Electric Fan - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 07-07-2011, 12:22 PM Thread Starter
1998dsmtalon's Avatar
Electric Fan
I don't know about anyone else but paying $550+ for a fancy aluminum shroud with 2 fan in it doesn't really seem cost efficient to me.
Has anyone tried to put the biggest single fan in possible? Like a 16 inch slim fan. I cant see the one on the truck now flowing more then 2200cfms.
06 QCSB 1168 HP 1799 TQ, 9.83 @140 mph
NREPerformance
1998dsmtalon is offline
post #2 of 22 (permalink) Old 07-07-2011, 09:43 PM
mblondek's Avatar
the Flex a Lite fan is very good and is cost effective. i have it and love it. it keeps my truck a little bit cooler, and my EGTs are a lot less.
1985 crew cab 350 with 1992 cummins, twins, built auto
1993 w250 being restored twins, built auto, denny t, more to come, want 500hp.
mblondek is offline
post #3 of 22 (permalink) Old 07-07-2011, 10:22 PM Thread Starter
What size do you use?
NREPerformance
post #4 of 22 (permalink) Old 07-07-2011, 11:19 PM
01_Cummins_Sport's Avatar
ford taurus fans are a great addition. you can find them at almost every junk yard and they are a dual fan hi and low speed fan setup
01 Cummins Sport-Edge Comp Hot-Airdog 150-AFE Bladerunner-200s-Built Goerend-Fleece Custom HX35 Workstock Charger-Big Thanks To Drivelines Plus562HP/1254 SOLD!!
2008 EBP CC Sport 6.7-5" TBE,EFI LIVE BY Paul Cato,S&B, Joker Fab, Lowered
01_Cummins_Sport is offline
post #5 of 22 (permalink) Old 07-08-2011, 07:10 AM
rockrash's Avatar
There is not an electric fan made that will move the air of the factory clutch fan when it's fully engaged. You are flirting with disaster towing with an electric. Fan motor dies, overheat, blow a fuse, overheat, don't have enough shroud, overheat, tow heavy, overheat.
02 2500, auto,4" turbo back,puck,Gauges....... E7153 Airtex LP because I refuse to conform...201k+ and counting on original trans.
. It runs on oil so it tows stuff good.
rockrash is offline
post #6 of 22 (permalink) Old 07-08-2011, 08:45 AM
Merf_09's Avatar
This company makes electric fans & controllers for Semi's & heavy duty trucks they are pretty reasonable about $400 for a single fan & controller that is more than capable of cooling our Diesel trucks.
Electric Fan Engineering : Electric and Hydraulic Fans, Radiators, Charged Air Coolers, Heat Exchangers, Body Climate Control Systems
One Owner 2001 3500 Six Speed HO 24 Valve, Valair Clutch, DAP 50 HP Injectors, 4" Exhaust, TS MVP, ATS Intake Air Horn, FASS 95 GPH, Devils Own Water Methanol Injection 330,000 & still Growing
Merf_09 is offline
post #7 of 22 (permalink) Old 07-10-2011, 12:13 PM Thread Starter
$400!? I might as well buy the kit with the shroud and fans for our trucks!
Very true an electric fan wont out flow out a stock one and full lock. BUT! How often does the fan full lock? And with an electric fan that is constantly flowing the same amount I could like to think it can compensate.
Also, I dont tow heavy.
NREPerformance
post #8 of 22 (permalink) Old 07-11-2011, 12:51 AM
KATOOM's Avatar
There's no electric fan that can match the output of the OEM clutch fan which flows 10,000 CFM at 2000 RPM. Yes, there's guys who claim they can tow heavy with a mid-sized junk yard car electric fan cooling their Cummins but there's no way I'm trying that. Besides, the OEM clutch fan is very efficient because its basically doing nothing unless its needed.....and when its needed, its NEEDED. So to try and compare an electric fan that draws loads of juice from the electrical system, which is also a HP drain, to a clutch fan that only fully engages at 205* or more, is kinda silly. Not to mention you have to make sure the electric fan is running when the A/C or defrost is on otherwise you'll damage your A/C compressor. So while driving in the heat or rain your going to be running that electric fan all the time. Whats the gain in that?
