85plus/2 stroke oil? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 10-19-2009, 01:20 AM Thread Starter
dzlpwrd's Avatar
hey guys just noticing that a lot of guys are running 2 stroke oil- 1 quart per tank or something like that..
I use the winterized 85 plus from redline religiously because it boosts the cetane, and reduces cloud point to some level.
Questions:
Am I getting enough lubrication for my vp44 by just using the redline?
Can I safely mix my redline and the 2 stroke oil? I dont know if this is such a good idea or not.
Are there any drawbacks to using 2 stroke oil in diesel?
2002 QCSB 4x4, 5-speed SO, ST, line-x, 2" Revtek level kit, Banks Big Hoss tuner, Big Head wastegate, FASS II, draw straw, K&N drop in, Banks Hi-Ram intake, str8 piped, silencer ring mia
, pyro, boost and fuel pressure gauges, coming soon 100hp sticks
dzlpwrd is offline
post #2 of 8 (permalink) Old 10-19-2009, 01:23 AM
countrycummins99's Avatar
shouldnt hurt considering both the diesel in your truck and the two stroke came from the same place i run mine with power service and two stroke all the time
99 DODGE 24VALVE, FASS 150, EDGE COMP/SMARTY REVO STACK/100HP COALTRAIN STICKS ,GOEREND BILLET, HE351VE ,TC LOCK UP SWITCH, 380HP 744FT/lbs with my old slipping auto , GAUGES (FUEL PRESSURE, TRANS TEMP, BOOST, EGT DP))INFAMOUS 53 BLOCK 310,159
countrycummins99 is offline
post #3 of 8 (permalink) Old 10-19-2009, 01:45 AM Thread Starter
dzlpwrd's Avatar
right, I hear ya there..id like to keep the redline for the cetane and lowered cloud point, and add 2 stroke oil for the lubrication at the ip.
I was also wondering how good of a job redline does at lubricating?
dzlpwrd is offline
post #4 of 8 (permalink) Old 10-19-2009, 02:52 AM
mjhartz87's Avatar
twostroke works great. it smoothes out the truck quite a bit. it does not increase cetane levels in the fuel.
most places only sell ultra low sulfer diesel and its designed for 2007 and up diesels. the vp44 injection pump is sensitive cuz unlike the 12v p7100 it does not have an oil supplied cooling line from the engine. the vp44 cooling is solely based on the fuel cooling it hence the performance lift pumps having a higher pressure. higher pressure cools more. the 2 stroke oil restores that lost lubrication and saves your vp44 from a lot of wear from the lack of lubricity. i do a quart to a tank which is basically 1oz per gallon.
the 2 stroke oil HAS to be tcw3 formula which is ashless to prevent build up of carbon
03 H.O. QC/LB 4x4 NV5600: Pure Performance/ Carli/ Smarty/ Corbeau XRS/ S&B/ RSD/ Aeroturbine 5050/ Toyo 35's/ Gear Alloy 728B/ AD150/ AM Gauges/ Retroshop-projectors/ Amp Steps/ Custom Grille.
1936 Chevy 1/2 ton: 4bt cummins or 383 sbc. still deciding
C3 His and Hers Vette's
mjhartz87 is offline
post #5 of 8 (permalink) Old 10-19-2009, 03:04 AM Thread Starter
dzlpwrd's Avatar
Id love to get the benefits from the 2 stroke oil, but i also would like the redline 85plus for cetaneand cloud point.
can I mix them safely?
dzlpwrd is offline
post #6 of 8 (permalink) Old 10-19-2009, 03:14 AM
mjhartz87's Avatar
i imagine u could. i know people who mix two stroke and stanadyne. one for lubin and the other for the cetane.
nice chattin on the pm's if u have anymore questions let me now man!!
The Following User Says Thank You to mjhartz87 For This Useful Post:
dzlpwrd (10-19-2009)
post #7 of 8 (permalink) Old 10-19-2009, 03:20 AM Thread Starter
dzlpwrd's Avatar
Ya thanks for all the info helped alot..kinda like a confidence booster hahaha its one of those things where you want to do it, but your unsure..all u need is that little push over the edge
dzlpwrd is offline
post #8 of 8 (permalink) Old 10-19-2009, 09:12 AM
here is a link to someone who actually tested various lub additives, just remember he was ONLY testing for lub, not the other additive benifits
Lubricity Additive Study Results - Diesel Place
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
