Old 10-01-2009, 07:36 PM   #1 (permalink)
powermad's Avatar
code p0522
ok got this code the other day it a low voltage going to the oil system!!! is it a bad ground or is something needing to be replaced. gurus comment only please!
MY TRUCKS FOR SALE!2001.5 cummins sport SOVP44 afe stage 2, edge comp, 200hp injectors, silver bullet 66/74/14 and a built tranny with goerend and bd internals.
http://www.youtube.com/user/powermad2001
powermad is offline   Reply With Quote
Old 10-02-2009, 12:17 AM   #2 (permalink)
powermad's Avatar
anyone at all?????
Old 10-28-2009, 09:41 PM   #3 (permalink)
1000EE-Monarch's Avatar
I was driving down the road today noticed the oil pressure gauge sitting at 40PSI regardless or RPM.
Checked codes sure enough P0522. I'm tempted to change the oil press. sender.
Does you oil pressure gauge do the same thing (not move from 40psi)?
Alex K.
'01 3500 QC 4x4 NV5600 HO. Stock for now. BHAF, no silencer ring, muffler delete.
WANTED: '98 12v 3500 QC 4x4 5spd 3.55 gears
1000EE-Monarch is offline   Reply With Quote
Old 10-28-2009, 10:18 PM   #4 (permalink)
powermad's Avatar
i have no issues with the pressure. and the code went away. idk whats going on with this thing. i had brett at left coast diesel go through the truck and the only code that showed up was from the lock up switch. so i hav no clue
Old 11-01-2009, 03:58 PM   #5 (permalink)
Hmm maybe you just had an intermittent thing going on with the oil press sender....
It appears that if the oil press sender dies the gauge usually goes to the 40 psi mark (right in the middle).
I'd going to change that oil pressure sender on mine and see what happans. But at the moment the APPS issues I have are a first priority.
Alex K.
Old 11-01-2009, 05:38 PM   #6 (permalink)
powermad's Avatar
good luck with the fix let me know what happens
Old 11-04-2009, 08:55 PM   #7 (permalink)
OK put a new oil pressure sender in. The oil pressure gauge works correctly now, and I'm assuming the code will go away shortly.
The oil pressure sender is Cummins part # 4921511, got it from Cummins West in San Leandro, list price is $88.00. I get a 10% discount there, so that makes up for the darn sales tax.
Since your problem came and went, and your pressure gauge works correctly now, who knows it may have been a bad connection in the wiring, or maybe your oil pressure sensor is intermittent.
If you do see the pressure gauge stuck at 40 (right in the middle) for a long time check your codes again.
Alex K.
The Following User Says Thank You to 1000EE-Monarch For This Useful Post:
powermad (11-04-2009)
Old 11-04-2009, 09:13 PM   #8 (permalink)
powermad's Avatar
hey i appreciate the info i will make sure to keep a eye on it!
