Rpm gauge stop working - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 03-29-2011, 02:27 PM Thread Starter
1slowdodge's Avatar
The morning I'm driving my truck to work all of the sudden my check light comes on and my rpm gauge isn't working but speedo is. The rpm gauge started working about a min or two after that.My superchip said there was nothing wrong go figure. I've started the truck up a few more times since then and everything is working just fine. Any help would be great
99 2500 slt short bed 4x4 auto cold air intake superchip looking for 550hp dd tons more parts to come
1slowdodge is offline
post #2 of 7 (permalink) Old 03-29-2011, 02:36 PM
CGCampbell07's Avatar
did you do the key trick and did your brake lights go off as well??
2015 Ram 2500 Auto 4x4 CCLB
2000 Dodge ram 2500 5spd, Airdog 150, 2wd with 353300 miles, 90hp injectors, and triple gauge pillar pod
CGCampbell07 is offline
post #3 of 7 (permalink) Old 03-29-2011, 02:43 PM Thread Starter
1slowdodge's Avatar
didn't do the key trick didn't that work on the trucks. And I'm not sure about the brake lights going off. This has happen before but I just chalk it up to the superchip tuner
post #4 of 7 (permalink) Old 03-29-2011, 03:08 PM
i mean the abs light on the dash and brake light on dash...also the key trick does work but who knows if it pull a code or not.
post #5 of 7 (permalink) Old 03-29-2011, 03:10 PM Thread Starter
1slowdodge's Avatar
all those were off but the check engine light
post #6 of 7 (permalink) Old 03-29-2011, 06:37 PM
01cmsqdcab's Avatar
since you got a 99 im 99% sure its gonna be your crank sensor but you gotta pull that code to know for sure
2001 quad cab long bed 4x4, haisley machine sticks, ATS exhaust manifold, Raptor 150, 5 inch exhaust, quad adrenaline, glowshift gauges, leveled out, redline trans with big lines,
01cmsqdcab is offline
post #7 of 7 (permalink) Old 03-29-2011, 07:38 PM
cpubradley's Avatar
Just replaced my crankshaft sensor today - and that is what happened to mine, the RPM would come and go randomly... pulling the codes on mine showed that it was the crankshaft sensor, don't remember the code.
2000 Dodge Ram 2500 QCSB 2wd, RV275, PowerPuck, Boost Elbow & Fooler, Raptor 150, gauges.
cpubradley is offline
