Fuel Sending Unit - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 05-05-2010, 06:59 PM Thread Starter
Fuel Sending Unit
Does anyone know the part number for the fuel sender for the truck in my sig? I ordered one that was for a 01 that the part number was in the fourm from another user but it is different than the one in my truck. It did not have the intank fuel pump.
1999 2500 quad cab, 5spd, edge juice with attitude, smarty ,aem intake, airdog 150(Thanks to jkidd and the fast shipping ), dreaded 53 block 181,000km`s no cracks and high idle
bomb, rear 4 link with full fbss air ride
98 Freightliner 5.9L cummins, rollback tow truck stock except for ddp50 and boost fooler
06 2500 5.9l stock except smarty s-06,insight cts and straight piped
canntfly is offline
post #2 of 26 (permalink) Old 05-05-2010, 09:06 PM
pepsi71ocean's Avatar
go to the dealership and then have them look up your truck, and then ask for the fuel sending unit, and then tell them you want the predicessor, not the revised one, if the guy doesn't understand tel him its pre pumped,
i will look up the part number, as i have it in my paerwork somewhere.
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
The Following 2 Users Say Thank You to pepsi71ocean For This Useful Post:
canntfly (05-06-2010), LeadSSled (05-05-2010)
post #3 of 26 (permalink) Old 05-05-2010, 10:41 PM
I would like that part number too, please.
2001 Dodge Ram 2500 4X4 Quad Cab 5-speed CTD:
Icebox Cold Air Intake w/Amsoil Nano filter, Farmboys Diesel 5" Budget exhaust with flow-thru muffler, FASS 95, Edge Juice with Attitude, South Bend ConOFE 13" clutch.
It's a mule to pull my SSLED to racing events.
LeadSSled is offline
post #4 of 26 (permalink) Old 05-06-2010, 04:30 PM
Canntfly: if this is the [art number you have then let me know.
This is what i dug up.
Part number is 4897670AB
When asked it is the sending unit without the "fuel pump module" inside.
It should be about 500 bucks.
Please note that if you are running an aftermarket lift pump ie FASS Airdog, or one that has filters on it i would recommend cutting out the screen on the bottom of the unit, and also drilling the bottom suction hole. Doing so should reduce most of the pressure restrictions.
They ROCK!
post #5 of 26 (permalink) Old 05-06-2010, 05:55 PM Thread Starter
That cann`t be the right part number as that is the one that I ordered and it is different
canntfly is offline
post #6 of 26 (permalink) Old 05-06-2010, 08:46 PM
ok, let me check around my office for some other numbers.
They ROCK!
post #7 of 26 (permalink) Old 05-06-2010, 08:51 PM
i had the same problem i havent purchased it but i was told you could get it from moparparts.com for cheaper than the dealer. p/n 4797738
01 Dodge Cummins laramie SLT, qc, 4x4, short bed, auto, 3.55's, raptor 150,big line kit, Hellman sump ,BHAF,isspro fp gauge,35 bfg m/t,hbs level, silencer ring mia
socaldiesel is offline
post #8 of 26 (permalink) Old 05-06-2010, 09:00 PM
Mopar parts has the unit listed, but they are a dealer specifi part.
I know what your looking at its this page here
Dodge Ram 1500 Parts - The Official Mopar Parts eStore offered by Chrysler
Its under section 1, on that page, and its the last one, problem is they list the unit with the tank in it, but that is NOT what the picture is.
What you want is the shiny white fuel tank moduole on the left, it does not have the pump in it.
Apparently part number 4897670AB is the sending unit, which is the right part, but its not the module which you need.
They ROCK!
post #9 of 26 (permalink) Old 05-06-2010, 09:34 PM
Give me some time, i have a boat load of part number that i have listed for when they break/die on my truck, i'll find that sucker.
They ROCK!
post #10 of 26 (permalink) Old 05-20-2010, 02:10 PM
Guys i found the recipt from the Dodge Dealer from October and it lists the number of
4897668-AF Module KIT 14067004
It says list is 522.50 net 475.
i called the dealership and they said that the parts kit, make sure you tell them that you went aftermarket frame rail mounted lift pump and that it REQUIRES the Oem pumpless sending unit. itherwise they will tell you you can only get the one with a pump in it which by the way is the same part number but has a different revision on the end, go figure.
They ROCK!
LeadSSled (05-20-2010), pbmw (06-20-2010)
post #11 of 26 (permalink) Old 05-21-2010, 09:45 AM Thread Starter
I just got the sender in and it was just the sender for just over 80.00 CDN with taxes. The part number is 1-04897669AB and it is the right one for my truck but it was stated that it is for a 2000,01, 02 and mine is a 99.
canntfly is offline
The Following User Says Thank You to canntfly For This Useful Post:
LeadSSled (05-21-2010)
post #12 of 26 (permalink) Old 05-21-2010, 09:59 AM
Thank you for the part number. I'm struggling to picture what "just the sender" looks like. You didn't happen to take a photo before your install, did you?
Where is it in this photo?
