48RE shift kit install (47RE also) - Page 4 - Dodge Cummins Diesel Forum
98.5-02 Modifications Non-Aftermarket Mods. Upgrading what you already have.
post #37 of 49 (permalink) Old 08-03-2011, 07:46 PM
ddtnewyork's Avatar
is there any parts needed that a shift kit doesnt include and what would they be? that gm solenoid thing
03-2500 QCSB stainless 2nd gen mani,5" intake and exhaust, GD air boss,new intake horn, BD special, II dragon fly60's,w/bop, fuellab200gpm LP, Edge CTS ,33"falkens,s06pod,built47re- dynoed 500+
ddtnewyork is offline
post #38 of 49 (permalink) Old 08-07-2011, 06:28 PM
rllnsmk's Avatar
bump for same question above...
2004 1/2 Dodge Quad Cab SB- Edge w Juice, 5 Inch Turbo Back MBR Exhaust, Custom PVC Air Box Mod, 50 Gallon Tank in the bed
To Come - Air Dog Fuel System (unsure which one yet), Line X Rockers, Built Tranny, bunch of motor parts...
rllnsmk is offline
post #39 of 49 (permalink) Old 08-07-2011, 07:58 PM
calltrex's Avatar
doesn't come with BW solenoid or governor
both about $80 each
2003 Dodge 4 door 4x4, Auto
Edge computer with attitude, AFE Cold Air Intake
4" Exhaust System. 33" Terra Grapplers Es
AirDog 150 Fuel System, Industrial Injection 90hp injectors, Banks High Ram, 48RE Special, ATS Manifold, Super Phatshaft Turbo, ARP Studs
calltrex is offline
post #40 of 49 (permalink) Old 08-08-2011, 03:51 AM
rllnsmk's Avatar
thank u sir
rllnsmk is offline
post #41 of 49 (permalink) Old 08-04-2012, 09:20 AM
g_dog1's Avatar
Well I would like to thank Baxy for posting this thread and all of the details. I have installed my shift kit. It took be 2 day to do it, but I was being very careful. Along with the Superior Shift Kit, I installed the billet aluminum accumulator piston and an aluminum servo and cover. all the shifts except 2-3 feel firmer. Would the 2-3 shift feel softer because I used the stronger supplying spring on top of the new taller accumulator piston?
2007 5.9L 4X4 3500 Dually, Automatic. Bone Stock except for PML diff covers.
g_dog1 is offline
post #42 of 49 (permalink) Old 08-04-2012, 09:25 AM
g_dog1's Avatar
Taller accumulator piston
Here is the pic of the new piston and the stronger spring. I don't even know if the original piston had a spring on it at all...The ATSG manual said some models don't have a spring on top. Maybe there is a lot more force to move the new piston and stronger spring that it is making my 2-3 upshift feel slow and less firm.
g_dog1 is offline
post #43 of 49 (permalink) Old 08-04-2012, 10:07 AM Thread Starter
The band adjustment (space in the servo) is the 3rd acumulator
So if you used factory band adjust I would expect a stock feeling shift
As well if you still have a stock torque converter I wouldn't expect 3rd to be too aggressive
building/repairing transmissions at home message me if you need something done
BAXY is offline
post #44 of 49 (permalink) Old 08-14-2012, 09:41 AM
g_dog1's Avatar
After performing this shift kit upgrade, it feels like the transmission wants to hold first gear, and not shift into 2nd...a bit longer. So I either have to go faster or rev higher to shift to second. It isn't a large difference from stock, but it is still noticeable. Why might that be? Should I be increasing or decreasing line pressure, or is this the result of puting in stronger springs to offset the increased line pressure?
g_dog1 is offline
post #45 of 49 (permalink) Old 08-15-2012, 09:31 AM Thread Starter
Actually the kit should make second gear occur earlier
BAXY is offline
post #46 of 49 (permalink) Old 08-24-2012, 04:35 PM
g_dog1's Avatar
holding gear
What modification in the kit would tell the transmission to hold 1st gear longer or less long? Would it be the Gov. Solenoid? I thought that the Gov. Solenoid was responsible for telling the transmission when to shift.
What does the plug in the transmission case do? (What does it change?)
What changes, if any, would I notice if I was to increase the line pressure slightly?...Would it affect shift timing?
g_dog1 is offline
post #47 of 49 (permalink) Old 05-26-2013, 03:43 PM
I just installed this kit on my 2006 dodge 2500 yesterday, and now I have it all put back together and it goes into reverse great, goes into drive and it pulls strong but it will not shift out of first into any other gear. Can't shift manually either. Being that mine is an 06 I have the throttle valve actuator instead of the tv cable but regardless it still will not shift. I have taken it apart 3 times now and reinstalled it in the last day and same thing no shifting every time. HELPPPPP. I did everything to the T like the kit said, I'm so lost. This is my first shift kit installation and I was super confident after I did it but have been let down. I also installed the gm pressure solenoid on the billet block and disregarded the oe one. Did not change the pressure transducer because I don't have one but I don't see it going bad just cuz I put a shift kit in it :/ please help. Memorial Day weekend was supposed to be fun. If anyone can call me and give me advice that would be great. My name is Arden and my cell # is 8309927950. Thanks.
ardensmith830 is offline
post #48 of 49 (permalink) Old 06-01-2013, 02:35 PM
mykaos's Avatar
Thanks for the post. Got my parts, fixing to do this when I find a roundtoit.
05
, Compounds 62/65/14-S475, inter cooler, Crazy Larry, 45% injectors, FASS 150, CTS, 4" exhaust, Reworked 48RE, Billet Triple Disk.......and more stuff not worth listing
mykaos is offline
