Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Aftermarket Performance
98.5-02 Aftermarket Performance This is the 1998.5 to 2002 Dodge Cummins AfterMarket Performance Articles Section. Chips, Tuners, Intakes, Exhaust, etc...
Old 11-19-2007, 08:15 AM   #1 (permalink)
mayfair's Avatar
Arrow Running a FASS with the stock fuel heater
I've been asked quite a few times now about how I ran my FASS 150/95 and continued to use my stock fuel heater. As a result, I've decided to do a write up on how I did it. Hope it helps !!
I started by removing the stock fuel ( lift ) pump and the line that goes from the lift pump to the fuel filter. I then ran the line from the FASS onto the port where the stock fuel line was before. FASS provides the fittings nessary to screw right in here.
Here you can see the FASS line ( the blue line ) in the rear and the stock line that goes from the fuel filter to the VP-44 directly in front of it.
Here's another angle ...
Here you can see another advantage of keeping the stock fuel filter housing. By keeping it in the loop, you now also have a place to screw in the sensor for your electronic fuel pressure gauge.
Here's a shot to what you'll need to do. Basically I wanted to still use the stock fuel filter housing, but I didn't want to use the stock fuel filter anymore. I didn't want another filter to maintain and more importantly I didn't want to add any restrictions on the FASS at all.
What you'll need to do is trim off the top of your stock old fuel filter because it holds the o-ring that seals the housing. It's not difficult, I just used a razor blade
A close up shot once it's all done ...
That's pretty much it. Before I re-installed the housing I filled it back up with diesel fuel ( to make it easier to start and to prevent having to bleed air out of the first cylinder ) and screwed it back on. Once it was all done, I now have a running pressure of about 14psi and have yet to see it drop below 12 psi. It may run a little higher if I replaced that 1 foot section of stock line from the filter housing to the VP-44 with the larger line, I dunno. I didn't have any more line to try ( FASS is pretty stingy with their hose ... ). Either way, I'm very happy with 14psi.
Hope this helps !!
1998.5 24 valve 5.9 Cummins - Quad cab 8ft bed 4X4 - FASS 150/95 - Areo Turbine exhaust - K&N intake - Mag-tec Hy-tec trans and diffs - 3rd Gen 17" rims and caps - Edge Comp Box - Various other mods
mayfair is offline   Reply With Quote
Old 11-19-2007, 08:38 AM   #2 (permalink)
Super Moderator
rbmchief's Avatar
nice writeup. thanks mayfair.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin 2 stroke.
rbmchief is offline   Reply With Quote
Old 11-19-2007, 09:23 AM   #3 (permalink)
mayfair's Avatar
Glad you dig it Chief !!
It'll be yours and Dad's job now to remember where it's hidden for future use.
Old 11-19-2007, 10:48 AM   #4 (permalink)
Super Moderator
rbmchief's Avatar
?remember where what is? lol.
Old 11-19-2007, 10:58 AM   #5 (permalink)
mayfair's Avatar
It'll be yours and Dad's job to remember where this thread is hidden so that when someone asks in the future in one of the other topics / sections it'll be your job to direct them over here.
This forum is cool, but it IS a little confusing at times with all of the different "sections" that it's broken up into. For example if I wanted to research a specific subject I have about 6 different sections that I'll have to look in as opposed to having them all in just one "2nd Gen" catagory. Maybe not for the rest of the group, but for me it's kinda confusing.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
