why is cam sensor is in timing case on my 99 - Dodge Cummins Diesel Forum
98.5-02 24V P-Pump Conversion Discussion of converting 24V trucks from the VP44 stock pump to a P-Pump powered 24V No Advertising ...NO ADVERTISING
post #1 of 12 (permalink) Old 03-03-2013, 10:57 AM Thread Starter
Hi, I am in the middle of my p pump swap and never realized when I took my 24v timing case off that the cam sensor was in there. I was under the impression that the 99's picked it up near the starter. Is it possible that I have a late model 99?
I wish I had noticed before because I already put the cam in and buttoned up everything up top...
06 5.9 Megacab, 4x4, 295 toyos, Edge Juice w/ attitude.
99 QCSB, bombed p-pump, dpp dv's, 4k gsk, .083 lines, GD fuel boss, aeromotive a1000, Vulcan II draw straw, billet tc, 110# hamilton valve springs, Hamilton 188/220 cam
choga is offline
post #2 of 12 (permalink) Old 03-03-2013, 11:15 AM
00BRam's Avatar
98.5-00 trucks do use the crank sensor behind the starter. 01-02 trucks use the cam sensor on the timing case. You'll be fine without the sensor on the case, the factory tach will still work fine.
03 5.9 Cummins
SD s480, Duel CP3's, F1, Hamilton, Joker Fab, UDC tuned by Firepunk, and more
00BRam is offline
post #3 of 12 (permalink) Old 03-03-2013, 09:53 PM Thread Starter
Thanks for the info, been pullin hairs thinking I am going to have to pull the cam back out to install an adapter... What does the sensor in the timing case do if it is not necessary, will I loose anything else?
Thanks again, Doug
choga is offline
post #4 of 12 (permalink) Old 03-04-2013, 01:23 AM
blue02lbcummins's Avatar
I am in a similar boat. Mines an 02. is there any reason to not run a block off plate??
02 CTD QCLB 579hp 1029ftlbs @ XDP Dyno Day - torn down being PPUMPED!
92 W250 CTD daily driver, turnt up
Built Not Bought! With help from, Truck Toyz LLC, Diesel Shop LLC, & Marvin Racing
blue02lbcummins is offline
post #5 of 12 (permalink) Old 03-04-2013, 06:16 PM Thread Starter
I was thinking the same thing, looks easy to fab one.
choga is offline
post #6 of 12 (permalink) Old 03-04-2013, 06:19 PM Thread Starter
http://www.scheiddiesel.com/documents/1521.pdf
This helped
choga is offline
post #7 of 12 (permalink) Old 03-06-2013, 01:31 PM
00BRam's Avatar
01 - 02 trucks need the cam sensor to work the tach. 98.5-00 trucks its there and works but is not used for anything major in the ECM. It will maybe only throw a CEL. I have the 12V timing pin on my truck and my tach works just fine.
03 5.9 Cummins
00BRam is offline
post #8 of 12 (permalink) Old 03-06-2013, 02:33 PM
Originally Posted by choga View Post
Where can I get that addaptor shneid doesnt hsve them listed I guess im going to have to call. Im planning on using my 24v front cover does the 12v case need any modification done to fit the sensor.
I have also heard that the 01-02 trucks fuel pumps are wired and powered directly by the pc
And cut power at 4k? I have heard of people wiring in there lift pump (Ihave an air dog with 50psi spring) to a separate on off switch to prevnt this has any one else done this? ?
post #9 of 12 (permalink) Old 03-06-2013, 11:14 PM Thread Starter
Here is the part and part # from Scheid http://www.scheiddiesel.com/scheid-d...sor-adapter-1/
choga is offline
post #10 of 12 (permalink) Old 03-07-2013, 04:55 PM
Nice! Guess I missed it thats what I get for trying to do it from my phone
post #11 of 12 (permalink) Old 03-09-2013, 09:32 AM
00BRam's Avatar
I have heard the same thing about ECM cutting the power at 4K and being easier on the pump when starting. I have mine wired up on toggle switch.
03 5.9 Cummins
00BRam is offline
post #12 of 12 (permalink) Old 03-11-2013, 07:50 PM
Yeah I'm defiantly going to do the same thing I already need to make a switch panel for watermeth, lockup, and trans cooler so might as well.
