| 98.5-02 Non-Powertrain Discussion of 98-02 Topics Not related to the Powertrain...NO ADVERTISING |
headlights turn off
when i use my high beams and turn them off my headlights sometimes turn off and sometimes they dont, or they will just turn off all the sudden, but if i dont use my high beams at all they do not turn off, i was thinking maybe it was the high beam switch, but i am not sure how it works or how to fix it, has anyone else had this problem? or have any tips? thanks for any help
2002 2500 4x4, edge juice with attitude, fass 95 4'' tbe exhaust, afe intake, bd tranny tc and pressure loc. kore recon kit. |
#2 (permalink) |
Ive had this problem with older trucks with the dimmer switch on the floor. It was usually a bad dimmer switch. But... If the lights come back on when you switch from bright to dim you have a bad dimmer switch. If they go off after you have been running the high beams for a while and you have to wait a while for your headlights to work at all start with your fuse box. If the headlights use a thermal fuse switch it out with a regular fuse of equal value. If this fixes the problem you need a new thermal fuse. If it blows the fuse check your headlight wiring for shorts and make sure you have good connections at the headlights, headlight switch and also make sure that the fuse plugs into the fuse box tightly. Look in the relay center under the hood and see if you have any headlight fuses or relays in there. Make sure the connections are tight and if you have a headlight relay try switching it with another one in the box. If you have installed any aftermarket headlights that draw more current than the factory bulbs try putting the factory bulbs back in. If you still haven't solved the problem you probably have a bad headlight switch. The high amperage high beams may be heating up the switch to the point you lose connection.
2002 6-speed, 5 inch straight pipe, Icebox, Edge Comp/Smarty. Isspro pyrometer, mechanical boost guage & electric fuel pressure gauge. FASS 95, Valair kevlar/ceramic clutch... |
#3 (permalink) |
check your grounds! bad ground will result in dim or no light prev owner of my truck used an incorrect bulb in the driverside assembly and the results were disastrous, bulbs randomly working incorrect high low beams etc.. correct bulb completes ground circuit the correct way resolving problem.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100. |
#4 (permalink) |
hi have the same one year ago on my ram 1500 1995 4x4, it was dust in the switch near the steering wheel, i blast inside the switch with air pressure and put contact spray in same time on off on off ...20 times or more with current on (lights on) ok until now. hope this help! Thierry |
| The Following User Says Thank You to thierry For This Useful Post: | DESERTSAGUARO700 (11-04-2009) |
