Old 11-17-2009, 01:56 AM   #1 (permalink)
smkin6spd's Avatar
LED dash lights
anybody ever done LED lights for your dash? i have blue pillar gauges and would like to convert my green dash lights to blue also.
2002 silver 2500 - 6spd w/ SBC 3850 12CB DD, ARB locker, AFE Bladerunner, FASS 150gph, Hurricane 2's, .093 tubes, htb2 64/14 & S400, 4in exhaust, Snow Performance stage 3, Edge Drag Comp, o-ring head, arp studs, MONSTER VP44! 661hp@ BD Diesel 10/18/09
smkin6spd is offline   Reply With Quote
Old 11-17-2009, 02:06 AM   #2 (permalink)
i could be mistaken but the green is usually from either a cap over the light like my wifes echo in which case you could do that, or the console display is actually a green tinted acrylic in which case you will need a custom sheet made
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch. autometer boost/pyro gauges, glowshift FP gauge, raptor 100.
Dracozny is offline   Reply With Quote
Old 11-17-2009, 09:41 PM   #3 (permalink)
smkin6spd's Avatar
gotcha, i guess it will have to be a tear apart to see thing.
Old 11-17-2009, 10:11 PM   #4 (permalink)
mjd91's Avatar
Mine are blue! Not LED (yet) but they do look pretty good!
Mitch 2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, Quad Adrenaline, AirDog II 165, AutoMeter Cobalts, Peak intercooler boots
mjd91 is offline   Reply With Quote
Old 11-17-2009, 10:19 PM   #5 (permalink)
Tech Specialist
The display actually has a greenish blue (mostly blue) tint to it, the yellow from the stock bulbs makes for the funky factory green. Blue or green comes out the best unless you want to go to the trouble of redoing that lens. Let me know if you have any questions.
PM Cepp on here for a kit or go to Super Bright LEDs - LED Products and Accessories and order the bulbs individually.
98 Dodge 2500 Motor: 12 valve, original 913 pump with the basics, some DDP parts, FASS, and more stuff then they will let me put here
Drivetrain: 5-speed 4x4 w/ SB clutch
Dual K20s is offline   Reply With Quote
Old 11-17-2009, 10:26 PM   #6 (permalink)
mjd91's Avatar
Hey Dual, did you do your a/c controls too? If so how?
Old 11-17-2009, 10:41 PM   #7 (permalink)
Tech Specialist
Yeah. I just used two 4mm "NeoWedge Instrument LED bulb"s from superbrightleds.com
Old 11-17-2009, 11:03 PM   #8 (permalink)
mjd91's Avatar
Is it as simple as the dash lights? I haven't really looked at them.
Old 11-17-2009, 11:51 PM   #9 (permalink)
little red cummins's Avatar
man thats sweet!!!
02 2500 4x4 6spd. SB Single. HOT Juice. Smarty Revo. FASS 150. BHAF w/ Outer Wear. 6'' Aussies. Leveled. 315 Procomp M/t. B&W Gooseneck. Cobra 29 NW w/ dual 4ft Firestixs. Custom Front Bumper. High Idle Bomb
little red cummins is offline   Reply With Quote
Old 11-18-2009, 12:24 AM   #10 (permalink)
Tech Specialist
It takes just a tiny bit more finagling but its still really easy.
Old 11-18-2009, 03:04 AM   #11 (permalink)
just dawned on me that if you wanted LEDs your console dimmer will probably be useless. I do use mine often
Old 11-18-2009, 02:42 PM   #12 (permalink)
Tech Specialist
Yeah my dimmer acts as more of an on/off switch now. I got some LEDs from ISSPRO that worked with the dimmer when the others didn't
It would be nice if it worked but I can deal with it. I wonder if something like this would work?
