Steering Box Replacement - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 11-19-2009, 11:09 PM Thread Starter
wennis1's Avatar
Can anyone tell me how to replace the steering box? There is a leak where the pitman arm goes into the box and I have never done this before. Any advice would be a great help.
99 2500 4x2 quad cab, auto trans, FASS 150, K&N
wennis1 is offline
post #2 of 26 (permalink) Old 11-20-2009, 08:15 AM Thread Starter
wennis1's Avatar
Anyone? Beuller.....Beuller.....Beuller.....Fry.....Fry... ..Fry.
wennis1 is offline
post #3 of 26 (permalink) Old 11-20-2009, 08:26 AM
Just Another Cummins's Avatar
Remove steering shaft, remove p/s steering lines, remove drag link.
Remove 3 bolts from frame viola it's out.
Only tool other than sockets and wrenches you need it a pickle fork.
Cameron
01 QC SB 47RE
Tinted WS and all others, Quad ADR, BD150 tips, HX35, Raptor 150-DSV, 4" MBRP,35x13.5-18s
2590.8 MM Western Straight Blade
RU "Sirius"
Just Another Cummins is offline
post #4 of 26 (permalink) Old 11-20-2009, 09:09 AM Thread Starter
wennis1's Avatar
Do I have to get the pitman arm out? If so do I use a puller?
wennis1 is offline
post #5 of 26 (permalink) Old 11-20-2009, 10:01 AM
virgils59's Avatar
I dont know jack about this but
would that just be a seal around the pittman arm shaft? just trying to help!
Derek
2006 2500 White, 15% Tint w/5% Strip, Debadged, No Muffler or Cat, 4 inch exhaust, S&B, 295/70/17 Hankook rf10 ATs, KMC XD 17 x 9 Revolvers BLACK... Waitin on ... Black Big Mouth Grille, Spray In, Black Bumpers....
virgils59 is offline
post #6 of 26 (permalink) Old 11-20-2009, 10:08 AM Thread Starter
wennis1's Avatar
I believe that it is a seal but things can get worn around the seal and I don't want to have to do this again. Found the steering box for $166 plus core. Not bad.
wennis1 is offline
post #7 of 26 (permalink) Old 11-20-2009, 09:09 PM
The pitman arm is removed after box removal using a puller.
Cameron
01 QC SB 47RE
RU "Sirius"
post #8 of 26 (permalink) Old 11-21-2009, 02:12 AM
dont be surprised if after replacing the steering box, the new one developes leaks from the same spot down the road. do a search for DSS, it is a brace that supports the pitmam arm shaft so that you dont tear the bearings and seals out of the PS box.
my new box lasted 3months of use, thats 8-10hrs a day 5 days a week, I ended up installing a NApa seal kit(came with lower bearing) and a DSS, its not leaked since and I likely have 60,000+ (gotta check my log book to be certain) of intown use on it!
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #9 of 26 (permalink) Old 11-21-2009, 08:01 AM
Davcruz's Avatar
My preference is to remove the pitman arm prior to removing the box, sometimes you have to beat on it a bit and that is not easy with the box flopping around on the floor. You will need a pitman arm puller.
David - 2001.5 2500 Auto 4x4 QCLB, Fabtech 5.5, 35's, Magnaflow 4", AFE Stage 2, Edge Comp, BD Digital Pillar gauges, Airdog 100 big line, unknown injectors (RV275's maybe), Billet triple disc and shift kit
Davcruz is offline
post #10 of 26 (permalink) Old 11-21-2009, 11:19 AM Thread Starter
wennis1's Avatar
Once I put the new box in how do I reinstall the pitman arm and in what order do I do things on the install? Thanks for the help guys. I am going to start this project by myself in an hour.
wennis1 is offline
post #11 of 26 (permalink) Old 11-21-2009, 12:20 PM
put the pitmarm on the shaft, instal the nut and impact it on, also ensure the steering box is centered first as the arm can be installed incorrectly.
center box first on the floor, by turning lock to lock counting turns then turn back 1/2 the number of turns. also ensure you lock the steering wheel so it does not spin around "winding up the clock spring" and ruining it. when you are ready to install the steering colum to the box you can unlock the steering(use your key) to rotate it enough to line up the bolt and tightenit up
nickg is offline
post #12 of 26 (permalink) Old 11-21-2009, 02:49 PM Thread Starter
wennis1's Avatar
Thanks guys. He goes nothing. I will take pictures and try to post them tomorrow.
wennis1 is offline
