Old 07-02-2009, 08:03 PM   #1 (permalink)
Drop My Ride
I would like to drop the 02 below.
Front
Best I can tell it has a leveling kit in the front, that is supposed to be about 2.5" I think. Also, it seems that 4" in the front would be the max I would be willing to go because this is the distance between the rubber snubber and the plate it strikes. Would cutting out 1 round of the coil work =~ 4"? Can you cut the coil with a hacksaw or do you need a torch?
Rear
The block that the leaf pack sits on is 4.75" tall. Can I just remove this block? Will the leaves align and sit correctly with this block removed?
Thanks! And come on, do not beat me up for wanting to ... "Drop" My Ride!
02 2500 4x4 SLT Laramie, QC, SB, 113K, Bed Cap, Leveled, 47RE, 4.10, 4" Exhaust, guages, FASS HPFP, Draw Straw V, Edge Mileage Max
afgunn is offline   Reply With Quote
Old 07-02-2009, 09:17 PM   #2 (permalink)
Gus Farmer at Farmboys Diesel Performance has his 99 down rather low, link below, and his is a 4x4 as well. I do not think I can get mine that low without some more expensive parts - do not want to go that route. Can a 99 be lowered more than an 02?
1999 Dodge Ram Cummins Diesel - Diesel Trucks - Diesel Power Magazine
Old 07-02-2009, 09:39 PM   #3 (permalink)
MI Chapter President
IC-Smoke's Avatar
Do NOT use a TORCH!! spring steel will collapse if you heat it up as you will mess with the temper heating it up.
You can install 1/2 ton springs
Im going to run 3/4 ton gasser springs to drop 1" or so then make new blocks to match the front drop so its level or 1" above the front
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
IC-Smoke is offline   Reply With Quote
Old 07-02-2009, 09:56 PM   #4 (permalink)
cmns2500's Avatar
if ya post up a pic, i can do an estimated look w/ a photochop...
CJ's truck....CLICK HERE===>>join CF TRUCKIN' on Trukz.com
02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up...
Old 07-02-2009, 10:28 PM   #5 (permalink)
IC-Smoke
I agree on the torch! Just what I was concerned about as well. Can you cut a hardened spring with a hacksaw or bandsaw?
cmns2500
It will take me a few days to get a picture up. Need one for the avatar as well. Thanks. Looking forward to seeing what it will look like before doing the work!
Old 07-03-2009, 12:12 AM   #6 (permalink)
BlackedOut02's Avatar
anyone know if 1500 drop shackels will work??
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 07-03-2009, 02:26 AM   #7 (permalink)
dknaks's Avatar
If you pull that leveling kit out and snap some pics would be happy to buy it from ya.
-Dustin
2002 CTD, 6 Speed, Quad Adr w/Pulse, RV275's, Fass 150, BHAF, ProComp 2", Isspro Boost & FP, Autometer Pyro, Toughneck Bumpers, Kenwood in-dash DVD/Nav.
dknaks is offline   Reply With Quote
Old 07-03-2009, 02:41 AM   #8 (permalink)
smokin24valve's Avatar
Here's a picture of mine. It had a 2.5" skyjacker lift on it with the "add a leaf" in the rear, now it has no blocks in the rear and 1500 coil springs(no engine, so the front will sit down a little lower). It dropped it a total of about 4 1/2", that was measuring from the top of the tire to the bottom of the fender.
James
96 1500 RCSB 4x4 12v in the works
smokin24valve is offline   Reply With Quote
Old 07-03-2009, 10:10 AM   #9 (permalink)
dknaks,
Everything that I have is for sale ... at the right price! I doubt that you would pay my price.
smokin24valve,
Great pictures! Thanks a lot, very helpful. Did you leave the skyjacker lift in when you put in the 1500 springs? Seems that the front would drop too much when you put in that 1100 lb. cummins!? Did you buy new front springs or get them used? In the rear, did you pull out the overload leaf?
Old 07-03-2009, 12:38 PM   #10 (permalink)
Originally Posted by afgunn View Post
smokin24valve,
The lift that was on my truck was a taller coil spring not the spacer, so its just the 1500 springs.
I put the block back in just to see how it was going to sit and it only dropped the front less than 1".
I bought the 1500 springs used for $20.
The overload leaf pack does not affect the ride height, there are 3 leafs in the main pack and one leaf under that. I will probably put "add a leaf" back in to help level it up.
The rear drive shaft in going to have to be shortened though. Not sure about the front drive shaft because I was waiting to get the engine back in first, but I doubt it will have to be shortened, because if anything the axle sits a little further forward than it did with the lift.
Here is a picture of how it sits with out the "add a leaf", the front sits a couple of inches higher than the rear.
James
Old 07-07-2009, 05:28 PM   #11 (permalink)
smokin24valve,
Thanks again, esp. for the photos. A photo is worth a million words!
