CD Player and Dome Lights quit working. - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 03-19-2010, 12:48 AM Thread Starter
99DodgeCummins's Avatar
I don't have power to my cd player and my dome lights inside my cab doesn't work anymore. I took out the light under the hood that is connected to the hood and that stuff quit working so i reconnected to see if that would fix the problem and it didn't fix it. What could it be?
99, 5 Speed, SouthBend Dual Disc, 1 3/8 Shaft, F.A.S.S. 150/150, 150 Scheid Injects, Edge Drag Box/Smarty Stacked, 4" down pipe, 5" exhaust, ARP Head Studs, Ladder Bars, Safety Loops Front and Rear, weight rack, 2" leveling Kit, FP, Boost, Pyro Gauges
99DodgeCummins is offline
post #2 of 14 (permalink) Old 03-19-2010, 01:52 AM
carson b's Avatar
check for blown fuses use a test light dont just look at them
2001 dodge 3/4 ton 6 speed 4x4
4 inch bd exhaust with engine brake
edge juice computer and bd cold air intake
carson b is offline
post #3 of 14 (permalink) Old 03-19-2010, 03:01 AM
cumminsnut69's Avatar
there is a power wire that supplies power to the cd player, dome lights, rear cab (just the cargo lamp) and power mirrors. if you changed the player without the battery dico'd then there is a chance you may have shorted that wire (this happens on my 00' 1/2 ton). it runs from the fuse block (under hood) through the back of the instrument cluster into a splitter for all above mentioned sources. its a massive pain but check those things also, if you lost those that may be your problem. i ended up running a wire from my in cab fuse block (using an extra port) to the distribution block then eveything worked again, good luck. use a multi-meter to check the wires
2007 5.9lcr 4x4. 48re w/ bd valve body, Raybestos bands, Alto clutches, BW gov sol, & billet struts sonnax servo/accumulator and suncoast triple tq. also muffler delete, an Edge w/attitude, Revtek leveling kit, and home made headache rack.
cumminsnut69 is offline
post #4 of 14 (permalink) Old 03-19-2010, 01:09 PM Thread Starter
alright thanks that helps out alot.
post #5 of 14 (permalink) Old 03-19-2010, 01:25 PM
countrymanlife's Avatar
i lost these on my old 1500. check your fuses. Mainly in cab fuses the ones under the black covers (they can be overlooked when you are in there)
'02 2500 4x4 Quad Cab Auto - BHAF, Straight Pipe, 35x12.5r17 BFG KM2s, XD Hoss 17"s, 6" Franka-lift, DTT Tracbar, '98 HD steering, EMS Manual Hubs, PSC Gearbox, DSS Stabilizer, NFAB stepbars, and much more to come... Gotta Pay to Play
countrymanlife is offline
post #6 of 14 (permalink) Old 03-20-2010, 04:29 PM
mopar-or-no-car's Avatar
Its the i.o.d. fuse
01.5 Ram 2500 4x4 5.9 DTT auto, quadcab, long box, ez/pm3, hx35, bd exhaust brake, bd towloc, sport lights, kool vue's, toyo's, fass, isspros, piaa'ss, daystar leveling kit, 4" magnaflow tbe SOLD
mopar-or-no-car is offline
post #7 of 14 (permalink) Old 03-20-2010, 05:27 PM
mrclean's Avatar
Originally Posted by mopar-or-no-car View Post
Its the i.o.d. fuse
As Mopar said......IOD fuse. Should be #12 in the fuse panel on the side of the dash.
'99 3500, QC, 5-spd, FASS, PacBrake, van Aaken Smartbox
mrclean is offline
post #8 of 14 (permalink) Old 03-20-2010, 05:56 PM
Mingle's Avatar
IOD fuse. 10Amp. It's the one with the big black cover around it, just pop it open and pull it out. Bet that's it :P
'99 2500 24V. Auto. AD100. Quadzilla Adrenaline, 4" turbo back (straight piped), BD-Power HPVP44, BD Stealth Plate, Boost Elbow. Built Trans.
Mingle is offline
post #9 of 14 (permalink) Old 03-20-2010, 07:54 PM
Dwalker.98Cummins's Avatar
My truck did the same thing an no my battery wasn't dissconected when i was trying to put an aftermarket cd player in it.... so what is the easiest way to correct the problem?
98.5 24v 2500 5 spd. 4x4 Ext. Cab. Laramie SLT long bed straight 4" exhaust. Superchip max micro tuner.. NON 53 BLOCK hah
Dwalker.98Cummins is offline
post #10 of 14 (permalink) Old 03-23-2010, 04:39 AM
you need to pull the dash apart the distribution block is mounted to the back of the housing where the instrument cluster mounts, but you cant get to it throught the cluster housing, unfortunetly you have to go in under the dash. you can either pull the power supply wire (once you find it; mine where all white) out of the bundle all the way to the block under the hood or just use an empty spot in you in dash fuse block and run a "hot" wire up to the distribution block. this is a massive pain it fustrated me for days after checking all the fuses and relays i found i had shorted the wire and burned the prong at the source.
post #11 of 14 (permalink) Old 03-23-2010, 02:03 PM
I have a similar problem with my 99 2500, but it's only the cd player. I don't want to thread Jack you but I didn't want people saying that I should of posted in this thread either. My problem is that the radio and everything works normal BUT the cd player. I have the stock Premium speaker package (infinity I think) and the cd player stopped working one day in the stock head unit. I replaced the stock head unit with an after market head unit and it still doesn work. The wierd part is, is that both the stock and aftermarket head units function completely (especially cd player) in my friends 2500.
'99 2500 5speed 2001 engine swap, hx-40, AD150, Edge Comp, Jammer Stg 5 sticks, 4" turbo back stack, HID halo's, 2" leveling kit, 35's, AEM Intake, pillars, plenty of more done and more to come....
____Kurt____ is offline
post #12 of 14 (permalink) Old 03-24-2010, 03:03 AM
oh just to let yall no all i had to do was replace my I.O.D. fuse. it had blown. just put a new one in an was good to go....
Later
Doug
