How to change thermostat…... - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 06-05-2011, 07:14 PM Thread Starter
dcff's Avatar
I'd like to change my thermostat, any write up on how to go about this?
thank you
2001 Ram 2500 QCSB
Edge Juice w/ attitude hot, BHAF, S&B Intake manifold, MBRP 4,inch, Airdog 150, liberty fuel module, Built Trans, new VP$$
dcff is offline
post #2 of 7 (permalink) Old 06-05-2011, 07:38 PM
its right on top of your engine in front of and to right of the valve cover. follow your top radiator hose to the engine. remove the 2 bolts, remove th old tstat. install the new one and bolt it back up. be sure and use the new seal that come with the new tstat. all done.
2002 2500 QCLB HO 6 speed 4" exhaust turbo back banks e brake AD II 165 rv275 BHAF Edge Comp
dripley is offline
post #3 of 7 (permalink) Old 06-05-2011, 08:09 PM
rhagfo's Avatar
thank you
Only install a 190 T-stat and you should go with either a Cummins $$ or a NAPA Gold.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 296K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #4 of 7 (permalink) Old 06-05-2011, 09:10 PM
Hemi
iTrader Score: 5 reviews
mjd91 is offline
post #5 of 7 (permalink) Old 06-05-2011, 09:15 PM
DankCummins's Avatar
I run a 180* and it's fine. Either way your fine.
1993 RCLB
Denny T Fuel pin - 3200Gov - HX35 -
DankCummins is offline
post #6 of 7 (permalink) Old 06-05-2011, 09:28 PM
rhagfo's Avatar
You ECM will be constantly trying to get to 190, and over fueling your engine. Diesels like the warm. Try changing to a 190 and see it your mileage improves.
rhagfo is offline
post #7 of 7 (permalink) Old 06-05-2011, 09:31 PM
I read that and switched to a 190, no difference. Hand calculated.
I figure having a 180* when it's 100* here can't hurt. Let's it open up that much sooner and then when I shut it down it's not gonna keep heating up above 190*
1993 RCLB
The Following User Says Thank You to DankCummins For This Useful Post:
Novakane (11-06-2013)
