how many quarts of oil does a 98.5 24v cummins take? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 37 (permalink) Old 05-31-2009, 06:47 PM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
11356cc's.
patracy is offline
post #14 of 37 (permalink) Old 05-31-2009, 10:52 PM
Originally Posted by Free Range View Post
I put in 3 gallons, brings it up right below the full mark on the dipstick. That and someone had chalked 12 qts on the fan shroud before I got the truck.
That's what mine does. I noticed the dipstick is different in mine from the ones I have seen in 2 '98's and a '99. I think ours do take 12. I'll have to check the manual.
RR
'01 QC 2500 long bed, 3:54 auto w/Dunrite VB & LU switch, untapped Comp, Scan gauge II, Raptor lift pump, fuel pressure gauge and trans temp gauge.
Russ Roth is offline
post #15 of 37 (permalink) Old 06-04-2009, 06:40 PM
Free Range's Avatar
Now do you fill the filter before you put it back on, or do you let the oil pump do the work? Just curious cause I do fill mine and just that takes quite a bit!
14 2500 68RFE 4x4 Tradesmen, stock 37k; 91 D250 auto, stock 299k; 01 2500 6spd 4x4, Smarty, AD 100, BD Steering stabilizer box boost fooler & elbow, BHAF, MBRP SS 4in, 09' steering linkage, Ranch Hand bullnose, 217k
Free Range is offline
post #16 of 37 (permalink) Old 06-04-2009, 07:27 PM
DodgeMech's Avatar
DON'T EVER PUT THE FILTER ON W/O OIL IN IT...
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #17 of 37 (permalink) Old 06-05-2009, 03:29 AM
Always fill it.
RR
post #18 of 37 (permalink) Old 06-05-2009, 03:40 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
There are 2 different dipsticks. The newer 2nd gen trucks came with a longer dipstick and tube to read full at 12 qts. I always put 12 in and it reads over but it doesnt leak anywhere.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
post #19 of 37 (permalink) Old 08-01-2009, 01:42 PM
Originally Posted by cmns2500 View Post
especially when ya run synthetic Rotella that costs about 20 bucks a gallon...
BUT, if we had the bigger capacity, the oil would last longer, which would pay itself off eventually maybe right?
Get a FS2500. Ive got 5000 on this oil change and the oil is still nice and honey brown. The filter will also allow to run about 1.5-2 quarts more. With this system, you should be able to go 15k on a oil change. I plan on going to syn rotella t on my next change. With these extended drain intervals, you will make up the diff so you can afford to run syn oil.
01 2500 QCLB. 6" Long Arm. 37" MT/R's. Juice w/Att, Smarty, AFE intake, AD150, CFM+, Super B turbo, Performance Innovations tranny and JKIDD 100HP Injectors.
Smokin&Shakin is offline
post #20 of 37 (permalink) Old 08-01-2009, 02:08 PM
I would not run more than the recommended 11 quart total on a factory stock truck that has the stock pan and filter system, more is not always better... Too much oil can bathe the crank too deeply and this condition can and does cause a lot of aeration in the oil and is very bad for bearings... This goes for all engines, be it Diesel or gas... I have spoken with a very reknown crank/rod/piston/cam/rocker maker and a Mobil 1 consultant and they spoke in no uncertain terms about their feelings on this... Cummins and petroleum engineers aren't substandard, and if they thought 12 or more quarts would've been better then You can rest assured they would have required so... They want their engine to last as long as possible... I'm not trying to be a big shot, but I have seen few engines that has scorched bearings due to this very topic... I'm passionate about engine longevity, mine and others...
K.Kiser is offline
post #21 of 37 (permalink) Old 08-01-2009, 06:34 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Originally Posted by BBRam View Post
Get 3 gallons.
(Return the favor)
It's 11 quart (2.75 Gallons) typically... But since I'm running Frantz filter I take 3 Gallons...
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #22 of 37 (permalink) Old 08-01-2009, 11:30 PM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
Originally Posted by Mopar1973Man View Post
(Return the favor)
It doesn't say add 3 gallons. Try reading before typing.
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
post #23 of 37 (permalink) Old 08-01-2009, 11:55 PM
milesdodgeboy's Avatar
Originally Posted by patracy View Post
11356cc's.
hmmmm now that's just accurate. I like that
2003 3500, 2014 john deere gator rsx 850i, stock 2002 jetta tdi with 01m that I rebuilt myself
milesdodgeboy is offline
post #24 of 37 (permalink) Old 08-03-2009, 08:40 PM
ROCKSTAR_RAM's Avatar
Well first time doin an oil change on the cummins and using shell rotella. I think il add 11 then check the level. Thanks for the write up everyone.
Spike It!
Have that mean, aggressive, and expensive look thats easy on your check book.
619-301-7880 or
ROCKSTAR_RAM is offline
