Old 07-12-2009, 11:09 AM   #25 (permalink)
cmns2500's Avatar
Originally Posted by SlammedWagon View Post
All Cummins equiped 2500's came with the D-60 fronts..
yup....
2500 Auto's had DANA 70's, Manual 2500's got the dana 80.. I believe anyway, I know i have the D80 on my '01 2500 6sp I believe this conversion will work on all trucks with outer mounted rotors
the 00-02 manual 2500's came w/ the "hybrid" D 80 rear, as did all 3500's, the 00-02 autos came w/ the D70 rear, and, pre-2000, all 2500's had the D70...
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link
02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up...
Old 07-12-2009, 04:36 PM   #26 (permalink)
Dang Nice right up.... Can't wait to do this to my truck ... never was too impressed with the stock braking....Already have the 17" Rims.... Thats prolly the most expensive part to the whole dea!!!
2001 2500 ext cab short bed 4X4, 2" level kit, S&B intake, 4" Down pipe ,5" exhaust, Fass 150, Silencer Ring MIA, Gauges (Boost,EGT,Trans Temp,Fuel Pres), Power Pucked, Recon Billet Triple Disc TC, Transgo SHift Kit, 125 HP Injectors on their way !!
kevstar1212 is offline   Reply With Quote
Old 07-12-2009, 05:44 PM   #27 (permalink)
Originally Posted by Mopar1973Man View Post
For the OP how many miles on the brake before replacement???
Surely you have a tough time catching me... 150K miles and still running on factory brake pads!
I might change brake pads by 200K miles...
Exhaust brakes are really handy!
Odometer - 118K when I did the brake job, the fronts were overdue for a brake job by about 2K as they started squealing like a pig. I continued to drive since I knew I was replacing the rotors anyways. The rears still have lots of pad left. The truck had 315/75 rubber when I got it at 56K and I swapped the mud tires for 315/75R17 BFG AT on H2s. So, it the odometer is about 9% off I believe since about 50K. Based on the tread left on the tires when I bought it I would guess it had the larger tires on since about 50K, so equivalent to 125K or so on 1 set of pads. Not bad! I do not have an exhaust brake like you, but I am easy on my truck.
2001.5 2500 4x4, QC, 6 spd, 57/65/12, Int heater delete & horn, 5" exh, AD 150, Psychotty intake, 275 Inj, Edge Comp, Vulcan DS w/ dual return, SB Con OFE, 2" front level kit, 315/70R17 BFG A/T on H2 wheels, 3rd gen front brakes, DSS, Custom stereo.
JasonblkZ06 is offline   Reply With Quote
Old 07-13-2009, 05:18 AM   #28 (permalink)
Offroadjunkie's Avatar
ya when it comes to towing exhaust breaks are great because on down grades you rarely have to touch them. My buddy always brags about this so i know all about it.....
Offroadjunkie is offline   Reply With Quote
Old 07-20-2009, 07:06 PM   #29 (permalink)
Sasquatch
crazyrunner33's Avatar
Originally Posted by cmns2500 View Post
yup....
A lot of the pre 2000 2500 manuals also came w/the Dana 80.
'99 Cummins: too many mods to list
Some tips on using the search function for better results.
crazyrunner33 is offline   Reply With Quote
Old 07-20-2009, 07:10 PM   #30 (permalink)
cmns2500's Avatar
didn't know that....
i like your avi too man...
Old 07-22-2009, 01:43 AM   #31 (permalink)
Jesse James's Avatar
Gosh dam I have looked all over for a diesel parts store online who stocks the 3rd gen brackets, which one did you buy them from for $37.00. Where can I get these?
01 Sport, auto, 2.5'' leveling kit, 35''toyo m/t, Fass HPFP, HX35, BHAF, 4''turbo back, Edge comp, 80 horse injecters, 3rd gen brake swap, Borgeson steering shaft, BD steering box stabilizer, TC lock up switch
Jesse James is offline   Reply With Quote
Old 07-22-2009, 10:24 PM   #32 (permalink)
MI Chapter President
IC-Smoke's Avatar
Would a pair of 3rd gen calipers work on this swap? would it be worth it?
Thanks!
Ian
Your local dodge dealer...
I picked mine up at the dealer for just under $38.00
Part #s
5093268-AA $38.96
5093270-AA $38.96
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
IC-Smoke is offline   Reply With Quote
Old 07-23-2009, 03:47 AM   #33 (permalink)
Thanks!
Ian
Part #s
5093268-AA $38.96
5093270-AA $38.96
3rd gen calipers are the same as the 01-02 calipers.
Old 07-23-2009, 09:47 AM   #34 (permalink)
IC-Smoke's Avatar
Thank you!!
Old 07-23-2009, 09:22 PM   #35 (permalink)
Thanks jasonsblkZ06
Old 07-23-2009, 09:52 PM   #36 (permalink)
Wastegate's Avatar
Thanks jasonsblkZ06
Hey Jesse, If you need those caliper brackets let me know and I can get them for you at cost..
99 Dodge 2500 with some stuff done to it
Wastegate is offline   Reply With Quote
