ABS & Brake Light stuck on - 1999 Ram 2500 4X4 CTD...? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 09-25-2009, 09:22 PM Thread Starter
Any suggestions where to start poking around?
I just bought a 1999 Ram 2500 SLT. It is 4WD. 5.9 Cummins. Automatic.
The Brake and ABS light are stuck on. I haven't had much time to poke around with it and see whats going on. But was hoping this was maybe a common issue with these trucks and a simple fix.
Any suggestions?
Thanks guys,
Joe
PS - The power difference going from a 1992 F350 7.3 IDI to a 99' Cummins with Hypertech, Cold Air, and 5" Stack is UNREAL...
2006 Ram 3500 4X4 5.9L G56 QCLB DRW - Bone Stock other than Valair Twin Organic Quiet
CarnageZ28 is offline
post #2 of 18 (permalink) Old 09-25-2009, 09:38 PM
UtahDodgeCummins's Avatar
Disconnect the negative battery cables and turn your lights on. Leave it for about 10 minutes and that should clear it up. I had the same problem on my truck once. They came on after I tried to put the truck in 4 Hi.
'00 2500 Auto QuadCab ShortBed 105k- Quadzilla Adrenaline, BD performance elbow, 4" straight pipe exhaust, AirDog 100 w/custom bracket, BD Fuel pressure sensor, Autometer boost and pyro, EV2 Fuel Pressure, 55 block
, BD APPS Noise Isolator, BHAF
UtahDodgeCummins is offline
The Following User Says Thank You to UtahDodgeCummins For This Useful Post:
hhrumph (06-23-2014)
post #3 of 18 (permalink) Old 09-25-2009, 09:38 PM
I'd try the rear ABS sensor first. It's on the top of the rear differential. Just unplug it and remove the bolt holding it in, and then pull it out. Watch for the o-ring. There might be some metal shavings stuck to it as it's magnetic. You can try cleaning it off and reinstall it. That worked once for me, but I eventually had to replace the sensor. I had the same problem as you on my '98 12 valve 4X4. My truck has 4 wheel ABS.
prattman is offline
post #4 of 18 (permalink) Old 09-25-2009, 09:57 PM Thread Starter
Thanks guys! Work all day tomorrow. Hope to have time Sunday to play around with it and get it straightened out.
Appreciate the fast responses. This is my first Dodge so wasn't sure what I was getting myself into here haha...
post #5 of 18 (permalink) Old 09-25-2009, 09:58 PM
v10sport's Avatar
Your speedo working?
07 5.9L 2500 QC/LB 4x4. Edge J/A, Smarty TNT, AFE stage 2/ progaurd 7 filter Arson III 2G intake horn 6" lift 37 13.5 17 SS M-16 5"TBE Full Billet trans.
2012 3500 4x4 Auto DRW 4:10's Max tow. 5" TBE, EGR delete, CCV delete, Minii Maxx
v10sport is offline
post #6 of 18 (permalink) Old 09-26-2009, 06:46 PM Thread Starter
Speedo works fine.
post #7 of 18 (permalink) Old 09-27-2009, 12:43 AM
Waldershrek's Avatar
Sounds dumb but check your fuses also.
01 Dodge Ram 2500//262,000 miles and counting//AFE Stage 2 air box AFE dry flow filter and pre-filter//Raptor 150//Diamond Eye 4" stainless dual exhaust//Isspro Ev2 fuel pressure gauge
Waldershrek is offline
post #8 of 18 (permalink) Old 09-27-2009, 09:31 AM
Super10brss's Avatar
Mine is stuck on too
Seems the guy I bought mine from swapped out the front hubs with non ABS units You can see ABS wires dangling down...
I heard some where you can replace the bearings in the "stock" hub with Timken bearings and rock on with out having to buy the whole unit.... Any body know what the deal is on that.?.?.?.
1998 cab-chasis Utility bed #100 fuel plate 3K GSP Garmon trans
(Sold)
2007 LBZ Dirty Max
Super10brss is offline
post #9 of 18 (permalink) Old 09-27-2009, 02:44 PM
UpInSmoke02's Avatar
You'll spend more in shop time and parts than buying new ones. IMO
'02 2500 4X4 ADR W/ PULSE, S&B CAI, S&B Intake Elbow, FASS 150, BD SO VP44, Diamond Eye 4", 2.5" HBS Level Kit w/ Bilstein 5100's, 33" MTR's, DT Pro Fab Steering Box Stabilizer Next up: Tranny, Turbo, Sticks
UpInSmoke02 is offline
post #10 of 18 (permalink) Old 09-27-2009, 02:51 PM
Any suggestions?
Thanks guys,
Joe
Check the hub bearing for play... grab the wheel top and bottom, try to move it back and forth. You're looking for no movement.
Sounds like one of the sensors is toast. The front sensors are located on the hub. You just have to take the wheel, caliper and rotor off to get to it. I believe a 6mm allen is what you need to take it out.
They're about $60 to replace or if you have to replace the hubs, they come with it.
The rear is on the diff.
post #11 of 18 (permalink) Old 09-28-2009, 06:27 PM
DieselRiot's Avatar
iTrader Score: 5 reviews
The dealer has the scanner to read the codes for abs
2008. EFI Live By Cummins-Tuner. Copilot. 5" TBE. S&B Intake With Scoop. GDP Mega-Flo With Boost Tube. GDP Pro-Gate. GDP CCV Delete. WCC Silencer Ring Mod. Rail Shim. Fass Ti 150. ARP 425's.
DieselRiot is offline
post #12 of 18 (permalink) Old 09-28-2009, 10:07 PM
bigjim17's Avatar
my abs and brake light are both on and my speedo dont work? any ideas
1998.5 24v, edge juice w/attitude, 100hp injectors, cold air intake, 5 in stack,
bigjim17 is offline
