2500 dually conversion - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 09-17-2009, 03:49 AM Thread Starter
dish_towel2000's Avatar
how could i do a dually wheel conversion?
2000 dodge 2500 ctd, 2wd, auto trans, converter lock-up box, shortbed conversion, gauges, lift pump, vb, billit converter, 4in open xhaust, stage 2 intake, intake elbow, edge tuner. Plans: custom suspension and back to the long bed
dish_towel2000 is offline
post #2 of 25 (permalink) Old 09-17-2009, 11:50 AM
NC4WD's Avatar
You need a D80 out of a dually or an adapter.
Arrowcraft - Dual Wheel Conversions
They also have complete kits:
Y2K | NV4500 | NP241DHD | BHAF w/ prefilter | BD Wastegate | Edge Juice With CS Monitor | AirDog II | Dana 80 | Valair Clutch 500/1000 | NC4WD Flat Bed | GM Wheel Cylinders | 3rd Gen Wheels | 3rd Gen Front Brakes | Super HD Track Bar | Skyjacker Rear Springs | NC4WD Pre-Runner Bumper | Bilstein 5100's Front / 7100's Rear | 6" Grand Rock Stack | 35" KM2's | Amsoil Bypass Filter | North Country Rock Sliders | Cummins Coolant Filter | Lots of Ballistic Fabrication Parts | T-Style HD Tie Rod| Heavy 2 Stroke Diet | Updated 5th Gear Nut | Puke Bottle Delete | DSS Steering Stabilizer | Heavy Duty Lower Control Arms
NC4WD is offline
post #3 of 25 (permalink) Old 09-17-2009, 11:58 AM
you need,
Front spacers - these bolt onto your existing hub, allows you to run the heavily offset dually wheel
Dana 80 rear - is 4 inches wider then a srw rear end
dually wheels
and a bed or a flat bed
if your interested I have the front spacers for sale that were taken off my dually when i went to srw. I also have a set of 6 black dually wheels but i think it would be too much to ship.
2012 CCSB 4x4 Stock
catch2otwo is offline
post #4 of 25 (permalink) Old 09-18-2009, 04:07 AM Thread Starter
yea i have the front spacers already and all the rims. if the dually d80 is 4in wider than why would it be a problem to run 2in spacers on each side of the rear axle?
post #5 of 25 (permalink) Old 09-18-2009, 12:55 PM
probably work. might just need to get longer studs. From a spec standpoint, you will be able to have more load on a d80 then you would a 70. but from an aesthetics standpoint, im sure spacers would make the wheels work.
2012 CCSB 4x4 Stock
post #6 of 25 (permalink) Old 09-19-2009, 02:11 AM Thread Starter
im not doing a dually wheel conversion for weight. im doing it for 2 reasons. 1 being i think flatbeds look better on duallys and 2 i think im gunu do a 19.5 or 22.5 truck rim conversion.
i have a lathe and mill so im prolly gunu make rear spacers. thats why i wanted to know if they would work. prolly just make a 2 inch thick 8 to 10 lug adapter. and 4 inch 8 to 10 lug adapter too.
post #7 of 25 (permalink) Old 12-11-2009, 05:53 PM
Originally Posted by catch2otwo View Post
you need,
Is there a difference in a cab and chassis axle vs a DANA 80 dually axle?
Did either of these come with a 4.10 ratio from the factory?
Thanks!
BondoBuilder is offline
post #8 of 25 (permalink) Old 04-26-2010, 10:28 PM
i have a 2001 cab and chassis that came with 4:10's
cadethibb88 is offline
post #9 of 25 (permalink) Old 04-26-2010, 10:54 PM
BigHemi04's Avatar
iTrader Score: 5 reviews
reg duallys came with either 3.55 or 4.10, so yes.
06 QCLB 4x4 Lifted Auto, 06 QCSB 4x4 Lifted Auto, 95 RCSB 4x4 Auto 'Race Only', 77 Crew RampTruck 12v 6-Spd, 08 F450 CTD Swap
BigHemi04 is offline
post #10 of 25 (permalink) Old 04-27-2010, 12:11 AM
Someone took Mega Cab dually fenders and converted a 2500 QCSB into a 3500 QCSB Dually. Looks pretty cool but wierd as a Sec Gen.
2010 Ram 3500 Single Wheel Mega. Leveled in Front and Bagged in Rear.
Cutterw is offline
post #11 of 25 (permalink) Old 04-27-2010, 12:16 AM
cummins724's Avatar
iTrader Score: 23 reviews
I'm doing the same thing right now. I'm converting a 98 12v 5 speed ext. cab truck into a 1 ton dump. I'm having trouble getting a set of front dually adapters. I been looking all around. Anyone has any, let me know.
cummins724 is offline
post #12 of 25 (permalink) Old 05-14-2010, 04:05 AM
flubyux2's Avatar
Anyone have pics of drw on a 2500? I have a camper/tow package with a 3500 c&c width d80. I could technically benefit from a drw setup and the only difference is I have the narrow d80. I just wanted to find some pics of how far the drw sticks out on the 2500 box. I don't know what fender flares would work best, a 2" or 4" pocket bolt flare of if I'd need to go all out for the megacab flares. Just wondering if a drw swap would be too much of a Frankenstein or if it could work on an srw width.
truck #5
2001.5 3500 Laramie, qclb, 4wd, drw auto, goose, AirRaid
flubyux2 is offline
