I've seen some people on here that have switches installed on the overhead console. I was wondering how people got the wires up through the roof without tearing everything up??
'99 dodge 4x4 NV4500, Super X VP, FASS 150, Custom Quick Spool Super B w/ ATS manifold, RV's, Smarty programming. north of 400 hp... Bout to add water/meth injection
take the headliner down. to get anything up there. gotta pretty much remove both a pillar covers, th erear c pillar covers the console itself and then the headliner will drop.
support your local voulenteer searchand rescue/emergency corps... AVEC347!!
Just to install switches, can't you just run them under the trim that holds the headliner up and down the pillar to the fuse panel.
I put switches in my overhead. I went from the floor behind the firewall, through and past the fuse panel, up to the A pillar next to the windshield, across the headliner (remove the visor and the headliner drops enough), to the center overhead console (I removed this also). I used some lightweight wire since I was only powering relays with the switches.
hey thanks, that's the kinda detail I was lookin for. Time to start on my overhead switches now! :thumbsup
