Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Aftermarket Performance
98.5-02 Aftermarket Performance This is the 1998.5 to 2002 Dodge Cummins AfterMarket Performance Articles Section. Chips, Tuners, Intakes, Exhaust, etc...
Old 12-08-2008, 11:33 PM   #1 (permalink)
rattledbycummins's Avatar
High EGT's?
ok i got to know if i have a egt problem. whenever i take off from a stop in town under normal acceleration my egts seem to get up to like 700-800 degrees. when i get on the highway and the truck hits torque coverter lockup it will hit 1000 easy. based on my sig. is this how it is for my mods or is there something wrong here? im also going to be putting a hx40 in and want to know if it will help. are there any other ways to help controlly my egts?
1999 Ram 2500, Edge box, Stage 5 Injectors, ATS 3 piece, HX 40, K and N intake, BD Fuel Pump, Glowshift Boost Pyro Trans Temp guages, Low fuel pressure warning light, T/C Switch, 4 inch turbo back, Built Trans, 2'' leveling kit, Towing mirrors
rattledbycummins is offline   Reply With Quote
Old 12-08-2008, 11:42 PM   #2 (permalink)
bigger turbo,water/meth helps but a bigger turbo should help you,i run around 500-600 in town and 700-800 on the highway,cruising of course,under acceleration within reason like on an on ramp or something i will hit 1100 for a little bit but it drops back down to around 700.These are without my water/meth.
1998.5 dodge ram 4x4 qc,lb,edge juice w/att hot,coaltrain 200's,headstuds,airdog 150,S&B air filter,ats arc flow,aurora 3000 turbo,4" exhaust,pacbrake,coolingmist water/meth injection,ATS trans w/ 5 star converter,manual lock-up switch
rayster is offline   Reply With Quote
Old 12-08-2008, 11:43 PM   #3 (permalink)
oh,im not sure on this but i have heard those k&n's are bad for turbos,maybe someone else will chime in on this.
Old 12-08-2008, 11:45 PM   #4 (permalink)
GA CUMMINS CREW PREZ
SOUTHERN SMOKE's Avatar
you deffinately need a bigger turbo, thats why your egt's are high, you are running stage five injectors on a stock turbo, thats asking for trouble...
CLICK---> GEORGIA CUMMINS CREW
"There are no stupid questions, just stupid people."
Originally Posted by milldog View Post
Unless she makes the move first then show her the sambo stick!!!
SOUTHERN SMOKE is offline   Reply With Quote
Old 12-08-2008, 11:47 PM   #5 (permalink)
yea im always worried that when i boot it and im under hard acceleration the egts just seem to keep going.... and i back out of it erly because i dont wanna melt anything.
Old 12-08-2008, 11:48 PM   #6 (permalink)
i think im going to have to get that turbo in this week as well.
Old 12-08-2008, 11:51 PM   #7 (permalink)
Mike516882's Avatar
I can hit 1500* when punched for like 10 seconds. I too, need a BIGGER TURBO!
2000 QCSB, 47RE, Converter and VB, 150hp Sticks, Edge Comp, Leveling kit and 315's, Fass150, All the important Gauges, BHAF, 6" Black Miters, HTT 62/71/13SS!!
Mike516882 is offline   Reply With Quote
Old 12-09-2008, 12:02 AM   #8 (permalink)
BigBusa's Avatar
I will chime in. A bunch of people say that and have never presented good reasons why they are bad, and have sighted no specific instances where they have caused damage or harm. Me and my dad both run K&N's on our 06' 5.9's. I have 70,000 trouble free miles and he has 75k.
06' QC 4x4. 6" Superlift, 35" Toyo M/T's, 18" MKW M19's, Edge J/A +HOT, MP-8, K&N Intake, ATS Arcflow, MBRP 5", Bushwacker Flares, Tint. More to come!
BigBusa is offline   Reply With Quote
Old 12-09-2008, 12:04 AM   #9 (permalink)
BigBusa's Avatar
Oh, and those EGT numbers are very normal. I can't even run my hot unlock cuz it hits 1,500 in a few seconds and defuels. I'm switching to 35's (to decrease the load) and getting a manifold. Hopefully this will remedy the situation.
Old 12-09-2008, 12:20 AM   #10 (permalink)
Kansas Chapter VP
There are quite a few turbos ruined out there due to sucking in the cotton from a K&N filter. There was even some pics and discussion on this site about it. Now so I don't derail this thread any further,when you cram a lot of fuel with not near enough air(which is what permits the burning of the fuel) you get unused energy (HEAT) escaping the cylinder chamber. This is what causes unmanageable egt's. To simplify.....as said before, get that bigger turbo on soon.
2002 quad cab LB,24 valve CUMMINS,4x4 3.55 Dana 60F,70R
Kansas Cummins Crew ...Vice President
http://www.cumminsforum.com/forum/ka...mins-crew.html
Proud supporter of my RIGHT TO BEAR ARMS!!! Live by the 2nd......
Cummins in Kansas is offline   Reply With Quote
