Old 06-20-2009, 09:05 AM   #13 (permalink)
Originally Posted by Nitrous340 View Post
I thought we all just had D60 fronts.... 2500 had D70 rear and 3500 had D80s. Mine is a D60 I believe. But 00-02 are the only ones that can do it to the front axle cause we have slip off rotors.
2500 Auto's had DANA 70's, Manual 2500's got the dana 80.. I believe anyway, I know i have the D80 on my '01 2500 6sp I believe this conversion will work on all trucks with outer mounted rotors
SlammedWagon is offline   Reply With Quote
Old 06-22-2009, 04:04 PM   #14 (permalink)
Whitehouse23's Avatar
so what do 1999 autos have in the front and rear? and i take it i cant do this conversion on my 99?
99 2500 Auto, 24V, QC, 4x4, AEM Filter, ADRENALINE w/ Pulse, AirDog150, BD Exhaust Manifold, 47re rebuilt DTT TC and Input shaft, 5 inch exhaust, HIDS, Silencer ring MIA
Whitehouse23 is offline   Reply With Quote
Old 06-22-2009, 05:48 PM   #15 (permalink)
MI Chapter President
IC-Smoke's Avatar
Originally Posted by DodgeLuvr View Post
well considering the impressive power coming from ur 2nd gen, i can imagine! cant believe you dont already have semi brakes on it or something j/k.
I need them! haha Im going with a slotted rotor and a set of HAWK pads. I need to woah the old girl down
Do you have any part numbers for the caliper brackets?
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
IC-Smoke is offline   Reply With Quote
Old 06-22-2009, 06:47 PM   #16 (permalink)
Originally Posted by IC-Smoke View Post
I need them! haha Im going with a drilled/slotted rotor and some high dollar pads. I need to woah the old girl down
Part #s
5093268-AA $38.96
5093270-AA $38.96
2001.5 2500 4x4, QC, 6 spd, 57/65/12, Int heater delete & horn, 5" exh, AD 150, Psychotty intake, 275 Inj, Edge Comp, Vulcan DS w/ dual return, SB Con OFE, 2" front level kit, 315/70R17 BFG A/T on H2 wheels, 3rd gen front brakes, DSS, Custom stereo.
JasonblkZ06 is offline   Reply With Quote
Old 06-22-2009, 06:57 PM   #17 (permalink)
IC-Smoke's Avatar
Originally Posted by JasonblkZ06 View Post
Part #s
5093268-AA $38.96
5093270-AA $38.96
Thank you!
Old 06-23-2009, 02:50 AM   #18 (permalink)
DavidLVG's Avatar
I'm curious now.... is there a place to go and find out what axles were on what models and years of trucks?? Or is there too much production indifference?
2001 2500 - 200k+ mi. - 60hp Chip - 5 speed - 13" SBC - Bilstein 5100's - 2" Coil Spacer & Leaf Block - Dual Shock Steering - 4" to 3" Gibson Dual Exhaust - 35" Toyo M/T
DavidLVG is offline   Reply With Quote
Old 06-24-2009, 03:44 PM   #19 (permalink)
D.Nel928's Avatar
All 4x4's had the Dana 60 front.
Automatic 2500's have Dana 70 rear, Manual 2500's have Dana 80s, and all 3500's have Dana 80s.
This is for 94-02 Models, after that I believe they went to AAM axles.
1999 - 3500 - 24 valve - 5 speed - 4x4 - 53 Block - South Bend Con OFE - 4" MBRP - Edge Comp - AD150 - Hummin Half Dozen!
D.Nel928 is offline   Reply With Quote
Old 06-24-2009, 04:10 PM   #20 (permalink)
All Cummins equiped 2500's came with the D-60 front but The 360 V8 gas equiped 2500's came with HD-D44's if im correct only in std cab configuration but maby in the ext cab also.. But this is a cummins forum so thats not too important untill your Phone shopping for junkyard parts..
Old 06-24-2009, 06:15 PM   #21 (permalink)
DavidLVG's Avatar
Good to know.... thanks.
Old 07-06-2009, 06:13 PM   #22 (permalink)
IC-Smoke's Avatar
just waiting on the rotors
Old 07-12-2009, 10:24 AM   #23 (permalink)
Keep us posted, what rotors are you going with?
Old 07-12-2009, 10:57 AM   #24 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
For the OP how many miles on the brake before replacement???
Surely you have a tough time catching me... 150K miles and still running on factory brake pads!
I might change brake pads by 200K miles...
Exhaust brakes are really handy!
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
