Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Maintenance
98.5-02 Maintenance This is the 1998.5 2002 Dodge Cummins Maintenance Articles Section
Old 04-10-2006, 07:25 PM   #13 (permalink)
Jakey's'01H.O.'s Avatar
Angry
remove the friggin axle hub and shaft to get the damn rear rotor off??? ummm.....
'01 ETH/SO VP. FOR SALE.
'04 silv quad SB AirDog. Arson 2. loaded. HOLLAND COURT DIESEL PERFORMANCE. WICKEDDIESEL. DIESELNUT COALTRAIN IS THE SH$T
Jakey's'01H.O. is offline   Reply With Quote
Old 04-11-2006, 05:40 AM   #14 (permalink)
Gone...
Remember I've never done this on the 2002... I'm assuming the rotor and hub are one piece... But I still think that the hub will be dissembled to gain access to the parking brake shoes. I'm also asuming your truck is a 3/4 ton frame & axle.
Old 05-22-2006, 06:11 PM   #15 (permalink)
RJF
RJF's Avatar
I may be wrong here, since I have yet had to do brakes on my 2001.5, but I would imagine that the rotors are outboard style. The way you described with the hub needing to be removed is an inboard design. This is what I know from larger applications anyway.
2001.5 Ram 2500 4x4. Red Sport LB QC, black leather interior, billet everything. Edge HOT Juice/MBRP5"exhst/BHAF w,shield/Axiom &Suncoast trans, Amsoiled up
2002 Ram 3500 4x4. H.O. Black Sport/black leather. Mach1's, Jacobs brake, guages, SBC Con OFE
RJF is offline   Reply With Quote
Old 05-26-2006, 02:40 PM   #16 (permalink)
Hogg Innovations
Bosshogg's Avatar
The rear disks come off without pulling the axleshaft. There are two or three clips that hold the disk on from the factory-for the assembly line. they are on the studs, so you would have to clip them off with side cutters or the rotor wont come off. the only other thing it could be would be rust holding things on.
02.5 2500 4X4 reg cab white HO 6spd
Tapped Edge Comp with TST plate and Bosch RV 275 sticks. Stacks by Hogg innovations to roll the coal...
Hogg innovations lift pump/filter big line setup, Multi function shifter stick,Solenoid High Idle
LED's all over, and CF stickers too!!
Bosshogg is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
