Bilstein vs KYB Shocks - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 05-05-2011, 01:36 AM Thread Starter
dieselpowrd's Avatar
Im putting a leveling spacer on my truck and have heard its a good idea to install new shocks while its apart..Trying to decide between the bilstein 5100s and the kyb 'gas adjust"
The 5100s are made for trucks with a 2in lift in the front and I believe the KYBs are made for stock height so my question is does the longer bilstein shocks actually make a difference in this situation or would the KYBs work just fine?
If anyone has any experience with these any input would be much appreciated. My truck is a daily driver used mainly for highway so Im looking more for the best ride quality
Thanks for the help!
2001 Ram 2500 4x4, Fass lift, Edge juice Hot Unlock, Built Goerend tranny
dieselpowrd is offline
post #2 of 5 (permalink) Old 05-05-2011, 10:25 AM
dodge widowmaker's Avatar
iTrader Score: 7 reviews
I have bilsteins on both of my trucks and I love them. I think the bilsteins will ride a bit better than the KYBs
99 2500 Edge Comp, DTT trans, 100 stix, Boost, Trans, EGT, Fuel guages, Airdog 150, Green CAI, 5 inch
06 2500 Airdog 150, EFILIVE, AFE stage 2, Traction bars, SB DD, Dragon flow 50, 5 inch
dodge widowmaker is offline
The Following User Says Thank You to dodge widowmaker For This Useful Post:
dieselpowrd (05-05-2011)
post #3 of 5 (permalink) Old 05-05-2011, 10:36 AM
I have run both, and both are good shocks but the bilstiens are better, and with stock length shocks and a 2inch spacer, your right at the limit of travel, too big a bump will hyper extend the shock, and of course ruin it.
as a test after your leveling block is in, drop the shock i the hole, instal lower bolt, now instal upper shock tower, with the shock fully extended you can see or measure the distance between the lower part of the tower and the frame, you will be lucky to see 2inches of room, that will pretty much convince you to go with the longer shock
kyb does not improve the ride as much as bilestein does
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
The Following User Says Thank You to nickg For This Useful Post:
post #4 of 5 (permalink) Old 05-05-2011, 10:47 AM
cummminsV12's Avatar
Bilstein all the way..PS:my shocks were so rusted that I hat to cut em to remove em..botl was seized..even with a torch
01 ECSB SPORT-Quad4K,DTT Built47re/48RE inside,AD2-165,RADbox,PusherIntake,7x.012w/lift,Silver64,ARPStuds
cummminsV12 is offline
The Following User Says Thank You to cummminsV12 For This Useful Post:
post #5 of 5 (permalink) Old 05-05-2011, 02:51 PM Thread Starter
How do those bilsteins ride? I was worried that since there designed for off road theyd be rough going down the road
