turn signal and hazard light trouble - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-02-2011, 09:31 PM Thread Starter
captainr0ck's Avatar
Hello, I have a stock 99 CTD 4wd auto. My turn signals stopped working out of no where yesterday. the hazards don't flash either. when the hazard button is pushed, the lights will turn on but not flash. when the turn signal switch is pressed nothing happens and there is no clicking sound. I have checked and tested the #4 20amp fuse under the hood as well as the #10 10amp fuse in the junction box and they both are ok. I replaced the blue square flasher relay with a new black one from advanced auto parts and there is no change. I have tested everything i can think of and am stumped.... ANY help is greatly appreciated.
captainr0ck is offline
post #2 of 12 (permalink) Old 01-03-2011, 02:20 AM
ram1500tr's Avatar
could be the switch system in the colum
new truck 2001 dodge ram 2500 extended cab long bed mild build auto trans. new vp pump edge comp drag box and hoping more to come soon
ram1500tr is offline
post #3 of 12 (permalink) Old 01-03-2011, 08:42 AM
stevesdiesel's Avatar
I had the exact same thing happen. In the engine compartment, in the fuse box there is a fuse for the hazards. I think it says hazards, I went to remove it and when I grabbed it the hazards started to work. It also controls the turn signals too. Mine is loose or something but I go it to work by moving it around. I'm going to fix it the right way when it gets a little warmer out. It might be a loose wire or something. good luck
2000, 4x4, 2500, quad cab, diesel, 5 speed, 4" exhaust, Airdog 150 . Stock height and tires. 114,000 miles @ 6-22-10. Good ol' work truck with a little rust that will be fixed this summer
stevesdiesel is offline
post #4 of 12 (permalink) Old 01-03-2011, 10:22 AM Thread Starter
Thanks guys. I'll try to test the switch in the column tonight. I haven't found any loose wires yet but I'm going to keep looking! Thanks
1999 Ram 2500 CTD 4x4 QCSB. White with black leather. Stock 47re auto. AFE Pro Dry S air filter. Silencer ring removed. Hypertech MaxEnergy tuner. Trans oil cooler, Fleetguard filters and coolant. 285/75/16 BFG AT's
post #5 of 12 (permalink) Old 01-07-2011, 10:31 AM Thread Starter
New switch and flasher, checked and tested all connections and fuses 3 times. Still no luck. Hazards turn on but don't flash. Nothing for turn signals... I'm lost
post #6 of 12 (permalink) Old 01-07-2011, 11:31 AM
are you using led bulbs? that would cause a regular flasher relay to do the same.
99 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch. am boost/pyro gauges, gs FP gauge, raptor 100, hypertech III. 53 block, (355k miles, still no cracks
)[knocks on wood
Dracozny is offline
post #7 of 12 (permalink) Old 01-07-2011, 01:16 PM Thread Starter
Using regular 9004 sylvania bulbs.
post #8 of 12 (permalink) Old 05-11-2011, 10:40 AM
Carothers's Avatar
Did you ever get this figured out? I caught the same problem this morning.
01 3500 Flatbed 2wd Dually - SOLD
02 2500 HO 6 SPD, guages, leveled on 33's, Raptor 100, Edge Comp, Edge BB turbo, E.D. 150's, Valair org/ceramic single, BHAF, 5" TBE
Carothers is offline
post #9 of 12 (permalink) Old 05-11-2011, 09:38 PM
ShayetonKnake's Avatar
theres a flasher relay in the cab to check that one thats what it was in my 99 if the relay is good then you have a short like i did mine was on the front drivers side along the bumper and mine wouldnt flash and just stay on until the relay blew give that a try
1999 Dodge ram 2500 Quad Cab 4X4 Auto[/B], Holset HE451VE Billet Wheel W/Fleece VGT controller, Lightning VP44,70HP Sticks,Edge JuiceWAttitude Level6UNL,Banghart Special Auto Trans with tripple disc converter billet input, Billet Flexplate,deep trans pan, Airdog 150GPH, K&N Intake,ATS T4 Exhaust Man,S&B Intake elbow, biggest cam without fly cutting pistons, Upgraded pushtubes and springs,Head ported all the way, 4inch Straight MBRP Duals, ARP 625 Head studs,fire ringed,12 valve rods, girdle kit,14mm main stud kit 17inch 3rd Gen rims with Mikey Thompson ATZ 315/70R17 [SIGPIC][/SIGPIC]
ShayetonKnake is offline
The Following User Says Thank You to ShayetonKnake For This Useful Post:
Ragnar5823 (06-14-2011)
post #10 of 12 (permalink) Old 05-12-2011, 09:19 AM
Carothers's Avatar
Got it figured. #4 fuse under the hood. It looked good from the top.
post #11 of 12 (permalink) Old 05-12-2011, 11:57 PM
dieselpower270's Avatar
iTrader Score: 5 reviews
I have heard that the flashers and turn signals hook into your lights somehow and something there could have gone wrong. So I guess what you donut take off the switch panel and test all those wires?
2005 5.9 600hp SOLD
2007.5 6.7 built auto deleted, 5" turbo back, intake, Fuel rail plug, 8" lift, 22x14
dieselpower270 is offline
post #12 of 12 (permalink) Old 05-13-2011, 01:53 AM
99CTD Dually's Avatar
are there not flashed only on 1 side or both,could be burned out bulb. that is my 2c, hope it help
99 24V 4x4dually, auto, 152k,dual pillar gauge. Suncoast torque converter and triple disk,TC Lock-Up Switch, MagHytec Trans Pan&rear diff, Edge Comp, Air-raid, 5" system,Tunnel Ram,ADII-165,BD valve body,ScangaugeII,2" dually spacer with 265/75/16
99CTD Dually is offline
