Hazard Flashers don't work - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 05-08-2011, 07:59 PM Thread Starter
2000 Ram 2500 Hazard flashers don't work. Turn signals and brake lights work unless I turn on the hazard flashers then no turn signals,brak lights or hazard lights what is wrong ? I only see one flasher relay in fuse panel is there one for the hazards? If so were?
Thanks
Boscodn73 is offline
post #2 of 12 (permalink) Old 05-08-2011, 11:30 PM
dieselpower270's Avatar
iTrader Score: 5 reviews
there is a flasher relay under the hood and there is a fuse in the cab. check those which it sounds like they still are good. it also might be the signal switch. try these but could be something else.
dieselpower270 is offline
post #3 of 12 (permalink) Old 05-08-2011, 11:57 PM
Marble Crusher
MarbleCrusher's Avatar
flasher relay and hazard relay are the same thing
-Jordan-
-02 Dodge 2500 cummins 4x4 6spd. Quadzilla XZT+, Volant CAI, road armor w/ lonestar guard front bumper line-x'd, Fass 95 , 3in lvl kit, bilstein shocks.
-68 F-100, grandad bought it new gave it to me when i was 16 been restoring bak to factory ever since.
MarbleCrusher is offline
post #4 of 12 (permalink) Old 05-10-2011, 10:25 AM
I have the same problem on my 1999 No Hazard but the turn and brake lights work.
morganwoody is offline
post #5 of 12 (permalink) Old 05-11-2011, 10:17 AM
BrwnDzel's Avatar
I am chasing this issue on a '99. If I find out anything I will post...please do the same cause as of right now
97 2wd/removed silencer ring/KDP done!/4" turbo back mufflerless/Autometer Boost & Trans Temp/Mag hytec dd Trans pan/Aluminum rear axle cover
BrwnDzel is offline
post #6 of 12 (permalink) Old 05-11-2011, 11:43 AM
Will do. I spent 20 bucks on a flasher and that did not help. Fuses check out with a meter. May try and replace them just to make sure.
post #7 of 12 (permalink) Old 05-11-2011, 09:32 PM
ShayetonKnake's Avatar
I had the same problem on my 99 there is two relays one under the hood and one in the cab next to the fuse panel i had a short and blew them out constantly so make sure u dont have a short
1999 Dodge ram 2500 Quad Cab 4X4 Auto[/B], Holset HE451VE Billet Wheel W/Fleece VGT controller, Lightning VP44,70HP Sticks,Edge JuiceWAttitude Level6UNL,Banghart Special Auto Trans with tripple disc converter billet input, Billet Flexplate,deep trans pan, Airdog 150GPH, K&N Intake,ATS T4 Exhaust Man,S&B Intake elbow, biggest cam without fly cutting pistons, Upgraded pushtubes and springs,Head ported all the way, 4inch Straight MBRP Duals, ARP 625 Head studs,fire ringed,12 valve rods, girdle kit,14mm main stud kit 17inch 3rd Gen rims with Mikey Thompson ATZ 315/70R17 [SIGPIC][/SIGPIC]
ShayetonKnake is offline
post #8 of 12 (permalink) Old 01-25-2012, 12:34 PM
Where was your short? I'm having this very probllem with mine.....
'99 2500 reg cab 4wd 5sp, smarty, F1 mach IV injectors, valair dual organic disc clutch, 53 block about to be converted to 55...more to come.
03 3500 qc 4wd auto, still in planning.
bmclemore82 is offline
post #9 of 12 (permalink) Old 02-17-2012, 06:23 AM
Flashers won't work
I have a 99 and a few days ago my emg. flashers just quit working---when turned on I have a fast blinking right turn signal in the cab, however nothing on the outside of the truck. I have replaced the interior 5 prong flasher unit, someone said there is one under the hood? I looked and didn't find a flasher unit?? I have all other lights-----just no emg. flasher----any idea's?????
Thanks
ONLYNAMRICA is offline
post #10 of 12 (permalink) Old 02-17-2012, 08:14 AM
may also be a bad ground
2001 2500 auto isspro fuel pressure, isspro turbo boost, isspro trans temp, MBRP 4" turbo back.
jordan2468 is offline
post #11 of 12 (permalink) Old 05-05-2012, 11:01 AM
im having the exact same problem on my 99 dodge. is there anyway to completely rewire the hazards? run them on a toggle switch? thanks
99 dodge 2500 4x4 reg cab 53 block (no prob yet) 156,000, no programmer, 4 in stainless exhaust, holey dash lol, and no hazards
zbkfarm is offline
post #12 of 12 (permalink) Old 05-05-2012, 11:44 AM
also when i push down on the flasher switch i can hear the click in the flasher relay. but its just a single click not continuous.
zbkfarm is offline
