| 98.5-02 Non-Powertrain Discussion of 98-02 Topics Not related to the Powertrain...NO ADVERTISING |
Click when I Crank??
Hey guys, It hasn't happened for a day or two..... The other morning....pbly round 40 or so degrees..nothin' too cold, truck not plugged in I waited for the wait to start light to flick off I turned the keys forward and got nothn' but a click. It happened twice then started fine. It did it that afternoon again but it hasn't happened since. I had the clutch all the way in, so that can be counted off. I took all of the battery cables off and cleaned all the corrosion and crud off of them and posts. Checked the starter cables and they were just fine......... What happened? What's gonna happen? Has anyone had this issue turn into something astronomical after a few clicks.........???? Thanks, ![]() ![]() ![]() Joe H.
2002 Ram 2500 4wd 5speed, straight pipe, BHAF, Turbo Silencer ring remOOOOved!!..........looking for more....
#2 (permalink) |
just need to get new batteries bud...if everything else checks out...they are the problem
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link 02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up... |
#3 (permalink) |
my auto has done this as well and have been wondering if it's normal or not?
01 CTD, 47re, 55 block
#4 (permalink) |
i don't understand how a transmission has anything to do with the electrical stuff(bear in mind i drive a 5 speed) so, i can't help ya there
#5 (permalink) |
posted to late, but does the click hurt any thing when it does it?
#6 (permalink) |
no, the click tells you that the starter isn't getting the current that it needs to crank.... i went to start my rig last night, about 8 pm..opened the door, turned the key on, jumped in, turned the key and then all the electrical stuff in my truck went off...popped the hood, and, the damn terminal on the driver's side negative post was off...that coulda been bad
| The Following User Says Thank You to cmns2500 For This Useful Post: | 01 Blue Wagon (11-06-2009) |
#7 (permalink) |
actually a burned out motor and or solenoid will cause the same thing. pull it and inspect.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100. |
| The Following User Says Thank You to Dracozny For This Useful Post: | cmns2500 (11-06-2009) |
#8 (permalink) |
ha, i figured i was forgettin somethin...
#9 (permalink) |
usualy a click, means the starter contacts are nearing the end of its life, you have two options 1) replace starter 400-900$ depending where you buy it 2) replace contact strips 5-35$ heres a link to replacement parts and how to replace them LarryB's Dodge starting problems solved here. instal inst Contacts install
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Jun/09 455,000kms RETIRED Military Mechanic (20yrs) |
#10 (permalink) | |
with heavy pitting there is the chance that the stator contacts will be out of round. resulting in even more pitting when you try to start it.
#11 (permalink) | |
www.Mopar1973Man.com
![]() Join Date: Feb 2006
Michael Nelson - 2002 Dodge Cummins For Technical Assistance With Your 24V 2nd Generation Cummins - Click Here! Or Search CF.Com for an Answer Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
| The Following 2 Users Say Thank You to Mopar1973Man For This Useful Post: | cmns2500 (11-07-2009), Joe Howard (11-09-2009) |
#12 (permalink) | |
01,2500,qc,sb,4in exaust,autometer gauges,k&n intake,ats intake manifold,fluidamper,bd rad,airdog 150,sps62,bd manifold,a1 studs,edge juice w/a hot, coaltrain 150 stix, fbd built trans 503/1022 on 9/26/09 |
