Old 09-14-2007, 03:07 PM   #1 (permalink)
WhiteLightning334's Avatar
need help fast
My abs light has just come on, and I am thinking it is the abs pump but im not sure please help
I have a 2000 dodge 3500 with a 24valve cummins I already have a straight pipe on it. But I want more out of my truck
WhiteLightning334 is offline   Reply With Quote
Old 09-14-2007, 04:29 PM   #2 (permalink)
Twin Port Sales, Authorized Amsoil Dealer
Duluth Diesel's Avatar
Ah, mine does that once in a while. The wheel speed sensors tend to be sensitive to moisture. My ABS light goes nuts for a day or so after I go nail snow drifts for fun. I usually just drive it for a few days and once the sensor dries out, the light goes off. You can also see if any codes have been tripped by cycling your ignition key on and off 3 times with the engine off, stopping the cycles with the key in the ON position. Then watch the odometer, have a pen handy and write down all the codes that flash by.
-Chuck
Duluth Diesel is offline   Reply With Quote
Old 09-14-2007, 04:47 PM   #3 (permalink)
Shibbyutman's Avatar
ABS light only indicates that the abs wont work, base brake function will be fine, I work for the company that made it, PM me if you have any specific questions.
2003 Dodge Ram 2500 4X4, Banks Big Hoss Bundle, K&N FIPK, 5" Turbo back Expand-It exhaust, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit.ABS Brake Specialist-You've got questions, I've got answers.
Shibbyutman is offline   Reply With Quote
Old 09-14-2007, 05:44 PM   #4 (permalink)
yeah I know that. But I need to know what may cause the abs to shut down
Old 09-14-2007, 05:54 PM   #5 (permalink)
01cummins's Avatar
i got the same prob. i just live with it
01 3500 6" single stack, Goerend trans, powerpuck, FASS, and the new vp at 147,000 (soon set of rv275, comp or juice with add.)
01cummins is offline   Reply With Quote
Old 09-14-2007, 06:00 PM   #6 (permalink)
Ok if you dont want to just live with it, the two main problems are easily fixed. It is going to be EITHER the wheel speed sensor, or the lead that runs to the wheel speed sensor. The best way to test the wheel speed sensor, is to unplug it and ohm out the two terminals that are in the connector. Most of the time the little windings that are in the head of the sensor burn through from high temps in the fluid and just the current running through it. If you get an O.L. or open link on your meter your sensor is bad, just replace it i think they are like 30 bucks or something. If there is resistance in the sensor then most likely the lead is bad and you need to give the wires a little tug to check for any breaks or corrosion. The lead is a dealer item only I believe but it is also pretty cheap like 50 bucks or something. Try that and post back with how it goes.
Old 09-15-2007, 05:56 AM   #7 (permalink)
2manyhorses's Avatar
My abs light stayed on for months , then I decided to quit buying pucks and other mos and fix the real problems . ( priority issues ). The old sensor was so brille that removing it was like pulling a rotten tooth.Took me an hour to dig all the little pieces out. Jack your truck up and have somebody turn the wheels wjile you check the star wheel for damage. Make sure you clean out the hole really good or you could damage the new oring when you put it back in.Its a 15 min job if your third member isnt rusty and dirty.
Helga Von Pullenschtrong
2002 4x4 QC HO BHAF&OW,straight ex. Silencer ring MIA.ISSPRO FP,TB,Pyro . 285/75/16 Buckshot Mudders:
2manyhorses is offline   Reply With Quote
Old 09-16-2007, 11:24 PM   #8 (permalink)
KATOOM's Avatar
Some truck have ABS sensors on the front hubs also. If you have wires coming from the front hubs then so do you. I think everyone has the one on the rear pumkin.
'01 2500 Sport 4x4 5spd, EZ, straight piped, no sillencer ring, aFe, 2 lo kit, Dakota FP/Isspro Boost and EGT all on pillar, Pac Brake, 285's
KATOOM is offline   Reply With Quote
Old 09-17-2007, 06:14 AM   #9 (permalink)
Yeah, think that some trucks had a 3 channel abs similar to the third gen trucks. The sensors in the front hub are a different model, much less prone to crapping out at the worst time.
Old 09-18-2007, 06:10 PM   #10 (permalink)
yeah I have that setup. But it was the rear speed sensor.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
