Running out of fuel at 1/4 tank - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 01-03-2009, 11:02 PM Thread Starter
mac0001's Avatar
Question Running out of fuel at 1/4 tank
Sometime last summer my fuel gauge in my truck stopped working. When it worked, I would usually run my truck down to an eighth of a tank before I would fill up. I had even seen the gas light a few times. I would generally get about 550 to 600 miles to a tank as long as I was doing mostly highway driving. Since then, I have been filling up by the miles on the trip meter. In the last couple of months, I have only been getting about 450 miles to the tank and just took it to be bad city mileage. Over the holidays, I finally got around to pulling the bed and replacing the float in the fuel tank. The old one was gone. I got a new one from Mopar so it was a stock part. The fuel gauge started working again and everything was fine. Well, I was coming back from a backpacking trip earlier today, and got back into town. I pulled into a left turn lane and was waiting on the traffic when my truck just shut off. I looked at the fuel gauge and it was still showing well over a quarter of a tank. I managed to get it started back up and ran on fumes to a nearby station and filled up, then had to crack the fuel lines to get her started back up again. The truck only held 28 gallons filled all the way to top. Why is my truck running out of fuel when there is should still be 6 gallons left in the tank and it is showing that fuel on the gauge? For some reason it is not picking up all the fuel. I know it holds more that 28 gallons because I have put over 30 gallons in before and thats not cramming it. I have talked to a couple of other people who have had this problem with their dodges and I would really like to know how to fix it. I don't really like not being able to use all my fuel, and would like to have it back to normal. Sorry for the long post, but any help would be appreciated!
2008 Dodge Ram 3500 Laramie 4x4 Auto, Smarty, S&B Intake, 5" Turbo Back
Sold- 2001 Dodge Ram 2500 quad cab SLT Laramie 4X4 6-spd high-output, K&N intake, Coaltrain injectors, Silverline 4in turbo back, Hewitt gauges, 2" leveling kit
mac0001 is offline
post #2 of 17 (permalink) Old 01-04-2009, 12:32 AM
Garrard8's Avatar
I know its gonna be a pain in the rear but pull the bed again and check the hoses in the sending unit.They could be damaged but who really knows.If you still have my number call me and I can help you.
2001 2500,4X4,Auto
Garrard8 is offline
post #3 of 17 (permalink) Old 01-04-2009, 11:41 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
You might have the float rubbing the side walls and hanging it up. I had the same problem with mine. Just loosen the cap and twist the sender the oposite direction. You might have to swing it till it taps a wal to figure out where your at... This can be done without pull the bed or dropping the tank...
2002 Dodge 2500 (281k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is online now
post #4 of 17 (permalink) Old 01-04-2009, 03:50 PM Thread Starter
mac0001's Avatar
Yeah, I thought about the float hanging up, but I made sure it was in the middle when I put it back in and it still doesn't explain why the truck isn't using all the fuel in the tank. Thanks for the thought! Any other ideas?
mac0001 is offline
post #5 of 17 (permalink) Old 01-05-2009, 08:45 PM Thread Starter
mac0001's Avatar
Just giving it a bump. Anyone got any ideas?
mac0001 is offline
post #6 of 17 (permalink) Old 01-07-2009, 12:35 AM
jason's Avatar
Mine did the same thing and it was the sending unit.
2000,4x4, quad, 285 Disc. AT's, XZT+ to big hoss level 5,banks high ram,banks wastegate,100hp injectors,4"tbe,TAG,ranch hand,leveling kit,triple disc TC, Transgo Tugger VB, trans,pyro,boost,fuel press gauges, BHAF, FASS 150 Titanium
jason is offline
post #7 of 17 (permalink) Old 01-07-2009, 08:42 PM
bigpipe_59's Avatar
Nothing to add here constructive, but just noticed your location... WAR EAGLE!
'00 2500 4x4: BHAF, silencer ring MIA, 4" d/p to 5" bull holler stack, Autometer boost, EGT, trans, & FP gauges, upgraded 47re, 3.55's, & fueling system
I'd rather be Cummin' than Strokin'
bigpipe_59 is offline
post #8 of 17 (permalink) Old 01-09-2009, 01:32 PM
sjstar's Avatar
ill give ya a bump also.
I have a little different case- in my truck it seems like the gauge calibration is off or something instead of reading empty to full my empty is little less than full and it seems to stay on full for ever any idears?
2010 Mega cab Laramie, 4x4, G56, S&B Intake, EFI Live, CTS monitor, South Bend DD clutch, Glacier big line kit, Flopro 4" exhaust
sjstar is offline
post #9 of 17 (permalink) Old 01-09-2009, 07:19 PM Thread Starter
mac0001's Avatar
I thought about that, but I changed the guts of it, but it still doesn't explain why I am only burning 28 gallons of fuel. Its like its not picking all of it up or something. Thanks for the thought though!
mac0001 is offline
post #10 of 17 (permalink) Old 01-09-2009, 07:20 PM Thread Starter
mac0001's Avatar
War Eagle man!
mac0001 is offline
post #11 of 17 (permalink) Old 01-11-2009, 05:41 PM
jadog's Avatar
The Pump And Pickup Are Able To Slide Up And Down. Maybe It Has Bound In The Up Position When It Was Re-installed.you Can Drop Your Tank Without Pulling Your Bed. Just Unhook The Wires And Hoses Before You Drop It Down All The Way.
98.5 24 valve dtt trans. 4" exh. guages edge ez afe filter bd exh. brake
jadog is offline
post #12 of 17 (permalink) Old 01-11-2009, 11:58 PM Thread Starter
mac0001's Avatar
I'm not really sure what you are referring to, but I don't have an in-tank pump and I didn't move the actual measuring unit that the float attaches to. I was very careful to make sure that the sending unit when back in in the right position so the float wouldn't hang up. There are even arrows on it and the tank to make sure it is lined up properly. I could have dropped the tank, but I decided it was much easier to just pull the six bolts out of the bed and lift it up instead of trying to drive 600 miles to empty out the tank or trying to pump it out. It really wasn't that hard, it just takes several people. I may have to pull it again and look at the pickup hoses in the sending unit, but I hate to do it all and that not be the problem. I really don't have any idea what the problem could be.
mac0001 is offline
