Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Maintenance
98.5-02 Maintenance This is the 1998.5 2002 Dodge Cummins Maintenance Articles Section
Old 07-24-2008, 04:03 PM   #13 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
Originally Posted by piperca View Post
Gary, it might be my monitor, but is there a pink tinge on some of the pleats of the filter? Could that be the K&N oil being pulled through?
Yes - a small and harmless amount of the K&N coating came thru to the BHAF - absolutely NO adverse effect I could detect.
I might add at this point, that I have since this thread, converted to the Amsoil/Donaldson 9145 NanoFiber filter - also using the same inner liner material, as well as an Outer Wears waterproof cover - with EXACTLY the SAME results seen here above with the previous BHAF type filter!
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 07-24-2008, 04:30 PM   #14 (permalink)
Tech Specialist
For those unfamiliar with the Amsoil/Donaldson 9145 filter, as available to replace a BHAF for our trucks - here's a pic of mine - first, without the added OuterWears cover:
And then WITH the OuterWears waterproof cover - but inner liner absent:
The inner liner looks like this:
