Converting a 99 dually 2wd to SRW 4x4 - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 01-29-2009, 07:51 PM Thread Starter
Does anyone know what would be involved in to convert a 2wd dually to a 4x4 srw?
Has anyone done it?
Im not so sure I like the newer quadcabs. Kinda like my body style. But want to have a 1 ton still.
Any thoughts?
Reddooley is offline
post #2 of 16 (permalink) Old 01-29-2009, 07:54 PM
Nick B's Avatar
you will need
rear springs 1 ton
front axle
entire front sunspension
t case
front and rear driveshaft
some body work on your bed
im sure there are more parts but this will give you a idea it will cheaper to just buy one i would think
99 2500,4x4,
Nick B is offline
post #3 of 16 (permalink) Old 01-29-2009, 07:57 PM
Big Rich 01's Avatar
Sell your truck and buy a 2nd gen 4x4 dually. Unless you have a small fortune to burn and a ton of time to invest in a project like that. Probably get a pretty god buck for your truck being from Arizona, home of the rust free dinosaurs.
01' Quad Long Bed adrenaline fass 100hp stix
01' Jetta tdi 45mpg 225,000 miles. rolling coal
95' Harley Davidson Fatboy 110'' Revtech
Big Rich 01 is offline
post #4 of 16 (permalink) Old 01-29-2009, 08:13 PM
edcasey's Avatar
Converting to SWR is very easy. It's the 4X4 conversion that's a PITA. Personally, I would sell it and get a 2500 4X4. Once you take the duallies off there isn't much difference anyways.
2000 3500 4x4, auto 4.10,BHAF, 4" MBRP, Power Puck, Converted to SRW, Dual Walbro 392's w/2 mic Cat filter, DiPricol FP, PSC DSS, billet trans
edcasey is offline
post #5 of 16 (permalink) Old 01-29-2009, 08:24 PM Thread Starter
Dually front axle is different from SWRD front axle isnt it?
Edcasey, could you expound on your comment about not being much difference once you remove the duallies?
post #6 of 16 (permalink) Old 01-29-2009, 08:25 PM Thread Starter
They didnt make one.
post #7 of 16 (permalink) Old 01-29-2009, 08:30 PM
edcasey's Avatar
The dually front axle and SRW are the same. A removable spacer is added to allow the dually wheels to be mounted.
edcasey is offline
post #8 of 16 (permalink) Old 01-29-2009, 08:35 PM
Nick B's Avatar
i know that. just buy a 3/4 ton and put 1 ton springs on and you have a 1 ton thats the only differnce in the 2 beside the rear axle but you can get a dana 80 srw if you want
99 2500,4x4,
Nick B is offline
post #9 of 16 (permalink) Old 01-29-2009, 08:51 PM Thread Starter
Gotcha. Ill put that into the data bank for now and check into it later.
post #10 of 16 (permalink) Old 01-29-2009, 08:53 PM Thread Starter
What about rear axle?
post #11 of 16 (permalink) Old 01-29-2009, 08:57 PM
Nick B's Avatar
the rear is differnt lengths but a 1 ton had a dana 80 this was a option or it came with manual 3/4 ton trucks
99 2500,4x4,
Nick B is offline
post #12 of 16 (permalink) Old 01-29-2009, 09:04 PM Thread Starter
Is the dana 80 that came on 3/4 tons wider also? Or same width?
