Old 11-04-2009, 01:51 PM   #13 (permalink)
01_Cummins_Sport's Avatar
i talked to a guy that was selling all sorts of lights at a truck show a couple months ago and he said there was one company that makes them but i cant think of the name right now. he said other than that you need to make a wiring harness that takes the two bulb harness down to a one bulb. he said it was easy and you dont need to cut your harness to do it. if i can find his card ill email him and see where those headlights are at
01 Cummins Sport, 4" Turbo Back to 7" Stack, Pace Engineering Bed Cover, AFE Stage 2, Line X, Silencer Ring Removed, Smarty S-03, 5% and 20% Tint, American Racing Wheels, Radioshack CB, Sony, JL Audio 10's, Scangauge 2, ISSPRO 60lb Boost, 30psi Fuel Press
01_Cummins_Sport is offline   Reply With Quote
Old 11-04-2009, 05:28 PM   #14 (permalink)
SCRRRP
ruidosododge's Avatar
Originally Posted by Smourj21 View Post
nope SOL i guess, i looked everywhere, thinking about maybe smoking the stock headlights
ah I see. well if you find em put em up on here
Originally Posted by mjd91 View Post
Ask blackoutdp...
Thanks sir. I will find him and see what he knows
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
ruidosododge is offline   Reply With Quote
Old 11-04-2009, 07:20 PM   #15 (permalink)
Pull It Till It Breaks!
Smourj21's Avatar
that would be nice if someone made a plug and play harness for the bulbs, then put HID's in
Leveled 2002 Short Bed Quad Cab 6 Speed SHO | MBRP 4" Duals | Short Shift | Valair DD | Edge A2 | BD HRVP44 | Airdog 150 | CFM+ | BD Steering Stabilizer | Brite Box| 3pc Exhaust Manifold | DDP 250HP sticks | 35" Toyo MT's on 18" Driiv Offroad |Bilstein 5100's| Dana 60/80 | 3:55's | Detroit TrueTrac | Traction Bars| HX40/S475 TWINS|
|520hp/1132tq With the 200's|
Smourj21 is offline   Reply With Quote
Old 11-04-2009, 11:02 PM   #16 (permalink)
00sport24v's Avatar
I put the projector halos on my sport from ebay, I just didn't use the high beam connector, and I think I had to splice into a wire. Can't remember exactly but it was easy. And I do have both high and low beam. Hope this helps.
00 reg. cab auto sport4wd-Edge JWA, Fass150, Stacks, bhaf, Halo's, A.R.wheels, 285stt's, Smoke Switch
00sport24v is offline   Reply With Quote
Old 11-04-2009, 11:15 PM   #17 (permalink)
mjd91's Avatar
I think powermad has some smoked ones too. It looks like it in his avatar pic.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels
mjd91 is offline   Reply With Quote
Old 11-07-2009, 10:10 AM   #18 (permalink)
Smourj21's Avatar
i found some on Pure diesel power.com pretty cheap!
94-01 Dodge Ram Halo Projector Headlights - Chrome
94-02 Dodge Ram 1500/2500/3500 Halo Projector Headlights - Black
Old 11-07-2009, 08:41 PM   #19 (permalink)
01heavyweight's Avatar
Well, I have has this dilemma for around a year now and I decided to cope with it and just put HID's in, after about two months with HID's I decided I would smoke them a bit, well it was a complete waste of time. Why pay 300$ CAD on an HID kit when you can't see just as much as you did pre-HID. So If I could offer any advice I would say stick a HID kit in the there use rubbing compound on the lenses to take that yellow-ish look off and then put some 3M on them to prevent it from coming back. Just my .02 cents because I have already had this all happen.
01heavyweight is offline   Reply With Quote
