dodge ram curb weight - Dodge Cummins Diesel Forum
post #1 of 31 (permalink) Old 01-30-2010, 01:48 PM Thread Starter
Anyone know what the curb weight would be on a stock 98 dodge ram 2500 quad cab long bed with a 24 valve cummins?
Im having a hard time finding it on the net.
Rather be cummin' then strokin'
98 3/4 ton 4x4 24 valve turbo cummins K&N Air filter, 6" stacks cab high, glowshift guages and an Airdog 150 lift pump. Other then that.....Im a stocker!!
Pri_i_oh is offline
post #2 of 31 (permalink) Old 01-30-2010, 03:25 PM
Old_Sparky's Avatar
My came in at 7200 lbs with me in the seat.
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude, Airdog 100, K&N air filter, 17" rims, big brake upgrade (2004 version), 08.5 steering upgrade, CPP 125 hp injectors.
Old_Sparky is offline
The Following User Says Thank You to Old_Sparky For This Useful Post:
Pri_i_oh (01-30-2010)
post #3 of 31 (permalink) Old 01-30-2010, 03:30 PM
Jdwcummins's Avatar
mine was 7300 with a tool box and tools
01' making 500hp going for 700
08' Mega stock for now
Jdwcummins is offline
The Following User Says Thank You to Jdwcummins For This Useful Post:
post #4 of 31 (permalink) Old 01-30-2010, 03:33 PM Thread Starter
ok, I figured it was about that but me father in law who knows EVEYRTHING about diesel trucks said it cant weigh much more then my 1/2 ton....i tol dhim that wasnt even logical...lol
Pri_i_oh is offline
post #5 of 31 (permalink) Old 01-30-2010, 05:34 PM
rockrash's Avatar
My 02, 2wd, quad cab rolls across the scales at 6,200 lbs.
Two different scales, same weight. Add 200 for your 2' of bed. Add 1,000 for 4wd.
02 2500, auto,4" turbo back,puck,Gauges....... E7153 Airtex LP because I refuse to conform...201k+ and counting on original trans.
. It runs on oil so it tows stuff good.
rockrash is offline
The Following User Says Thank You to rockrash For This Useful Post:
post #6 of 31 (permalink) Old 01-30-2010, 08:39 PM
BigHemi04's Avatar
iTrader Score: 5 reviews
yeah, diesels way quite a bit more
06 QCLB 4x4 Lifted Auto, 06 QCSB 4x4 Lifted Auto, 95 RCSB 4x4 Auto 'Race Only', 77 Crew RampTruck 12v 6-Spd, 08 F450 CTD Swap
BigHemi04 is offline
The Following User Says Thank You to BigHemi04 For This Useful Post:
post #7 of 31 (permalink) Old 01-30-2010, 10:38 PM
AK-DRam's Avatar
7400 with leer shell & me
2001 - 2500 4X4, 6 speed HO, EDGE juice/attitude, strait pipe, BHAF, LUK clutch, level kit, DDP 75 sticks and CFM air horn, 4 inch dual exhaust, Banks exhaust brake and feed by an AirdogII. 
AK-DRam is offline
The Following User Says Thank You to AK-DRam For This Useful Post:
post #8 of 31 (permalink) Old 01-30-2010, 11:05 PM
BigHemi04's Avatar
as per dodge ram info.com
Ram 2500 Quad Cab Long Bed 4x4 w 3.55 or 4.10 Gears:
W/Auto
Curb weight - 6568
W/5 Speed
Curb weight - 6615
W/6 Speed
Curb weight - 6787
Pri_i_oh (01-31-2010)
post #9 of 31 (permalink) Old 01-30-2010, 11:07 PM Thread Starter
well, even my short bed 4x4 quad cab 1/2 ton weighs 5200 so I KNEW it had to be more. Thanks for proving me right...lol
I may not be the mostest brilliantest person in the whole world but golly gee i sure do have a little bit of common sense...lol
Pri_i_oh is offline
post #10 of 31 (permalink) Old 01-30-2010, 11:09 PM
BigHemi04's Avatar
FYI, this website has a ton of info and specs, pretty much all you need to know about a stock ram, check it out...
Dodge Ram Information
Or Diesel...
http://dodgeram.org/
post #11 of 31 (permalink) Old 01-30-2010, 11:35 PM Thread Starter
you guys sure have alot of info. i appreciate it alot guys.
Pri_i_oh is offline
post #12 of 31 (permalink) Old 01-30-2010, 11:37 PM
BigHemi04's Avatar
yep
