power steering fluid foaming out - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 01-16-2010, 04:25 PM Thread Starter
yoshi470's Avatar
Well i just pulled my truck in our shop and say that there is power steering fluid foaming out of the resivor. It has been making moaning and groaning noises lately as its been cold. it also does it when i hit the brakes. I've heard that they are both run off the hydrobooster? I think thats what i read, not really to sure what that even is....but some say to replace that and it will fix the problem. Others say to just flush the power steering fluid and put some new synthetic fluid in. How do you go about doing that..never really done much work with power steering components so bear with me here. Will i have to rebleed the system? Please help me out here guys
2012 Dodge Ram 2500 Laramie Longhorn
H&S XRT Pro, MBRP 4" TB Exhaust, More to come!
yoshi470 is offline
post #2 of 14 (permalink) Old 01-16-2010, 09:22 PM
Boiler up!
SootKing's Avatar
id like to know some stuff about it too...
2004 Cadillac CTS-V, black, maganaflow exhaust, 40k miles
SootKing is offline
post #3 of 14 (permalink) Old 01-16-2010, 09:54 PM
sledwrecker's Avatar
I always do the cheapest and easiest first. Suck as much of the ps fluid out as possible with a suction gun or turkey baster, then just refill with a quality synthetic and run it. I would do this 3-4 times to get as much of the old out as possible. Good luck.
00 SWB, Quad, Auto, 2wd, BHAF, FASS 95, Juice WAM, 4" Diamond Eye Strait,Smarty,3cyl/hi idle box.
98 RC 3500 4x4, 12 valve,DDP 75's,4k gsk,ARP studs,NV4500 with South bend 1 3/8" input shaft and OFE Con single disk,flatbed. 4" Diamond Eye Strait,BHAF.
sledwrecker is offline
post #4 of 14 (permalink) Old 01-16-2010, 10:47 PM
the turkey baster works too. but dont forget to start the motor and turn the wheel and pump the brakes, to circulate the oil.
2001 cummins automatic 2500 x-tended cab , airdog 150, edge juice/w/attitude , mbrp 4'' need more
to keep going
wontgoslo is offline
post #5 of 14 (permalink) Old 01-17-2010, 12:40 PM Thread Starter
yoshi470's Avatar
ok sounds like im gonna try and flush the system out and put new fluid in....anything else i should check?
yoshi470 is offline
post #6 of 14 (permalink) Old 01-17-2010, 11:13 PM
jroyster06's Avatar
I ended up having to replace my powersteering pump
vrooooommmm
jroyster06 is offline
post #7 of 14 (permalink) Old 01-17-2010, 11:51 PM
If its puking oil out of the PS its NOT going to be a bad powersteering pump. if its puking out the oil, first replace with good syn oil, and if it still does it its the hydroboost thats at fault (the acculimator is dumping its extra stored fluid backinto the PS resivor, causing it to overflow) you can only get a few oz at a time out of the resivor so it will take a couple flush/fills to edventually replace the fluid, if I remember correctly 1quart of fluid will fill the resivor 4 times, so suck empty top up, run engine pump brakes/turn steering, and repeat the cycle again until you have used up all the fluid
hydroboost is found directly behind the Master cyl, it can be replaced in 15mins or less, IF you dont unhook the MC brake lines, just unbolt the MC and push to the side, tie it away so that it wont bend the brake lines, then unbolt the HB,
super easy
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #8 of 14 (permalink) Old 01-18-2010, 03:28 AM
SLTRAM98's Avatar
For changing power steering fluid you can always just disconnect the rubber line running to the steering box... it will dump ALL of it in one go. Then just retighten and refill!
1998.5 24v 4x4 5sp ext. cab 3500. Fully Loaded. Straight 4" pipe from the turbo back, Quadxilla Adrenaline w/ Pulse, 100hp Edge sticks, AirDog 150 Silencer ring MIA.2" front lift HD...3:54's
NICE
SLTRAM98 is offline
post #9 of 14 (permalink) Old 01-18-2010, 11:16 PM
AK-DRam's Avatar
Today I used a turkey baster and small hose, filled it back up with royal purple and it still moans and groans although it is getting better. I popped the top and looked in...air is still in there. small bubbles... will try it again later.
2001 - 2500 4X4, 6 speed HO, EDGE juice/attitude, strait pipe, BHAF, LUK clutch, level kit, DDP 75 sticks and CFM air horn, 4 inch dual exhaust, Banks exhaust brake and feed by an AirdogII. 
AK-DRam is offline
post #10 of 14 (permalink) Old 01-19-2010, 12:05 AM
once you aeriate the power steering fluid you have to let it sit for an hour or so for the air to leave the fluid, after you suck it out you need to refill and when the truck starts make sure it does not suck the resivor dry or you will aeriate the fluid again
nickg is offline
post #11 of 14 (permalink) Old 01-19-2010, 12:18 AM
AK-DRam's Avatar
I will let it set over night and refill or do you think i need to suck it out again and start over?
AK-DRam is offline
post #12 of 14 (permalink) Old 01-19-2010, 02:41 AM
If you only sucked it out once, tomorrow before you start the truck, suck it out and refill, the more times you do it the more fluid gets replaced, If you use up a quart, flushing it, you should have replaced 80-90% of the old fluid,
maybe every morning before starting the truck for the next 3-4 days, suck it out and refill, or do it 3 or 4 times after running the truck for 10-15mins between "flushes",
later on once its been done, everytime you do an oil change, flush the PS fluid (1 flush will be enough)
nickg is offline
The Following User Says Thank You to nickg For This Useful Post:
BigMike12084 (12-29-2012)
