heater wont get warm - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 01-03-2011, 11:23 AM Thread Starter
goodyg92's Avatar
i know there is probably another thread about this but i cant search it on the computer i am on,
my heater wont heat, after about 15 min of driving it will get a little warm and stay there but it never gets warm enough. any ideas of what might be causing this or what i could do to fix it because it shouldnt take that long, i live in texas and the coldest it has been here is mid 30's. any help would be appreciated.
CODY 01 4x4 drw qc 12v. 6spd valair DD, air dog, 160 pump, big valves, oring head, 4k gsk, 181dvs, 370 marine inj, studs, 20 over CR pistons , 188/220 hd cam, hd pushrods, beehive springs, billet wheel 63/68/14, 5inch, edg cts eas.
goodyg92 is offline
post #2 of 14 (permalink) Old 01-03-2011, 11:53 AM
Old_Sparky's Avatar
Is the truck at proper operating temp? If so, check the heater hoses under the hood and make sure both of them are warm. If only one is warm, use a garden hose to flush out your heater core.
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude, Airdog 100, K&N air filter, 17" rims, big brake upgrade (2004 version), 08.5 steering upgrade, CPP 125 hp injectors.
Old_Sparky is offline
post #3 of 14 (permalink) Old 01-03-2011, 12:03 PM Thread Starter
goodyg92's Avatar
yeah it takes maybe 2-3 min to get up to operating temp, but wont blow as warm as it should be.
goodyg92 is offline
post #4 of 14 (permalink) Old 01-03-2011, 12:13 PM
flagmanruss's Avatar
If It only blows on the defrost... it's the vacume controled selector on the drivers side... must pull dash back to access. Test first to see you have vacume on the manifold along the cowel. Common vacume faults are disconnected lines at transfer case or cruise control under the driver's side battery.
If it's just temperature, Possibly broken (stupid plastic) blend door coupling. These folks have a SS repair part & instructions for how (with determination the first time) to fix without pulling the dash. The blend door motor is located near the hump in the passengers foot well. Auto replacement part, blend door fix, Heat, AC replacement parts
Before you start, pull the blower... make sure it's not clogged with mouse nest. If so, clean it out. Keep mice out by stuffing the cowel drains (behind the hood hinges) with coarse steel wool... I used a hunk of SS pot scrubber. Water will still drain, no mice.
2001.5 Dodge Quadcab, 2500, 5.9, AD150, big line, 47RE auto, 4X4, 4.10, 265/75R16, 8800 GVW, TCW3 4"TBE, 36" FTE swirl resonator, straight through "muffler", IAT (mpg) fooler, XZT+. NRA LIFE MEMBER
flagmanruss is offline
post #5 of 14 (permalink) Old 01-03-2011, 02:59 PM
Powerwagon64's Avatar
iTrader Score: 4 reviews
Exclamation Thermostat
Mine did this to!
I replaced my thermostat, had a tear in the rubber gasket that surrounds it that was not letting the engine build heat as the coolant was continually circulating into the rad, cooling off.
2001 ECLB, 4x4 Full On Suncoast, SXVP44, Blue FMS, Silencer Ring MIA, Banks 4" Power Elbow, 4" downpipe and 4" MBRP Duals 5" tips, FASS ip, BD low fuel indicator. In process of gathering upgrades to install tttriples!:
Powerwagon64 is offline
post #6 of 14 (permalink) Old 01-03-2011, 03:02 PM
kellysap1989's Avatar
mine did the same thing, threw in a new thermostats = problem solved
2000 4x4 ATS 3000/5000, ATS 3-Piece Manifold, 6x016's, Southbend dualdisk, ARP studs, Smarty, TST Comp, 5" MBRP, Airdog, SO VP, 6 Speed
kellysap1989 is offline
post #7 of 14 (permalink) Old 01-03-2011, 03:08 PM
thermostat***
post #8 of 14 (permalink) Old 01-03-2011, 07:50 PM Thread Starter
goodyg92's Avatar
well it looks like im gonna have to throw in a new thermostat. thanks for the help yall.
goodyg92 is offline
post #9 of 14 (permalink) Old 01-03-2011, 10:08 PM
JacksonDog's Avatar
Same with mine. Replaced the t-stat yesterday and its night and day
99 2500 4x4 Laramie, Ranch Hand front,62/65/12, ADR/Pulse, MBRP 4" , BHAF, AD100, Isspro fp gauge, lvld, boost elbow, Relentless
billet w/ triple. CPP 200s, Tunnel Ram. Steering brace, dual stabilizer, heims, adj. tracbar. 1000 watts. Rhino'd rockers. Air Ride
JacksonDog is offline
post #10 of 14 (permalink) Old 01-11-2011, 12:14 PM Thread Starter
goodyg92's Avatar
well i replaced my t-stat yesterday with a stainless steel one that opens at 192 degrees, still wont even get warm, any other ideas, or should i just take it to a heat and a/c shop and have them figure it out...
goodyg92 is offline
post #11 of 14 (permalink) Old 01-11-2011, 02:09 PM
JoeCanuck's Avatar
It takes forever to get all the air out of the system. One thing that helps is to drive it around in a gear lower than normal, keeping the revs at 2000 or more for a while.
This seems to help push the air out of the heater system and into the rad, where it's easier for the cooling system to push it out and swap in coolant from the overflow.
By the way, the air is purged when the engine is hot, and it sucks from the overflow as the engine cools...not when it's running.
'00 Quad Cummins 4x4 Shortbox, Was Silver. From AZ to AB. 50hp Edge Jammers, Adrenaline w/ Pulse, Raptor, Dodge Steering Stabilizer, Luke's Link, Leer tonneau, BFG T/A's, Isspro FPG, Transgo, FAILED DTT
billet single
, Excellent Diamond T Low Stall
JoeCanuck is offline
post #12 of 14 (permalink) Old 01-11-2011, 03:47 PM
tjk82's Avatar
I would suggest back flushing your heater core before goin to a shop. I had this problem too, this was my cure.
99 3500 ECLB w/mods, all supporting mods, and some extra's
95 3500 Chassis cab 11' bed no mods, and blow-by
tjk82 is offline
