| 98.5-02 Non-Powertrain Discussion of 98-02 Topics Not related to the Powertrain...NO ADVERTISING |
Lowering Kit for Dually
Hey Guy's, I have a 2 wheel drive dually and have been searching all over for a rear lowering kit ( level with the front ). Thanks
:2001 3500 QDC,2 wheel drive auto,4"-6" drop, Rockstars,Goerend TQ convertor and Valve Body,Mach 1.6 injectors,Edge JWA Fass 150/150 , MBRP 4" turbo back Straight pipe , AFE Bladerunner , Isspro egt,boost,FP, Viper Hood Silencer Ring MIA..
#2 (permalink) |
beltech should have something...
01 2500 5spd 4 door 4x4, 4" turbo back from West Texas Diesel Performance, Quadzilla Adrenaline, missing silencer ring, Raptor 150, 90hp sticks, Pulse monitor & Valair ceramic clutch from Holland Court Diesel. 4-11-09 409.1HP/742.6FT-LBS |
#3 (permalink) |
ground force makes 2 in drop shackles
black 2001 2wd qcsb goerend billet,4.10's, juice with attitude, 5in fbd turbo back, 22" kmc xd hoss, 12k hid's 15.0 @91mph
#4 (permalink) |
does the stock 2wd use a block between the spring and axle? whatever way you go keep in mind the pinion angle will change and you may need to use a shim to eliminate driveline vibration
2001 QC LB 4x4 HO 3.54, boost/pyro gauges, B1-2-EX4, F1 Mach3, Smarty, Blue Chip FMS, ConFE, DSS, 4.5" lift, 37" Toyo M/T, Airlift airbags, Thuren track bar and crossover steering |
#5 (permalink) |
Ya there is a block between the axle and spring. I have called allover and cannot find a company that makes a drop shackle for an 01 they have them for the 02 what would the difference be...don't know what options I have only want to go 2-2.5 lower Thanks
#6 (permalink) |
01 and 01 should be exactly the same. alot of places arnt used to kits on the heavy duties and are used to how in 01.5 the body style changed in the half tons. dunno but they should all be the same
#7 (permalink) |
That is what I would think..but I want to be sure before I make the purchase. Thanks
#8 (permalink) |
![]() Join Date: Feb 2009
muggs did you ever find a kit for the rear? figure out something that would work? ive been lookin around too and cant find anyhting
crash 94 dodge 3500RC 12V 47RH (stock trans), stock fuel plate forward, starwheel forward. black euro lights w/ 6K hids and 5K hid blinkers. pioneer 7" touch screen w alpine 10" sub.
#9 (permalink) |
Diesel Junkie
![]() Join Date: Dec 2008
beltech off the shelf from the auto parts store like orileys will work
2007 FIAT 5.9L 2WD QC SB ELECTRIC BLUE Sun Roof w/1st Republic of Texas Flag cover,TWANKY DOS'S Tinted Tailights {REMOVED: Intake Baffle, Silencer Ring, Badges, Kitty} COLOR MATCHED: CFM+, Fuse Box Lid, ICEBOX <INSTALLED: Glass Pack, 2" Drop Shackles, custom stock grill, Dipricols, 6" Tip, GHD, Fiat Badging, AIR HORNS, custom interior, eyelids, 1000W THUMP> Trophy Winner @ TSD!
#10 (permalink) |
how much will it lower it? and i dondt wanna do it if itll hurt my towin any thanks
#11 (permalink) |
Diesel Junkie
get it about level and wont hurt the towing, still has toe factory springs and overloads, thats how mine is dropped
