What size is the blowby hose on our trucks? I want to put a double ended barb fitting on with a hose extension so it will drip on the ground instead of my truck. Thanks
I just used a 6"-8" Black PVC threaded nipple and it twisted right up inside the stock tube. Puts the end just below the axle level and blends right in so that it looks like it belongs there. I do like Mopar1973's idea there but I was lazy and took the quick way.
the only reason why I suggest it is because it you do any kind of off-roading your going to get oil spillage. If you extend the hose straight down you'll never know that you spilled a large amount of oil.. Large enough to cause engine damage.
But in my method you'll never spill a drop of oil... And it doesn't require serious mods to your truck and it cost about $11 bucks to build. It don't drip on my garage floor either...:thumbsup
Mopar1973Man.com -=- Michael Nelson -=- (2o8) 628-3645 -=- If you need a hand with your Dodge Cummins give me a shout...
AirDog 150, RV275 Injectors, Edge Comp (Tapped), Straight Pipe 3" Exhaust, BHAF, Exhaust Brake, Timbo APPS, Southbend Con OFE, ScanGauge II, DiPriocl Gauges, High idle / MPG fooler, etc.
Well why didn't we all have that TSB done to our trucks since were having this problem.
Actually I just got done updating that web page listed above... There is actually two TSBs for the stock crankcase vent... And my little CCV fixes both...
The only reason I did go with the TSB fix was I didn't want to invest a full day to take my truck back to the dealer it rip it apart and add the TSB CCV... So I produced one for like I said $11 bucks... Really easy... :thumbsup
Can we still get this done now that we are way out of warranty period.
Just for the fun of it, yesterday I stop in the dealership to ask what is the price for the kit to eliminate pill bottle. kit # 05093017AA. They want $500 for it. That is insane. He show me the kit, contain one steel plate, clear plastic hose and some kind of round cap. I ask them, if is cover by the warranty, but person who handle warranty was not there. Maybe I stop there again, will be interesting to know, if is covered. Did anybody try this kit ?
