Old 11-04-2009, 05:30 PM   #13 (permalink)
SCRRRP
ruidosododge's Avatar
mine is coming from right behind the steering wheels as the others have described
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
ruidosododge is offline   Reply With Quote
Old 11-04-2009, 07:10 PM   #14 (permalink)
99DodgeRam360's Avatar
With this poping and cracking sound coming from mine i'm pretty sure it is coming from the steering box so i was wondering if you guys knew if the 1 ton steering box is more heavier duty than the half ton steering box and if so could i put one on mine.
99, 7 In. Suspesion, 3 In. Body, 38.5x14.50 In. Swampers, 15 In. Ion Alloy Wheels, Shorty Headers, No muffler, Couldn't Afford A Cummins
99DodgeRam360 is offline   Reply With Quote
Old 11-13-2009, 05:29 AM   #15 (permalink)
SCRRRP
Originally Posted by smokey18 View Post
if the noise is coming from close to the steering wheel it would have to be your turn signal switch. its like a doughnut and the steering shaft does through it. sometimes something falls off of it or a piece of it falls off or breaks. you have to take the two screws out of the back side of the steering wheel and the airbag will pull off. then use a steering wheel puller to take the wheel off and the gear wheel behind it too. then you will be able to look at the switch while you turn the shaft and see whats going on. this is really the only thing that can make noise.
where do you get a steering wheel puller and the part that needs to be replaced... mine is getting louder and louder
Old 11-13-2009, 03:21 PM   #16 (permalink)
CumminsOrNothin's Avatar
Most of the time its going to be your front end. Mine did it twice first time my track bar was bad replaced it it whent away second time i had to replace another bushing then it whent away these dodges dont have the best front ends i would do a walk through of your front end...
1999 4x4 Auto De-Chromed
Southwest Coal Rollers.Com(NM,TX,AZ,CO)
CumminsOrNothin is offline   Reply With Quote
Old 11-13-2009, 07:58 PM   #17 (permalink)
SCRRRP
Done that already haha...
I have to replace everything. But the popping noise is inside the cab in the column.
Old 11-14-2009, 12:10 AM   #18 (permalink)
I use to have something similar to what your describing.. the intermediate steering shaft was replaced, and away it went.. I was physically able to feel it in my fingers as I turned the steering wheel, and maybe just a subtle 'click' noise (a rusted knuckle)...I dont know if thats along the lines of what you're experiencing or not.
02 6 Speed, AFE Intake, 4" TB Exhaust, Fass 95 LP, Edge Comp, Pyrometer/Fuel pressure gauges
chucks_cummins is offline   Reply With Quote
Old 11-14-2009, 12:20 AM   #19 (permalink)
SCRRRP
Ya I mean I can not only feel it... I can hear it.... A loud popping noise inside the steering column... feels like there is a rock in there
Old 11-14-2009, 08:57 PM   #20 (permalink)
smokey18's Avatar
napa for the part. and they can order the tool if you dont have it. pull it apart first though. switches are salty. if you need a walkthrough. blarh3gen@yahoo.com
99' 2500 edge comp, banks big head, gauges, ''ringless'' m/t 16's 35 in mud tarrains, 4 in no muffler. 39 psi stock turbo 5 speed
smokey18 is offline   Reply With Quote
Old 11-14-2009, 09:00 PM   #21 (permalink)
SCRRRP
lol switches are salty?? Why are you kicking me over? and thanks for the email have you seen this part before??
'Rock Solid' Ram Truck Steering !
Old 11-14-2009, 09:05 PM   #22 (permalink)
smokey18's Avatar
yes i have replaced quite a few. not so much really new though
Old 11-14-2009, 09:12 PM   #23 (permalink)
SCRRRP
have you seen that part that I posted?
Old 11-14-2009, 09:12 PM   #24 (permalink)
I just got this part, but, I have not installed it yet. I hope it makes a difference. However, my truck drives pretty well, though. Will update when I get it installed.
kevlars
2002 Quad Cab, LWB, 4X4, HyperTech Tuner, Straight Piped, LT 285/75-16 Goodyear Wrangler Dura-Tracs, Stock Auto tranny, 3.55 gears, Posi rear axle, 95,XXX miles, Western Snow Plow, Airdog 150 with Autometer FP gauge.
kevlars is offline   Reply With Quote
