Old 10-28-2009, 06:15 PM   #1 (permalink)
Popping and cracking noise in steering wheel area?
What would cause a popping and cracking noise in steering wheel area? This has been doing this for awhile now and it hasn't progressed any worse yet and nothing else seems to be affected.
2002 SLT 6-speed HO SB/QC 4x4, 3.55's Anti-Spin, BHAF, Triple A-Pillar Isspro Gauges (FP,Boost,Pyro) , MBRP 4" Exhaust, Airdog 100, Smarty Revo, Edge Comp, Silencer Ring MIA
winch_warrior is offline   Reply With Quote
Old 10-28-2009, 06:34 PM   #2 (permalink)
Fischer86's Avatar
I have the same issue. It comes and goes. I would like to hear some input on this as well.
Fischer86 is offline   Reply With Quote
Old 10-28-2009, 07:20 PM   #3 (permalink)
smokey18's Avatar
if the noise is coming from close to the steering wheel it would have to be your turn signal switch. its like a doughnut and the steering shaft does through it. sometimes something falls off of it or a piece of it falls off or breaks. you have to take the two screws out of the back side of the steering wheel and the airbag will pull off. then use a steering wheel puller to take the wheel off and the gear wheel behind it too. then you will be able to look at the switch while you turn the shaft and see whats going on. this is really the only thing that can make noise.
smokey18 is offline   Reply With Quote
Old 10-28-2009, 08:00 PM   #4 (permalink)
overtime's Avatar
Possibly the clock spring. Does cruise still work?
07 6.7 3500 S.W. 4x4 auto 4:10 EDGE JUICE W/ATT NO DPF. 01 1 ton 4wd c/c welding truck.
overtime is offline   Reply With Quote
Old 10-28-2009, 10:25 PM   #5 (permalink)
Yes, cruise still works. Nothing else effected except it makes noise when steering wheel is turned.
Old 10-30-2009, 11:08 PM   #6 (permalink)
SCRRRP
ruidosododge's Avatar
This freakin noise just started in mine too. It only happens when I turn the wheel.. There has to be a fix besides replacing all that crap. Its just a simple creak/pop noise...?
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
ruidosododge is offline   Reply With Quote
Old 10-31-2009, 02:00 PM   #7 (permalink)
Kybel's Avatar
Mine has been doing this forever and only when I turn right.
1999 2500 Sport 4WD QC/SB Auto, 2nd VP, 285/75/16's, Ring MIA, In-tank conversion, 4" Diamond Eye Turbo-back, Quad XZT+, BHAF with outerware, ISSPRO Mech Fuel, PSC Steering Stabilizer, Lukes Link, DTT Noise Filter
Kybel is offline   Reply With Quote
Old 11-01-2009, 02:22 PM   #8 (permalink)
smokey18's Avatar
fixed mine. but wtf do mechanics know.
99' 2500 edge comp, banks big head, gauges, ''ringless'' m/t 16's 35 in mud tarrains, 4 in no muffler. 39 psi stock turbo 5 speed
Old 11-04-2009, 01:59 AM   #9 (permalink)
SCRRRP
could you share with us how?
Old 11-04-2009, 03:07 AM   #10 (permalink)
Fischer86's Avatar
He did. Check out post #3
98.5 3500. 4", Edge Juice w Att. unlocked, DDP 100's AFE filter, 47RE w Triple billet converter and VB
Old 11-04-2009, 04:06 AM   #11 (permalink)
SCRRRP
Oops... What part is it normally?
Old 11-04-2009, 10:33 AM   #12 (permalink)
99DodgeRam360's Avatar
Are you sure the noise is coming from inside the cab by the steering wheel or outside because mine has a popping sound to but it is from the outside and i believe its coming from my steering box. Just wondering
99DodgeRam360 is offline   Reply With Quote
