can't remember.
post #11 of 11 (permalink) Old 08-17-2011, 01:21 PM Thread Starter
i even put the old seals back on to see maybe if the new seals were making it act weird. still nothing.
