Grinding/Roaring Noise going around curves to the right? - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 05-11-2010, 02:54 PM Thread Starter
Here lately I have noticed a grinding noise coming from my front end when I go around curves to the right. It wont do it going to the left though. Is my driver side wheel bearing going out? Also it only does it at road speeds not when I am going slow. Any ideas?
2017 C&C 3500 SLT Aisin DRW 4x4
awoods9520 is offline
post #2 of 17 (permalink) Old 05-11-2010, 04:27 PM
rattlebox01's Avatar
That would also be my guess. Wheel bearings. Won't take but just a second to check it and find out.
2001.5 2500 4x4, 47re, 241 DHD, HX-35 swap, XZT+, Raptor LP, Hi-Flow Banjo Bolts, 4" Diamond Eye, BHAF, 3rd gen alloys, TC lockup switch
rattlebox01 is offline
post #3 of 17 (permalink) Old 05-11-2010, 08:36 PM Thread Starter
Well I just checked the bearing and and everything on the front end with it in the air and I cannot find any play anywhere My front driveshaft is spinning freely with the truck in 2wd, so I dont think that could be causing any racket. I also noticed that at about 70-75 I get a whoom whoom whoom kind of sound. Could that be part of the grinding in the curves?
post #4 of 17 (permalink) Old 05-11-2010, 08:44 PM
billow99's Avatar
wheel bearing id say. pain in the butt for our years. did mine while i did ball joints
99 2500,G56....
billow99 is offline
post #5 of 17 (permalink) Old 05-11-2010, 08:57 PM Thread Starter
Wouldn't the hub be loose if the wheel bearing was loose?
post #6 of 17 (permalink) Old 05-11-2010, 09:14 PM
could still be tight, but the bearing is dry, causing the noise when its loaded, it will likely fail very quickly and without much warning, bearing load occurs to the wheel on the outside of the turn, as weight is transfered to that side of the truck. so if noise occurs turning right the left bearing would be suspect.
I would order parts and pull it apart on your terms, not when it decides to fail. you can remove the bearing and pop the seal off, and note the condition of the bearings, my guess is it will be rusty and dry
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #7 of 17 (permalink) Old 05-11-2010, 09:39 PM Thread Starter
Can I inject some grease through the seal for a little more life? I have the hub/bearing assembly off as we speak and it does sound a little dry. If I can just do something while its off to help get me by.
post #8 of 17 (permalink) Old 05-11-2010, 10:23 PM
Does your bearing have a wheel sensor on top of it. I changed out one of my axle joints. When i spun my bearning it sounded dry so i dumped some 80w90 oil down the sensor hole. I had to constently turn the bearning so the oil would go down in. It was a slow process but ive ben driving about 15000 miles with same bearning and no troubles yet
bigcamcummins444 is offline
post #9 of 17 (permalink) Old 05-11-2010, 10:29 PM Thread Starter
No, it doesn't have sensor on it unfortunately.
post #10 of 17 (permalink) Old 05-11-2010, 10:43 PM
sorry some have the abs sensor and some dont. One good thing they are a lot cheeper without sensor. If it was me I would try to squirt some gear oil or grease through the seal with a sirenge. But im not familer with how thick, or tight the seal is off hand. 2001 dodge ram 2500 4x4 stock with 190,000 miles
post #11 of 17 (permalink) Old 05-11-2010, 10:47 PM Thread Starter
Well I drilled a tiny hole in the side of the seal and I have been injecting grease into it for twenty minutes now. I dont know how much of it is actually getting into the bearing itself though.
post #12 of 17 (permalink) Old 05-11-2010, 11:07 PM
ag cummins's Avatar
Great temp idea! Sounds like yur on the right track. Went though both of mine a couple of years ago w/ brakes and u joints gets expensive quick. Hope it works for you.
00'4x4QCSB,Sport,NV4500,4.10s,SB Hydros,Luk SD,Killer.63/65/14,Tunnel Ram,CFM+,BHAF,5" Exhaust,ARP425s,Raptor150,DAP160hp sticks ,CompHot,ProComp gauges,Leveling kit,Farm built ladder bars,Borgeson shaft and gearbox,Trac bar kit,Steering brace,35s.
ag cummins is offline
