| 98.5-02 Non-Powertrain Discussion of 98-02 Topics Not related to the Powertrain...NO ADVERTISING |
BD vs. PSC steering box brace
found this today... (SB-100) Dodge 4WD '94-'02 2500 & 3500 Steering Stabilizer [SB-100] - $169.95 : PSC Motorsports, Off-Road Steering Experts does anybody have one? Is the BD version worth the extra 55 bucks?
2000, 2500, 5 speed, non 53, 3.55's, gagues, fass 95/150, BHAF, Edge Juice w/ Attitude, boost elbow, 5" R.S.D. str8 pipe, leveled on 295/75/16 Toyo A/T's: Quadzilla XZT+ and set of Westac gages for sale!!!! |
#2 (permalink) |
Get the PSC! They are exactly the same just different paint! I wish I would of found the PSC before I bought my BD brace, oh well, they do make a hell of a difference though! Good luck.
2001 Dodge Ram 2500 White Quad Cab, 4x4, Leveled with 35" BFG KM2s, BD Billet Converter Drag Comp, DDP 110's, HTT 62/65/13ss, HTT Quickspool Manifold
#3 (permalink) |
SCRRRP
![]() Join Date: Dec 2007
Do they really make a good difference?
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
#4 (permalink) |
Ive herd both ways...I sure hope it does something! My dads kubota tractor has better road manners than this freekin Dodge
#5 (permalink) |
Horse Power JUNKIE
![]() Join Date: Jul 2008
I have the PSC, bolted up just fine and way cheaper. I think it help just a little, I believe it helps prevent damage more. Also helps with big tires.
2001 2500 4x4 PDR HX-40 , PSC brace, Hamilton 110 springs, Fluidamper, ARP studs, Adrenalin, DDP 150, custom intake, 4" straight pipe, AIRDOG 150, BD black FP, Suncoast billet trans, 3-disc converter, 3rd Gen Brakes, Thuren 3rd Gen track bar. RIP grandpa "Red" 10-11-08WAGNAAR MOTORSPORTS |
#6 (permalink) |
It's supposed to make it track straighter & help lessen the wear & tear on the rest of the front suspension. Mine was all over the road until I replaced 4 ball joints 1 outer tie rod, all Moog & a Rancho steering stabilizer. Also a front end alignment. It drive at least 90% better. With one of those bars, I bet it would drive & track as good as my Honda's. ![]() Dave
Red 98.5 24V 3500 dually. K&N filter, low fuel pressure light.Soon to be added: Fuel Pressure & Trans Temp Gauges. Will be running Biodiesel!
#7 (permalink) |
Pull It Till It Breaks!
![]() Join Date: Nov 2007
i got mine from dynomite diesel for $175 i like it because the main piece of the stabilizer is round, its not square stock. it just looks like its supposex to be there because everything else in the front is round not square. i noticed a difderence running my 35's steering is more reasponsive
Leveled 2002 Short Bed Quad Cab 6 Speed SHO | MBRP 4" Duals | Short Shift | Valair DD | Edge A2 | BD HRVP44 | Airdog 150 | CFM+ | BD Steering Stabilizer | Brite Box| 3pc Exhaust Manifold | DDP 250HP sticks | 35" Toyo MT's on 18" Driiv Offroad |Bilstein 5100's| Dana 60/80 | 3:55's | Detroit TrueTrac | Traction Bars| HX40/S475 TWINS|
|520hp/1132tq With the 200's| ![]() |
#8 (permalink) |
It does make a difference, but some trucks may or may not notice an improvement. the brace stiffens the frame area, and provides support for the lower bearing in the steering box, if you have other components that are bad ie, ball joints /trackbar/tierods. you WILL not see any difference. if you look at the steering set up you can easily see how the load is placed on the pitman arm/shaft, it will edventually tearout the lower bearing. the brace remove the load from it. To check to see if you box has play in the lower bearing, with the engine off and wheels straight ahead hit the pitman arm with the palm of your hand where the drag link connects to it, if bad you will see movement AND hear a loud "clunk" both the brace and the trackbar (3rd gen) will drastically eliminate steering wander. 90% of most steering issues is the trackbar.
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Jun/09 455,000kms RETIRED Military Mechanic (20yrs) |
#9 (permalink) |
Have you checked a price on the original brace made by Solid Steel Industries? The others are copies, SSI may be cheaper, not sure.
David 2001.5 2500 with some stuff |
#10 (permalink) | |
(im kinda anal with stuff like that )
#11 (permalink) | |
| The Following User Says Thank You to Smourj21 For This Useful Post: | TRUCKERBALLZACH (10-21-2009) |
#12 (permalink) |
I have both the PSC steering gear box & steering brace, IMO well worth the money, Good product!
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper. |
