Rebuild kit for steering box, where to buy - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 09-15-2009, 04:00 PM Thread Starter
Davcruz's Avatar
I know I looked for one about 5 years ago for my old 1/2 ton and there was nothing available then.
Does anyone know if there is a steering box rebuild kit for our boxes available now?
Need seals and bushings, etc.
David - 2001.5 2500 Auto 4x4 QCLB, Fabtech 5.5, 35's, Magnaflow 4", AFE Stage 2, Edge Comp, BD Digital Pillar gauges, Airdog 100 big line, unknown injectors (RV275's maybe), Billet triple disc and shift kit
Davcruz is offline
post #2 of 24 (permalink) Old 09-16-2009, 02:28 AM
dodge24's Avatar
Honestly, If you've never attempted this sort of thing before, just buy a new box. I've seen people try to rebuild big truck steering gears with less than favorable results. There is just way too much liability involved for me to even consider it. Besides, prices on new boxes from Dodge, not remans, were pretty reasonable last I checked.
01 Dodge Ram 2500 4x4 Auto 35" Toyo MT on XD Hoss Wheels
High Tech Turbo - Dynomite Diesel Performance - Thuren Fab - AirDog - Smarty - SOLD
dodge24 is offline
post #3 of 24 (permalink) Old 09-16-2009, 09:40 AM Thread Starter
Davcruz's Avatar
I have rebuilt many, I worked in a reman shop during my school days doing alternators, starters, steering boxes, etc. That place made their own hard parts and got the rest from China. It is not that hard to do, just a recirculating ball setup, the problem is finding the bushings, the seals are available but why replace seals for them just to go bad again because the bushings are worn out.
Davcruz is offline
post #4 of 24 (permalink) Old 09-18-2009, 07:15 PM
totalloser's Avatar
I got a reseal kit from NAPA for my AGR (POS) box. I'd look and see. Usually there is no need to overhaul. Just reseal and adjust for wear.
The sector shaft (pitman) usually is a bushing at the top, and a roller bearing at the bottom. the teeth on the sector shaft are tapered, so the freeplay can be adjusted from the top. Worm gear preload is a different matter, and might be better left alone if you need to ask.
But seals and adjustment are easy.
01 100hp tips EZ *hybrid* 4"ss BDbrake &steering brace "t"steer delphi tapped &rammed manual CAD 3.55's LSD, 1.375 nv5600/241HD Valair single pc rear ds 265x70r19.5 big rigs 3rd gen brakes Ugly black and thrashed!
totalloser is offline
The Following User Says Thank You to totalloser For This Useful Post:
schoust (08-11-2014)
post #5 of 24 (permalink) Old 04-07-2010, 09:45 AM
aerolland's Avatar
Here is how to rebuild one of our boxes:
Saginaw Steering Box Rebuild - Four Wheeler Magazine
And here is where you get the parts:
redneck ram hydraulic steering assist
1-877-833-7464
Call to order rebuild kit. In stock all day long, ~$40
'98 2500 4x4 5sp qcsb, 315/75-16 BFG's on Polished Centerline's, BHAF, 3K spgs, 13" SB DD, 1 3/8" I/S, Torque King M/S, TorqueTube, PSC steering gear, BD brake, DSS, PSC, KDP
'd, 0 plate, 3rd gen heat/elec tow mirrors, Ramsey 12K# hidden winch, Stealthbox
aerolland is offline
The Following 4 Users Say Thank You to aerolland For This Useful Post:
Davcruz (04-08-2010), eforbes (05-15-2010), hdscott57 (06-06-2012), slickrock209 (01-30-2012)
post #6 of 24 (permalink) Old 04-08-2010, 12:29 AM
DavidRasch17's Avatar
genos garage sells a new one for around 300$ and a upgraded one for 350$
(bluefurd)1998.5 blue 2500 club cab, nv4500,quad 4k, nanofiber amsoil, afe torque tube, FASS150GPH, 5inch str8 to 7in mirte with fte mount, pusher intake, tunnel ram, cpps 7x.014, bd short throw kit, valair 650hp dd, 17x9 kmc revolvers wrapped in 33x11.5 terra grapplers, 66/74/14 batmowheel, hamiltion rods/springs, arp studs, tru-trac in rear, lukes link, DAP steering brace, hawk brakes, blisteen 5100's, amsoil bypass system, devilsown stage2, ccp traction bars, fluidamper with pin kit, hellman fuel sump, equal lenght SS jet hot coated header
DavidRasch17 is offline
post #7 of 24 (permalink) Old 04-08-2010, 09:46 AM Thread Starter
Davcruz's Avatar
1-877-833-7464
Great info!!
Davcruz is offline
post #8 of 24 (permalink) Old 04-08-2010, 09:58 AM
I think I paid around 50$ from Napa
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #9 of 24 (permalink) Old 04-08-2010, 01:50 PM Thread Starter
Davcruz's Avatar
NAPA has these kits with the bushings? I have not been able to locate it on their site. What did the kit from NAPA contain?
Davcruz is offline
post #10 of 24 (permalink) Old 04-08-2010, 10:52 PM
I have the pkg in the garage, I'll find out the number for you, it had lower bearing for sure and seals
nickg is offline
post #11 of 24 (permalink) Old 07-21-2011, 06:33 PM
slickrock209's Avatar
You got that Part#
97, 2500, 4x4, 12v, 5 speed, 08 dodge rims, fuel plate #0, 3k GSK, boost elbow, posi lock cable, egt/boost guages, 5in straight pipe, K&N Air Intake, BD trackbar, BD steering stabilizer, towing mirrors, 5th gear nut, Valair 13in clutch.
slickrock209 is offline
post #12 of 24 (permalink) Old 07-23-2011, 03:44 PM
Dont repair it. Replace it with better technology from Delphi. Borgeson sells a replacement that is much better.
'00 QCLB4X4 Dr Evil Trans, Banks Bundle, more to come!
Shameless is offline
