Battery Group Size... - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 11-30-2008, 12:13 AM Thread Starter
After searching everyone I can think of I can't seem to find anywhere on the net that simply tells me what group size my truck uses. It looks pretty close to a 27 but I haven't measured.
Thanks,
Keith
'98.5 24v QC LB 4x4 5 spd. 4.10 Gears
DD Stage III Injectors, TST Powermax Competition, ATS 3-piece manifold, Super 40 w/16cm WG Housing
kdw75 is offline
post #2 of 18 (permalink) Old 11-30-2008, 12:35 AM
countrycummins99's Avatar
ya it is 27 just replaced mine
99 DODGE 24VALVE, FASS 150, EDGE COMP/SMARTY REVO STACK/100HP COALTRAIN STICKS ,GOEREND BILLET, HE351VE ,TC LOCK UP SWITCH, 380HP 744FT/lbs with my old slipping auto , GAUGES (FUEL PRESSURE, TRANS TEMP, BOOST, EGT DP))INFAMOUS 53 BLOCK 310,159
countrycummins99 is offline
post #3 of 18 (permalink) Old 11-30-2008, 07:47 AM
yup... it's a 27.
I just put in 2 fresh batteries before winter came.
BTW... if you like DieHard batteries... buy them at K-mart... they are $10 cheaper than Sears. (and you can find online coupons too)
2001 2500 QC 4x4, edge EZ, Glowshift Gauges, 4" Exhaust, K&N, TransGo, AirDog 100, RV275
Tony, Prez A&L Motorsports, LLC.
Dr Honda is offline
post #4 of 18 (permalink) Old 11-30-2008, 10:11 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Strange... This is winter number 6 for my stock batteries in my truck. I've never had a dead battey nor had to be jump started.
I tell you a few secrets.
1. If you start your truck drive it far enough to get the batteries recharged completely (minimum of 10-15 miles)
2. Check the electrolyte often and add only distilled water to the batteries.
3. Use a battery charger and full charge the batteries once a month on a high setting. The will tend to make the battery gassy but stirs the water and electrolyte up.
4. Never let you battery go dead or low. If so charge it up ASAP. Don't wait till morning or otherwise. Longer a battery stays weak the less capacity it will have when re-charged.
I got good pratice at maintaining batteries... My house is powered by batteries...
These batteries are over 15 years old and still going strong... :thumbsup (1,000 pounds of lead acid cruiseliner batteries!)
Mopar1973Man is offline
post #5 of 18 (permalink) Old 11-30-2008, 12:12 PM
Garrard8's Avatar
Michael you are a very smart dude.:thumbsup
2001 2500,4X4,Auto
Garrard8 is offline
post #6 of 18 (permalink) Old 11-30-2008, 12:16 PM
Mopar1973Man.Com
Thank you... I enjoy sharing my knowledge and experiences with others! beer
post #7 of 18 (permalink) Old 12-01-2008, 03:56 PM
DieselRiot's Avatar
iTrader Score: 5 reviews
what is the highest cold cranking amps battery that can go in?
2008. EFI Live By Cummins-Tuner. Copilot. 5" TBE. S&B Intake With Scoop. GDP Mega-Flo With Boost Tube. GDP Pro-Gate. GDP CCV Delete. WCC Silencer Ring Mod. Rail Shim. Fass Ti 150. ARP 425's.
DieselRiot is offline
post #8 of 18 (permalink) Old 12-01-2008, 04:12 PM
I will second that motion....:thumbsup
So Mike.....say I just get some Wally marts or O'reilly Super Starts....750 CCA's but don't know the reserves....complete the helpful hints you have given and I should be OK for awhile....
I am just wondering unless the maker of the batts does a poor job of construction.....If so that is what I am going to be doing......My stockers have lasted 7 yrs now without servicing........I am happy with that!
THEGreenGoat is offline
post #9 of 18 (permalink) Old 12-01-2008, 04:49 PM
Mopar1973Man.Com
I've seen batteries as big as 750 to 900 CCA... Basically the more money your willing to toss down the more CCA you'll get... But the standard for CCA requirement is you need doulbe the starting load typically. So if our starter needs 300-350 AMP to start on a cold day then you need to look at 600-750 CCA to cover the load properly. More is better and it don't hurt. But being too small (CCA) will ruin a battery rather quickly. Also remember our truck are running 2 batteries in paralell... So the CCA amps is double now... So if you got 750 CCA batteries you would have 1,500 CCA worth of starting power...
Most batteries do fine even construction wise. But things like beating a terminal on the post with a hammer, not cleaning or maintaining the battery, extreme cold with complete discharge, not completely charging a battery. (short trip or bad charging system) These all ruin a battery quickly.
Maybe it a good reason both of us have gotten 6 to 7 years from a stock battery which is most likely. No better than that Wal-Mart O'reilly Super Starts you just bought...
post #10 of 18 (permalink) Old 12-01-2008, 05:48 PM
CumminStrokeThis2001's Avatar
Yep mines an 01 and the stock batteries are just starting to slow down now after 8 years
Its not pollution, Its HORSEPOWER
CumminStrokeThis2001 is offline
post #11 of 18 (permalink) Old 12-02-2008, 06:40 AM
DieselRiot's Avatar
yea still got my stockers in too. (02) Most likely gonna need new ones this winter.
post #12 of 18 (permalink) Old 12-02-2008, 01:29 PM
Garrard8's Avatar
By looking at what is running Michaels house he needs to change his username to gadget man..
2001 2500,4X4,Auto
Garrard8 is offline