KATOOM is offline
post #9 of 22 (permalink) Old 07-11-2011, 03:30 AM
JoeCanuck's Avatar
One gain for me in going electric is my truck warms up way quicker and stays significantly warmer in winter. At sub freezing temps, the fan clutch is locked up solid.
One of the reasons that dodge put such a high flowing fan in the truck is because the under hood aerodynamics are terrible. Air which should be flowing through the rad bypasses it over and to each side. Under bumper ram air also pressurizes under the hood preventing proper flow through the rad.
If the stock fan flows so well, how is it possible for puke bottle oil to get onto the back side of the fan? That's because no matter how strong a fan potentially is, it will not flow air to that potential unless there is proper sealing around the rad, (which there isn't on the stock trucks...not even close), and a constantly negative pressure differential behind the rad compared to in front of the rad.
The oil on the backside of every single second gen rad is proof that this mega powerful stock fan is not pulling anywhere near 10000cfm through the rad...regardless of its potential.
What is needed is to ensure a negative pressure differential behind the rad in relation to in front of the rad. That means preventing any ram air from bypassing the rad and limiting the amount of under bumper ram air pressurizing the engine compartment.
There are electric fans which easily push enough air through the rad to cool it under any condition...as long as the many shorfalls in the Dodge engine cooling air aerodynamics are dealt with.
As for trans cooling and a/c condenser activation; my trans temps never get above 200f on the hottest days and the fan kicking in at low speed is enough airflow to cool the condenser.
In the winter, I have a simple switch to disable the a/c fan activation.
'00 Quad Cummins 4x4 Shortbox, Was Silver. From AZ to AB. 50hp Edge Jammers, Adrenaline w/ Pulse, Raptor, Dodge Steering Stabilizer, Luke's Link, Leer tonneau, BFG T/A's, Isspro FPG, Transgo, FAILED DTT
billet single
, Excellent Diamond T Low Stall
JoeCanuck is offline
post #10 of 22 (permalink) Old 07-11-2011, 05:09 AM
rockrash's Avatar
Been there and done that with rock crawlers. Belt driven fan matches engine speeds and demands. There are applications that require an electric fan due to space constraints....but these aren't FWD mid size cars or corvettes.
these are tow vehicles. I can assure you that for efficiency and RELIABILITY you cannot beat the factory fan.
rockrash is offline
post #11 of 22 (permalink) Old 07-11-2011, 10:34 AM
cummingetme's Avatar
I've been running a single 17" electric fan now going on 4 years and have towed trailers to Oregon and California and back numerous times in all weather with not one problem(knock on wood).I have it thermostat controlled and wired to come on with my ac so if you get the right size fan and set it up right you should have no issues.
red qclb 2wd,3rd gens w/295 terra graps,built trans,airdog fuel,adrenaline,custom intake,5" out the back
aftermarket lights all around.
cummingetme is offline
post #12 of 22 (permalink) Old 07-12-2011, 02:17 AM
KATOOM's Avatar
This is surprisingly a debated topic. All I can say is that if Cummins felt that they could get away with an electric fan then I'm sure thats what they would have used. Especially with fuel mileage and emissions playing a major role in engine manufacturing issues. Or maybe the clutch fan is just that much better all the way around.
And under hood aerodynamics are an issue for ALL engine compartments.....not just the Cummins. For that matter, if any engine would have a good coefficient rating, it would be the Cummins. Its a long narrow engine with very little obstacles for air to bump into. Unlike other engine compartments with wide short engines which are so jam packed with stuff that it creates an issue trying to get any air coming in to exit. So I'm not buying the theory that the Cummins has a known issue regarding air getting out from under the hood. My truck is one of the only vehicles I know of where I can open the hood and easily see the ground below.
And the reason the fan and radiator gets covered with oily residue from the catch bottle is because it is moving so much air, not because its not. Sure a properly set fan in a sealed shroud with fluid edges and ducted outlets would flow far better but lets be real here..... I've been in some serious triple digit summer weather, with the A/C on full blast, pulling decent loads behind me in the steep mountainous roadways and I'm always surprised how well the engine temps maintain. If anyone can get an electric fan to sustain in the same situation then by all means. Maybe keeping the EGT's down plays more of a part than one would think since 1100* is about as hot as I like it to get.
KATOOM is offline
