| 98.5-02 Non-Powertrain Discussion of 98-02 Topics Not related to the Powertrain...NO ADVERTISING |
Water in driver's side floorboard after rain??
Depending on how the truck is parked, standing water will gather in the driver side floorboard. Could it be the third brake light or the rear window?
'01.5 2500 SLT Laramie Long Box 4x4 QC Black 5sp manual STOCK (as far as I know) |
#2 (permalink) | |
windshield could be a culprit if it was installed prior to 04 due to bad sealant.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100. |
#3 (permalink) |
its probably your cab lights ,after market lights are cheaper than the factory ones
05 dodge 2500 4x4 48re , automet. gages, quad boost fooler, /no silencer ring, bully dog/crazy larry,stage 3 afe air intake 5"expandit |
#4 (permalink) |
Check third brake light and cab lights. Also if you do a search you will find GOBS of info including a write up I did with the most common places for leaks. You could go down the list doing each one until you find your leak. Mine was the third brake light.
2001.5 2500 4x4, QC, 6 spd, 57/65/12, Int heater delete & horn, 5" exh, AD 150, Psychotty intake, 275 Inj, Edge Comp, Vulcan DS w/ dual return, SB Con OFE, 2" front level kit, 315/70R17 BFG A/T on H2 wheels, 3rd gen front brakes, DSS, Custom stereo. |
#5 (permalink) |
GalliganJr
![]() Join Date: Sep 2009
My leak on the driverside floor ended up being as simple as the weather stripping on the door it didn't leak all the time only when it down poured. It looked good no signs of wear it ended up being between the windshield and the the cab lights that little 45angle it didn't look bad at all but it was leaking from there. Junkyard had the peice. Alot of 1500's in the yard cause of cash for clunkers!
99 quad cab short bed auto all stock 4x4 injection pump 8/08, apps sensor 10/09 |
